Old Aug 08, 2011, 11:24 PM
G Norsworthy is offline
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
Finished the wiring harness, RDS, and joiners. All that is left is assembly and balance. Looking really good.
G Norsworthy is offline Find More Posts by G Norsworthy
Old Aug 09, 2011, 11:18 PM
Master of the Wind
Joined Sep 2008
All balanced and still a few hundred grams under. Just the wipers on the hinge lines and we are ready to fly.
Old Aug 10, 2011, 10:43 AM
MikePal is offline
Find More Posts by MikePal
Mt. View, CA, USA
Joined Nov 2009
XC#10 Flys Again
Glad to hear the fix is coming along nicely. It will be nice to get some test flying in before Cal Valley.
MikePal is offline Find More Posts by MikePal
Old Aug 10, 2011, 12:33 PM
dbaya is offline
Find More Posts by dbaya
dbaya's Avatar
United States, CA, Union City
Joined Mar 2004
Maybe in a couple weeks we can test fly and get distance pins. SVSS in a couple weeks??
dbaya is offline Find More Posts by dbaya
Old Aug 13, 2011, 11:12 PM
Master of the Wind
Joined Sep 2008
All fixed and we have a winch tomorrow.
Old Sep 23, 2011, 09:16 PM
FlyVA is offline
Find More Posts by FlyVA
"Flying is my life!"
FlyVA's Avatar
United States, VA, Salem
Joined Oct 2002
Update
Awful quiet. So?
Whats next? We're all ready for your next project.
FlyVA is offline Find More Posts by FlyVA
Old Sep 23, 2011, 11:49 PM
Master of the Wind
Joined Sep 2008
At Cal Valley now. Good run today. Neck and neck with the Supra. Next will be a second copy but that is a winter project. Supra is easier to fly but #10 may have a little edge in speed. Mostly comes down to pilot at this point.
Old Mar 15, 2012, 11:02 PM
rrcdoug is offline
Find More Posts by rrcdoug
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
Hi Greg, I have been lurking on your XCracer series for over a year. I fly genies (Harley) which are slightly smaller.
I am writing this to warn you that over winter my RDS coupler crumbled from acid residue I left inside the tube when I soldered the wiper arm in. New procedure calls for soaking the shaft in baking soda (2 tbs/pt) solution overnight.
Thanks for all your hard work, and also for documenting your work.
I am very interested in XC, maybe we shall meet someday.
Doug Wallace, Kelowna, Canada
rrcdoug is offline Find More Posts by rrcdoug
rrcdoug is offline
rrcdoug's Avatar
Canada, BC, Kelowna
Joined Aug 2010
sorry for duplicate post
Old Mar 16, 2012, 02:59 AM
Bernd Brunner is online now
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
Greg,
do you know these articels:
http://scherrer.pagesperso-orange.fr...el%20flies.pdf
http://scherrer.pagesperso-orange.fr...late_OSTIV.pdf
I think it can help you in the developement of #11. Great job!
Bernd
Bernd Brunner is online now Find More Posts by Bernd Brunner
Old Mar 16, 2012, 02:09 PM
Master of the Wind
Joined Sep 2008
I did clean the RDS well in water after I made them. Hope all the acid came off. Baking soda is a good idea. I should check them after sitting this winter.
I did read those articles a while back. Very interesting. For now #10 will have to do until somebody goes faster than me. Season starts in about a week, weather permitting.
Old Mar 16, 2012, 03:37 PM
markdrela is offline
Find More Posts by markdrela
Cambridge, MA USA
Joined May 2001
I use this SS soldering method to completely eliminate corrosion risk:
First, clean all the SS components, and tin with solder using acid flux. This includes the inside of the SS tubes. Then clean off the parts completely, first using baking soda in water, and then some sort of solvent like acetone. Then assemble/solder the components using rosin flux.
Because the SS tube is tinned inside, and the wiper is tinned outside, you have to heat them while putting the wiper into the tube. But this is a not difficult if you have a big soldering iron.
markdrela is offline Find More Posts by markdrela
Old Mar 31, 2012, 01:37 AM
dare to thermal
Mannheim, Germany
Joined May 2004
Greg, how do you have calculated the horizontal tail (size, AR,..)?
Bernd
Old Mar 31, 2012, 01:01 PM
Master of the Wind
Joined Sep 2008
Bernd,
I was fortunate enough to get the design as a package from Philip Kolb. The design is proprietary but I can say that the tail volume coefficient is .43.
That is a good number to start with for a T tail. I would stick with .42-.45. You can make a plane fly with a smaller stab but it may have problems on the launch.
The best reference for design is the Supra plans, both for aero and structure. Also you can take any of the popular J planes and use the fuse/tail proportions as long as you like the handling. The next step would be to use XFLR5 but I am not sure there is a lot to be gained in this area for the effort.
http://www.charlesriverrc.org/articles/supra/supra.htm
Good luck,
Greg
Discussion XC racer #8 in a series G Norsworthy Cross Country Soaring 186 May 15, 2015 11:37 AM
Discussion XC#9 in a series, Giant Supra and other possible wings G Norsworthy Cross Country Soaring 96 Apr 23, 2011 07:14 PM
Discussion Getting Started in XC - Planes, tips, advice aeajr Cross Country Soaring 42 Sep 02, 2010 06:45 AM
Discussion Giant RC DC-10 Turbine Powered Crash trev0006 Fuel Plane Talk 2 May 01, 2010 07:42 PM
FS: Giant WOODIE. Saggitta XC ronrange Aircraft - Sailplanes (FS/W) 5 May 17, 2005 12:17 PM
