Old Jul 10, 2010, 10:32 PM
BigD1961 is offline
Find More Posts by BigD1961
Team OFG (Old Fat Guys)
BigD1961's Avatar
United States, KY, Leitchfield
Joined Jul 2008
Timer
Originally Posted by darksiede View Post
Yeh, the DX6i has a timer function, it can count up till you stop it, or down from a set time. I have mine set for up-count on all my micro's and count the beeps at each minute mark. Once done I stop the timer right before I unplug the battery. On my Champ I regularly go over 15 minutes on the 150 mah cells and have yet to hit the LVC cutoff. With the 250 mah cell, I've gone 31 minutes without LVC.
I fly by feel and when it takes more then 60% throttle to cruise I call it a done deal. When first starting a flight the 150 mah's cruise at 35% and the 250 just a hair under 40%.
~Kev
How do you activate the timer on the DX6I? I have yet to figure it out.
Thanks a bunch.
BigD1961 is offline Find More Posts by BigD1961
Old Jul 10, 2010, 10:33 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Thanks a bunch.
The trainer toggle on mine is what does it, in each model in the settings you can adjust a downcount timer for a set time, such as 15 minutes towards zero, or an open ended up count timer..
~Kev
darksiede is offline Find More Posts by darksiede
Old Jul 11, 2010, 07:04 AM
leethetreeguy is offline
Find More Posts by leethetreeguy
Fly em if ya got em.
leethetreeguy's Avatar
Winder Ga
Joined Sep 2008
On each model, you can scroll down to the "adjust settings" function. Click that. Then scroll down till you see timer. Click that. Then you can make it another switch that activates it. I like the "cut throttle" button to activate mine. I had a great flight last night. Flew off of a bench in my back yard. hahaha. Then 14 minutes of true happy flying. Loving it. Lee
leethetreeguy is offline Find More Posts by leethetreeguy
Old Jul 11, 2010, 11:15 AM
lightspeeddud is offline
Find More Posts by lightspeeddud
Up Up and Away!
lightspeeddud's Avatar
Joined May 2008
Originally Posted by qiuliyeye View Post
Cheap, affordable choice of a life.
http://www.12usd.net
get out of here you little S H ! T
lightspeeddud is offline Find More Posts by lightspeeddud
Old Jul 11, 2010, 11:28 AM
Aero Andy is offline
Find More Posts by Aero Andy
ExPat
Aero Andy's Avatar
Spain, Murcia, Mazarrón
Joined Apr 2010
Cheeky bugger!! Sod off!!
Aero Andy is offline Find More Posts by Aero Andy
Old Jul 11, 2010, 11:32 AM
ShawnM4kq is offline
Find More Posts by ShawnM4kq
Still AWD, Subaru
St.Louis
Joined Nov 2006
already reported it to the mods
ShawnM4kq is offline Find More Posts by ShawnM4kq
Old Jul 11, 2010, 11:34 AM
Winder Ga
Joined Sep 2008
Any of you flown your Champ today? Just trying to get back on subject after this little derailment. LOL. Lee
Old Jul 11, 2010, 01:53 PM
Still AWD, Subaru
St.Louis
Joined Nov 2006
yup flew earlier, added some new details...waiting for the tornado's to pass through.
Old Jul 11, 2010, 01:54 PM
smoothone is offline
Find More Posts by smoothone
Greenville Tx.
Joined Oct 2006
flew mine today
Did a little flying over my pond, just waiting for some floats lol.
smoothone is offline Find More Posts by smoothone
Old Jul 11, 2010, 02:00 PM
Greenville Tx.
Joined Oct 2006
whats the best way to add a video. Most of mine are wmf.
Old Jul 11, 2010, 02:02 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
The easiest way is to upload them to a youtube account you set up.
UNGN is offline Find More Posts by UNGN
Old Jul 11, 2010, 02:20 PM
Greenville Tx.
Joined Oct 2006
ok thanks
Old Jul 11, 2010, 05:27 PM
BigD1961 is offline
BigD1961's Avatar
Joined Jul 2008
Timer and Champ with DX6I
~Kev
Thanks a bunch.
On a different note: Has anybodyused their DX6I with their champ, and if so, what settings do you use?
Old Jul 11, 2010, 05:31 PM
Winder Ga
Joined Sep 2008
I use a dx6i with all my pz. Settings are always different. You don't wanna burn the servo's. Lee
Old Jul 11, 2010, 09:53 PM
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
Thanks a bunch.
On a different note: Has anybody used their DX6I with their champ, and if so, what settings do you use?
Yeh, I use my DX6i on every plane I own... Main thing to keep in mind, is do not set the travel beyond 100% on any control surfaces, you can over-travel the servo and burn it up. Also be careful with your mixes if you choose to run any, as sometimes you can cause an over-travel situation with a mix on.
IE:
Aileron +100% -> Elevator +10%, giving you 10% up elevator at full aileron deflection, but if you manually put in 100% elevator on the stick with that mix on, you can get up to 110% and cause an issue. The DX6i will allow you to exceed the ATV maximums of the ar6400 and other bricks.
I run mixes on mine just to be lazy, doing just as above, I've never had a problem with it, but others have reported issues.
Otherwise, as far as main settings I just run a single Hi/lo rate switch, usually on the flaps/gyro toggle because none of my models have flaps or gyros :P
~Kev
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 890 Sep 29, 2016 12:12 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
