Old Dec 04, 2010, 04:56 PM
bob2fly is offline
Find More Posts by bob2fly
Wisconsin
Joined Jan 2007
Need help on how to connect an AR6400 for brushed.2S motor
Back in August there were several posts related to using 2S power on a brushless ESC all driven by an AR6400.
Does anyone have any recommendations on what brushed esc can be used with a 2S power source to power a brushed 8 volt motor?
I have an old unused brushed esc (ElectriFly C-12 Micro ESC 2-3 LiPo), but its output voltage reads 5 volts on my meter, and the AR6400 only wants 4 volts.
And I do not need to use that esc and another would be acceptable.
Also a schematic would be appreciated.
Thank you for your ideas and assistance.
Bob
bob2fly is offline Find More Posts by bob2fly
Old Dec 04, 2010, 07:39 PM
Prime_8 is offline
Find More Posts by Prime_8
Lawn dart pilot/builder
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
go to radioshack , look for a diode like 1400n or n1400 or n1004 .. some mix of thos LOL
sorry i forget .. LOL
anyhow , if you look it will have a just over 1v ..look for one that can take teh amps you need to draw and has a forward voltage drop of just over 1 V
shoudl be a wee pack of 2 ... now go home power uo your esc , ( only ) ,
put the diode on the RX supply/bec pin (centerpin) . and test the output with your meter .
if you did it rite you shoudl be supplying your ar4600 with 3.5 -3.7 v ? if i remember .
if nothing flip the the diode end for end .
Prime_8 is offline Find More Posts by Prime_8
Old Dec 04, 2010, 09:41 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
I think I bought 1N4003 diodes, the white band on the diode goes toward the 6400.
TODD
I R Irv is offline Find More Posts by I R Irv
Old Dec 04, 2010, 10:31 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
^^^ yeah that's it ..
ieach diode inline dropps voltage ,
i theory you could run a 3s esc & motor with enough diodes. LOL
trick is getting V drop correct is all .
the ESC wil LVC on it's own so it sorts itself.
was thinking of trying to make UM p47D , to hold a 5g HK brushless in direct drive using a plush ESC ,
just need some spare UM guts. LOL
Old Dec 04, 2010, 10:47 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Here's a 2S brushed Brick schematic for the AR6400
UNGN is offline Find More Posts by UNGN
Old Dec 04, 2010, 10:51 PM
PiperCub49 is offline
Find More Posts by PiperCub49
Playing with AutoCAD!
PiperCub49's Avatar
United States, ME
Joined Oct 2008
I actually need to get a 3S setup. Does anyone know what diode(s) I would need?
PC49
PiperCub49 is offline Find More Posts by PiperCub49
Old Dec 04, 2010, 10:55 PM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
PC49
The same. Battery voltage doesn't really matter. Its the BEC voltage that is being reduced by the diode. You could use a 10S ESC if the BEC voltage was 5.0V
Old Dec 04, 2010, 11:25 PM
PiperCub49's Avatar
United States, ME
Joined Oct 2008
Thanks UNGN. So there I have it. 3S/AR6400 combo with the 1N400X diode...so cool.
-PC49
Razors edge 29 is offline
Find More Posts by Razors edge 29
QuAd FaNaTiC
Razors edge 29's Avatar
Canada
Joined Aug 2009
For the 2S set up used with 2 1S batts - you just y off the power lines and add in two 1S connectors correct?
Razors edge 29 is offline Find More Posts by Razors edge 29
Old Dec 04, 2010, 11:41 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
yeah .. but series , as the 2s name implies,
just test V with your meter to be sure you got it ..
i made a 2x mini jst females to 1 Jst (red) , so i don;t have to change speed control .
i'm thinking same , i have some 160mah's still fresh un used so they woudl match up well.
now i need a plush & a new 5g BL , i thinkit will look nice in a p47d cowl .
needs 5 A .. at WOT with a 5x3gws .. but makes ~140g thrust .
my 2 160even at 20c only my a hair over 3A .. lol
so i may order a rhino 2s pack .
Old Dec 05, 2010, 09:38 AM
QuAd FaNaTiC
Canada
Joined Aug 2009
I have ordered a plush and have the AP05 BL so I am hoping to use it on some 2S projects.
Old Dec 05, 2010, 09:27 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
nice .
cant wait to see what you do .
Old Dec 08, 2010, 07:54 PM
bob2fly is offline
Wisconsin
Joined Jan 2007
Another brushed AR6400 question
No more questions..diodes solved my last issue.
I appreciate everyone ideas on getting a brushed ESC and motor to work off of the AR6400.
Everything works perfect as per UNGN's schematic.
Again, thanks to all for your help.
Bob
Old Dec 08, 2010, 08:24 PM
Prime_8 is offline
Prime_8's Avatar
N.L. Canada
Joined Jun 2010
black bec / is actualy your bus gorund , it can / should go to the ground pin on brick where ESC / servo woud go .
basicly , hook up you ESC to the brick with just the red (bec +V high) lead off .
some esc's the ground(black/brown) side of the bec / signal wire is common but not linked to thier main ground in . ( isolated to reduce noise to brick )
Old Mar 29, 2011, 10:07 PM
Matt D. is offline
Find More Posts by Matt D.
Matt D.'s Avatar
Greensboro, NC
Joined Jul 2002
Hey Razor,
I just saw this thread again.
Have you done any more work towards this little plane?
Matt
Matt D. is offline Find More Posts by Matt D.
Discussion How fast do you guys think this thing will go? scolen3 Electric Plane Talk 12 Jun 23, 2010 11:34 AM
Question What other airframe would the guts of a UM P51 work with? Razors edge 29 Parkflyers 18 Jun 01, 2010 07:53 PM
Question Do you think this will work!? dan c Foamies (Scratchbuilt) 37 Oct 20, 2009 06:31 PM
Discussion I think this combo will work with this plane, do you? FlyingLakland Power Systems 8 Dec 01, 2008 10:08 PM
Do you think this will work?????? Foam bashing hehe Dauntae Foamies (Kits) 4 Oct 13, 2001 08:07 PM
