Jun 24, 2010, 04:47 PM
New Zealand, Hawke's Bay, Havelock North
Joined Dec 2004
Greg,
Nicely done! The next level of complexity is to optimize the airfoil for each design variant and see if the same trends/sensitivities still hold true. Yes, there is some reinvention of the wheel in all this number crunching, but for me at least, doing the numbers really gives one a "feel" for the design space instead of just having the results handed to you by someone else. If you can find a copy (maybe check with JT), have a look at the proceedings from the MARCS sailplane symposium from way back in the late 80s (between '86 and '88 if memory serves) where I gave a talk on XC design optimization. Yes, this optimization was a bit on the crude side (single airfoil, 2 ch design). What also may be of interest is the stuff regarding speed to fly. One wee little thing to remember is that way back then, I did the analysis using a hand calculator. Spreadsheets were a gleam in someones eye way back then...
Jack,
You bring up an interesting aspect regarding visibility. I suspect that something between mean and average chord is the appropriate choice for visibility optimisation. One would need to do some real-life experimentation to further refine what the independent variable should be for the optimization process.
Dihedral is a pretty minor player in the performance side of the equation. I suspect that the dihedral constraint gets defined by spiral stability as one really wants the vehicle to have reasonable spiral stability for flying at high altitudes.
As for the losses at the dihedral joints, these are pretty small in the grand scheme of things. The next item in the evolution of XC performance will be in the reduction of wetted area of the fuselage as just about all of the current aircraft flying have more than a wee bit of performance degradation at inter-thermal speeds due to the drag of the fuselage.
