Old Jun 07, 2010, 02:56 PM
kenstogie is offline
Find More Posts by kenstogie
Can we lift the embargo?
kenstogie's Avatar
menands flats, NY
Joined Dec 2006
Hobbyzone Champ Mods
Didn't see any threads on the Hobbyzone Champ in the Mods department so thought I'd start one up. If there is let me know.
Of course you can...
-use a better TX (DX6i, DX7, LPD5M, DX5E or any DSM2 TX) use a little mixing/dual rates etc.
-adjust the control horn positions for more response
-maybe go brushless (if you have please post!!)
-get a bigger battery or use a smaller one too(Hperion and Turnigy and the list goes on)
Hobby King List, ( I would stick with 240 and under)
http://www.hobbyking.com/hobbyking/s...figuration.asp
Turnigy 160 30c(not really 30c but it's cheap enough )
Hyperion HYPERION G3 CX 0160 MAH 1S 3.7V 25C/45C SINGLE CELL W/UM CONNECTOR
Hyperion link 2
Multiple Battery Charging at one timehttp://www.hobbycity.com/hobbyking/store/uh_viewItem.asp?idProduct=10621&Product_Name=2_Pin _JST_plug_with_6_x_Pico_plug_charging_harness
Floats http://www.rcgroups.com/forums/showp...&postcount=582
PARTS at My atomic also available on EBAY and Horizon Hobby too.
prop_with_spinner http://myatomic.com/catalog/viewsku?..._spinner_champ
gear_box_w_motor http://myatomic.com/catalog/viewsku?..._w_motor_champ
pushrods_w_accessories http://myatomic.com/catalog/viewsku?...essories_champ
bare_fuselage
main_wing http://myatomic.com/catalog/viewsku?...ain_wing_champ
complete_tail http://myatomic.com/catalog/viewsku?...ete_tail_champ
main_landing_gear_set http://myatomic.com/catalog/viewsku?...gear_set_champ
On Board Video
Various Cams...
http://www.actionfigurelover.com/act...car-key-camera
-different props
http://www.rcgroups.com/forums/showp...postcount=1063
kenstogie is offline Find More Posts by kenstogie
Old Jun 07, 2010, 08:33 PM
Scarface26 is offline
Find More Posts by Scarface26
Colorado Springs, CO.
Joined Mar 2009
The Hyperion G3 CX 0160 Mah battery is also $7.99 ea vs $12.99 for the E-Flite 150 Mah at my LHS.
Scarface26 is offline Find More Posts by Scarface26
Old Jun 08, 2010, 01:47 PM
Flyboy Steve is offline
Find More Posts by Flyboy Steve
Joined Nov 2007
Was flying my Champ this AM. Coming out of a power dive into a loop, and just BARELY hit the upright of a soccer goal. Tore the right wing off at the root. The rest is still attached to the fuse, but the right wing ripped off.
Can I CA it back on? Will it be strong enough to take loops, etc?
Anyone take the wing OFF the Champ yet? Is it glued on or taped or ??
Wasn't ready to start (re)building yet, but I'm out of choices...
Suggestions?
Flyboy Steve is offline Find More Posts by Flyboy Steve
Old Jun 08, 2010, 01:54 PM
Carl T is offline
Find More Posts by Carl T
CARL T
Carl T's Avatar
United States, OR, Grants Pass
Joined Dec 2005
Kenstogie.,
I have a group of mods that I will post when I get them drawn up.
Carl
Carl T is offline Find More Posts by Carl T
Old Jun 08, 2010, 01:56 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
Suggestions?
You can glue it back on, but its very likely to fail in the air next time. I would suggest adding a piece of carbon fiber rod under the wings to strengthen it back up if you do glue it. Make sure you use foam safe CA and foam safe accelerator on it too.
You can also get the wing by itself to replace:
http://www.horizonhobby.com/Products...ProdID=HBZ4920
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Jun 08, 2010, 02:42 PM
Joined Nov 2007
How is the wing attached to the fuse? Glue? Double sided tape?
What's the best way to get it off w/o damaging the fuse?
Should I put a fiber tape "spar" on the bottom of a new wing before attaching it?
Old Jun 08, 2010, 03:04 PM
SabreHawk is offline
Find More Posts by SabreHawk
Off we go.............
SabreHawk's Avatar
Seattle, WA. USA
Joined Jan 2006
Flyboy it's attached like all the other micros are, by a very thin double sided sticky tape. Just very gently and carefully work it off of the fuse. And I'd advise doing that and replacing it entirely. I can't see it ever being as strong by gluing it.
Hehe, and then stay higher up when doing loops and well away from objects like a soccer or football goal.
SabreHawk is offline Find More Posts by SabreHawk
Old Jun 08, 2010, 03:24 PM
3D-Seth is offline
3D-Seth's Avatar
Joined Jan 2007
The new wing will be fine without any reinforcement. I was only suggesting reinforcement if you glue the wing back together.
It is attached only by double sided tape. Just be careful and easily work the wing off of the airplane.
Old Jun 08, 2010, 03:34 PM
Donaldo Gordini is offline
Find More Posts by Donaldo Gordini
USA, CA, Hayward
Joined May 2006
Flyboy, I would order a new wing AND fix the old one. I would use a couple of bamboo toothpicks and CA (foam safe) them into the fuse side first. Then after the CA sets, dry fit the right piece of wing. When everything matches up, then use CA and a little bit of TP (Toilet Paper) if not a perfect match. The only caution here is that CA takes a long time to set on the inside of the foam, so once you get everything aligned let it cure at least overnight. You may also want to put some clear tape across the break. The weight of the CA and toothpicks should not significantly affect the balance. If it breaks, then you will have a new wing (previously ordered) to replace. I would bet the repair would last for weeks or more as long as you don't try flying into another object! Also, if you replace the wing, I would put a clear tape spar on the bottom of the wing. Just be careful when applying so that you don't tape a twist or bend into the wing. Good luck!
Don
Donaldo Gordini is offline Find More Posts by Donaldo Gordini
Old Jun 08, 2010, 05:05 PM
Hellysmack is offline
Find More Posts by Hellysmack
What package dear?
Hellysmack's Avatar
USA ILLINOIS
Joined Nov 2002
Suggestions?
Broke both sides off mine.
I cut some of the clear plastic (that all new junk comes in from the store) into strips, used clear double backed taped it to the wing then applied clear packing tape over whole assembly. Somewhat like a splint, it has been very solid and has over 20 flights on it. No paint is needed and from a distance you can’t tell, up close not so pretty.
Then fly it like you stole it
Hellysmack is offline Find More Posts by Hellysmack
Old Jun 08, 2010, 07:02 PM
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
Subscribed
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Jun 09, 2010, 10:40 AM
Mike F is offline
Find More Posts by Mike F
Brookings, OR.
Joined Dec 2005
I got a look at Carl T's mods and they are really going to trick this baby out and improve its durability
Mike F
Mike F is offline Find More Posts by Mike F
Old Jun 09, 2010, 10:56 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
Link?
Any one is any mixing on champ on programmable TX?
Anyone try UMP51 motor or know the piñon count? I think it's the same motor as sukhoi but I am not sure if piñon count is same as UMP51. But if it were would give the champ a little more juice coupled with GWS 543 prop and Hyperion batt.
Mike F
Old Jun 09, 2010, 12:00 PM
0xC0FFEE is offline
Find More Posts by 0xC0FFEE
Ordinary Average Guy
0xC0FFEE's Avatar
United States, MI, Northville
Joined Jan 2007
I have a P-51 motor in my Champ. The stock motor failed relatively quickly on me. It was a drop-in replacement, fits perfectly. The power lead is a bit longer on the P-51 motor.
I don't have any way to accurately measure the exact thrust, but I'd say that it's in the 1:1 area.
I am using the stock prop and 160 mah Turnigy and Poweredge batteries.
0xC0FFEE is offline Find More Posts by 0xC0FFEE
Old Jun 09, 2010, 02:54 PM
QuAd FaNaTiC
Canada
Joined Aug 2009
Cool
does it climb any better?
Article HobbyZone Champ RTF Review dee-grose Micro Ready-to-Fly 889 Mar 01, 2016 06:43 PM
Discussion HobbyZone Champ On-board Video VasMan Aerial Photography 4 Jul 03, 2015 01:09 AM
Alert HobbyZone Champ RTF Group Buy in Middle TN: $87.80 per plane (including tax) PerlAddict Hot Online Deals 5 Jun 16, 2010 06:00 PM
Wanted Hobbyzone Champ pmass23 Aircraft - Electric - Airplanes (FS/W) 0 Jun 01, 2010 01:17 PM
Video Hobbyzone Champ - Short Glide Video VasMan Electric Plane Talk 0 May 16, 2010 10:01 PM
