Old Dec 21, 2010, 01:14 AM
big_poppa4904 is offline
Find More Posts by big_poppa4904
Build, Fly, Crash, repeat
big_poppa4904's Avatar
United States, NC, Shelby
Joined Nov 2010
Will make sure of batts, thanks.
I also just finished my "wedge" mount for front viewing. Will test that out tomorrow if no wind.
I think the reason it seemed like it was bouncing up and down is I just stuck it on and went. I think I had it too far forward, as the nose kept wanting to go down. I will try and get more COG tomorrow.
big_poppa4904 is offline Find More Posts by big_poppa4904
Old Dec 21, 2010, 10:57 PM
Joined Nov 2010
Front view. I believe I can bring the angle up some with the prop still not in view. Will measure some tomorrow. Here is a vid
Click Link:
http://s457.photobucket.com/albums/q...efrontview.mp4
Old Dec 21, 2010, 11:33 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
As though there are not enough batts out there:
http://www.teamorion-avionics.com/av...o_avionics.pdf
For the time being, I sticking with my Hyperion 240's.......and my blankie.
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Dec 22, 2010, 04:39 AM
asboss is offline
Find More Posts by asboss
asboss's Avatar
United Kingdom
Joined Nov 2010
Originally Posted by big_poppa4904 View Post
Big-Poppa, Great first video, don't forget that you will need to re-trim when adding weight, you need to go level at half throttle and trim so it flys it's self more power you give the more altitude and less power it starts to decend in a steady manner.Great front angle . I would guess the trim is your bobbing problem, and when you fly without the camera you will have to re-trim again. Asboss
asboss is offline Find More Posts by asboss
Old Dec 22, 2010, 08:37 AM
Joined Nov 2010
yea, I did have to trim the steering a little. I guess the weight on the bottom changes stuff. But its still surprisingly easy to fly with the cam though. Getting better each time with the cam though, thats why the VERY first video was real "up and down", (i didnt have the COG set right, tail wanted to go down)
LOVE this plane!
Old Dec 22, 2010, 01:16 PM
asboss is offline
asboss's Avatar
United Kingdom
Joined Nov 2010
Take off and landing with some high flights and low passes.
http://www.youtube.com/watch?v=E8wX48-UyZg
Thanks for watching
Asboss
Old Dec 22, 2010, 01:33 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Thanks for watching
Asboss
Nice. What cam are you using on the plane?
modfly is offline Find More Posts by modfly
Old Dec 22, 2010, 01:53 PM
The Hog Pen is offline
Find More Posts by The Hog Pen
Go Ugly Early
The Hog Pen's Avatar
Azle, TX
Joined Oct 2010
Thanks for watching
Asboss
All those big fields around...and you chose a parking lot surrounded by trees?
But seriously...you knuckle-heads are going to force me to get an onboard cam, and show you some Champrobatics...lol
The Hog Pen is offline Find More Posts by The Hog Pen
Old Dec 22, 2010, 02:03 PM
asboss is offline
asboss's Avatar
United Kingdom
Joined Nov 2010
An 808 keychain cam, best buy ever!!!
Old Dec 22, 2010, 02:05 PM
asboss is offline
asboss's Avatar
United Kingdom
Joined Nov 2010
Only use the parking lot for take-off's and landings, makes it more fun with the trees. Normally not a problem but with the cam attached it's a bit more tricky.
Old Dec 22, 2010, 02:23 PM
totalywicked is offline
Find More Posts by totalywicked
Insert comment here:
totalywicked's Avatar
Placentia, CA
Joined Feb 2006
Maybe not the right place to ask but how do you do a roll with champ???
Every time I try it ends up being something weird…
totalywicked is offline Find More Posts by totalywicked
Old Dec 22, 2010, 02:31 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
You need to place the pushrods into a control-horn hole close to the control surface, and then you need a bit of speed.
I go a bit high, descend on full power, pull up a bit into a shallow climb, and then whack the rudder hard over.
A rudder-roll will always be a bit goofy, though.
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Dec 22, 2010, 02:41 PM
Placentia, CA
Joined Feb 2006
Dave
Thats probably the problem.
I was doing hard up and left or right at the same time…
Thank you Dave
Old Dec 22, 2010, 03:30 PM
CNY_Dave is offline
Joined Sep 2010
A flick up does help, but until I moved the rods I could only get inverted with a 1/2 outside loop.
Dave
Old Dec 22, 2010, 04:28 PM
turboparker is offline
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Thank you Dave
TW,
With the pushrods on the innermost holes, the Champ will do a nice snap-roll with those inputs if you enter the maneuver at the correct speed.
Joel
turboparker is offline Find More Posts by turboparker
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
