Old Jun 07, 2010, 12:56 AM
electronutter is offline
Find More Posts by electronutter
cambridge nz
Joined Oct 2008
Question
JW fus to wing join?
Hi just been dsing my Jdub and I used strapping tape pieces to join fus to the wing, every crash I needed to redo the tape. This got A bit tedious.
Does anyone have a better way, BTW I'm using 10 mil and gooped fus..
electronutter is offline Find More Posts by electronutter
Old Jun 07, 2010, 01:12 AM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
I used goop to fix the wing to the fuse.
rockbus is offline Find More Posts by rockbus
Old Jun 07, 2010, 01:20 AM
prplgoat is offline
Find More Posts by prplgoat
gas tires and oil
prplgoat's Avatar
malad, idaho
Joined Dec 2004
i just goop em on, but i make a receiver hatch just in front of the tail for access.
marty
prplgoat is offline Find More Posts by prplgoat
Old Jun 07, 2010, 01:56 AM
Forrest12 is offline
Find More Posts by Forrest12
DS state of origin NSW Vs QLD
Forrest12's Avatar
Joined Jul 2009
Hot Glue, holds enough when you want it and breaks apart when you need it.
Pete
Forrest12 is offline Find More Posts by Forrest12
Old Jun 07, 2010, 06:48 AM
spotterone is offline
Find More Posts by spotterone
Can you DS it??
spotterone's Avatar
Australia, NSW, Berowra
Joined Aug 2008
Pete
.....and if you have a gas powered hot glue gun, it's fixed at the slope in 3 minutes!
spotterone is offline Find More Posts by spotterone
Old Jun 07, 2010, 12:53 PM
cambridge nz
Joined Oct 2008
Cheers Guys for your input, goner go with the hot glue(quickneasy)
I've not seen a gas powered gun that would be handy where do you get em over there?
Old Jun 07, 2010, 05:37 PM
skaffen is offline
Find More Posts by skaffen
Ook!
skaffen's Avatar
New Zealand
Joined Aug 2007
You could try crashing less?
skaffen is offline Find More Posts by skaffen
Old Jun 07, 2010, 05:48 PM
cambridge nz
Joined Oct 2008
If you ain,t crashing you ain,t trying
Old Jun 07, 2010, 06:23 PM
skaffen is offline
Ook!
skaffen's Avatar
New Zealand
Joined Aug 2007
You must be trying really really hard!
How fast do you reckon you and Marce were going yesterday?
Old Jun 07, 2010, 07:03 PM
Can you DS it??
spotterone's Avatar
Joined Aug 2008
I've got a Portasol butane powered gun.
http://www.jaycar.com.au/productView...l&form=KEYWORD
Old Jun 07, 2010, 08:19 PM
cambridge nz
Joined Oct 2008
Cheers Pete we've got a jaycars in Hamilton will have a look
Marce reconed about 185 kms, thought you would have played with us yesterday..
Old Jun 13, 2010, 01:17 AM
cambridge nz
Joined Oct 2008
No the hot glue let go strait away I don't think it sticks to laminate .
Will try gooping the wing on and see what gives or doesn't.......
Old Jun 13, 2010, 09:38 AM
Can you DS it??
spotterone's Avatar
Joined Aug 2008
I'm fairly certain hot glue does stick to laminate or covering film. It's worked on my JW's perfectly, and I've built (and crashed) 1 or 2.
Name: IMG_0224 [1280x768].jpg
Description: The current fleet
Old Jun 13, 2010, 04:43 PM
cambridge nz
Joined Oct 2008
OK I will re glue and persevere with it , probably did something wrong
Awesome fleet by the way you must love J dubs
Old Jun 13, 2010, 09:20 PM
flyboyjimi is offline
Find More Posts by flyboyjimi
The sky is my playground
flyboyjimi's Avatar
Near the Ocean in Hunt. Beach Calif.
Joined Apr 2006
The stock build on a J w says to leave foam strip on the wing and inside the fuse. There ain't supposed to be any laminate on these two areas just so the goop or hot hot glue will stick foam to foam! Try it then you can run a bead of goop or glue as a fillet to smooth the edge where the two seams come together good luck. Jimmi
flyboyjimi is offline Find More Posts by flyboyjimi
Sold JW 60" and extra wing w/triple carbon spar $250 jrbike Aircraft - Sailplanes (FS/W) 2 May 20, 2010 11:00 AM
Question best way to install a wing servo for a slop free fit in a JW grfcon Dynamic Soaring 10 Feb 11, 2010 09:43 AM
Discussion help with wing join on a skylark slingsbyskylar Scale Sailplanes 8 Dec 21, 2009 05:03 PM
Discussion Fus/wing ratio JoeSantora Modeling Science 9 Nov 03, 2009 04:16 AM
Discussion foam wing join Fly Boy3 Fuel Plane Talk 2 Sep 08, 2009 11:45 AM
