Old Jun 07, 2010, 11:31 AM
A.B. is offline
Find More Posts by A.B.
A.B.'s Avatar
Calgary Alberta, Canada
Joined Feb 2008
IOM mast rule question
So I screwed up and made my mast tube to fit my 10.9mm mast tight and keel mounted, now if I wanted to use a larger diameter mast could I use a smaller insert in the bottom of a larger mast, or do i need to covert to a deck mounted mast?
A.B. is offline Find More Posts by A.B.
Old Jun 07, 2010, 09:34 PM
hew565 is offline
Find More Posts by hew565
USA, LA, Mandeville
Joined Feb 2005
I am not sure about the rules, but Anders Wallin posted his plans for a finbox/mast box that uses a small opening for a 5mm mast foot. If it is not illegal, your 10.8mm one won't be!! It could be argued that his 5mm extension is smaller than the allowed minimum mast diameter, but it really is just a way to transfer the load from deck level to the bottom of the hull. No different than a compression post under a deck mounted mast, to me, anyway!
http://www.anderswallin.net/2006/11/...nbox-for-noux/
hew565 is offline Find More Posts by hew565
Old Jun 08, 2010, 08:10 AM
mfr02 is offline
Find More Posts by mfr02
Blackpool, Lancs
Joined Feb 2006
I think you'll find that the rules talk about the height of the mast above the deck, with no detail about whether the mast is deck stepped, keel stepped or something in between.
mfr02 is offline Find More Posts by mfr02
Old Jun 08, 2010, 08:53 AM
8387mike is offline
Find More Posts by 8387mike
8387mike's Avatar
Perth Western Australia
Joined Jul 2009
Ok this is interesting
F.3.2 CONSTRUCTION
(a) A mast stub arrangement is permitted and, if used, shall be taken to be part
of the mast.
(b) Between the lower point and the upper point the spar section shall be:
(1) of circular outer shape,
(2) constant
within the variations permitted by F.3.4 except for the following permitted
items:
So a mast must be constant, what does that mean?
1) Constant size i.e. tapered lengths or different size mast widths
2) Constant lenght i.e. no joins
So how to get around this would be to insert a narrow shaft into the mast box and have a step on top of it, because unless you built the deck extremly strong it might colapse. So would this get around the above rules? would this be classified as a Step?
8387mike is offline Find More Posts by 8387mike
Old Jun 08, 2010, 02:16 PM
casy is offline
Find More Posts by casy
Joined Feb 2008
mast stub
Hi all after reading 8387 mike's entry it kinda takes the fun out of sailing especially if you have to be a lawyer to interpet the rules have fun Casy
casy is offline Find More Posts by casy
Old Jun 08, 2010, 05:40 PM
A.B. is offline
A.B.'s Avatar
Joined Feb 2008
Could someone who has access to the IOM forum, please post question in the rule area? I have tried to get an account but did not work.
Thank you
Andrew
Old Jun 08, 2010, 08:57 PM
hew565 is offline
USA, LA, Mandeville
Joined Feb 2005
constant diameter... no taper. You can have two piece masts, with a joiner. The joiner can not be longer than 100 mm I think, but it makes carrying an A rig much easier!
The "Lower point" referred to above, is the point where the bottom of the sail cannot exceed (go below it), at the gooseneck. It would be hard to put any limitations on the section of the mast below the "Lower Limit Mark" because of the different vang arrangements.
I think you are good with your plans, although I made the move to a skinnier mast and would not go back to a larger mast!
Your question was posted and the thread is here ==> http://onemetre.sbmyc.com/forums/vie...hp?p=8435#8435
Suggestion Language Rule question Jacques Flambeau Site Suggestions / Complaints 1 Apr 03, 2010 04:30 PM
Discussion AMA safety code rule 4 rewritten: 2010 AMA safety code rule 5 Thomas B AMA (Academy of Model Aeronautics) 18 Jan 20, 2010 02:51 PM
Discussion Mast Question and Info Teamwoody Aerial Photography 4 Apr 14, 2008 06:51 AM
Help! Century 750 mast/rig question jensenflemming Sailboats 5 Mar 26, 2008 04:39 PM
Question Main Mast Question brucie1dog Coaxial Helicopters 2 Mar 01, 2005 11:12 AM
