This thread is privately moderated by MikeMayberry, who may elect to delete unwanted replies.
Old Nov 24, 2011, 10:03 PM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Here is my Tanga F3B set up. Software 1.08.1
Special Notes:
Since the Flap/B-fly menu still sucks I figured out following work around;
Chanel set up:
Flap Chanel= Null
Falp 2 Chanel= Null
Aux 1= J3 (throttle stick)
Flap Con:
Flap: 100%/100%
Flap2 :100%/100%
Switch: Null
Adjust Funtion:
Switch: LT
Rate: 100% (then hit LT until the Flap servos are 100% offset )
At this point you get +-100% flap travel but max Servo throw is +-150% and you miss out on a considerable amount of throw.
To move the Servo in the lower part to 150% (max travel) do following:
P. Mix 1 Aux 1->Flap
P. Mix 2 Aux 1->Flap 2
Then move the throttle stick down and add servo travel by increasing the mix value. (make sure your T-Stop and EPA are set to max)
I did it this way because I like the Offset function in the B-fly menu but I needed max throw.
I used a flight condition on Launch instead of the Launch Menu because flight conditions can be assigned a priority and the Camber Mix and Aileron Dif and V-tail menus can be used to adjust the rates in accordance with the flight conditions. That's why I don't have D/R set up just expo.
Anything else is pretty standard.
fcbflyer is offline Find More Posts by fcbflyer
Old Dec 16, 2011, 01:28 AM
harleyfrog2000 is offline
Find More Posts by harleyfrog2000
Joined Dec 2011
Ultra Stick 40
Would you please tell me how you set the aurora 9 for an ultra stick (glow)? I want crow mix and also ailerons and flaps to work together as ailerons. Thank you. Rick S.
harleyfrog2000 is offline Find More Posts by harleyfrog2000
Old Dec 16, 2011, 03:36 PM
Dan.Cummins is online now
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
Butterfly for crow, aileron-flap for mixing the aileron and flap control surfaces.
DC
Dan.Cummins is online now Find More Posts by Dan.Cummins
Old Dec 16, 2011, 04:12 PM
Joined Dec 2011
Ultra Stick 40
Thank you. Rick S.
Old Dec 20, 2011, 09:38 PM
Eddie.C is offline
Find More Posts by Eddie.C
Posse Member
Eddie.C's Avatar
Joined Jun 2009
Special Notes:
Chanel set up:
Flap Chanel= Null
Falp 2 Chanel= Null
Flap Con:
Flap: 100%/100%
Flap2 :100%/100%
Switch: Null
Adjust Funtion:
Switch: LT
Oh Boy!
Eddie.C is offline Find More Posts by Eddie.C
Old Feb 19, 2012, 04:13 PM
Ashley123 is offline
Find More Posts by Ashley123
United Kingdom, England, Hemel Hempstead
Joined Mar 2009
RCRCM Typhoon 2m setup file request
Anyone have a setup file for the typhoon 2m
Thanks in advance
Ashley
Ashley123 is offline Find More Posts by Ashley123
Old Mar 12, 2012, 09:22 PM
frankswd is offline
Find More Posts by frankswd
frankswd's Avatar
United States, OR, Eugene
Joined Sep 2002
Anyone programmed a glider with 6 servo wing Aleron, Mid flap, Flap and tow release and willing to share This is for my scale Lunak.
frankswd is offline Find More Posts by frankswd
Old Mar 23, 2012, 09:29 PM
Fidelity101 is offline
Find More Posts by Fidelity101
Go fast, pull up.
Fidelity101's Avatar
United States, NY, Clarence Center
Joined Nov 2008
Is there a place where all of these files can be shared? I'm looking for a Scimitar configuration and a configuration for the Hobby Lobby Su-34 with twin thrust vectoring.
Fidelity101 is offline Find More Posts by Fidelity101
Old Mar 23, 2012, 10:43 PM
LowWatts is offline
Find More Posts by LowWatts
Seattle, WA
Joined Mar 2006
This is the place where setup files for the Aurora 9 are shared.
LowWatts is offline Find More Posts by LowWatts
Old Mar 24, 2012, 02:08 AM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
From FAQ page:
Aurora 9 - Model Set Up & Templates Program (Model) Templates.
(Download existing Set Ups and transfer to your Aurora. Upload & share your own set ups/solutions.)
Templates loaded to above are then indexed under post #40 this thread:
Aurora 9 - Template Index: Acro, Glider, Helicopter, Rock Crawler, Tanks, Simulator.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Mar 28, 2012, 11:57 PM
firehawkzach is offline
Find More Posts by firehawkzach
firehawkzach's Avatar
United States, TX, Fort Worth
Joined Jan 2011
I would be interested to see if anyone has a set up for a thrust vectoring, flaps, retract, rudders set up. I am using an optima 9 channel on this F-18. I don't care about airbrakes but it might be cool. I will have TV on a switch. I will post my set up when I get it done, still in the final stages of the build.
firehawkzach is offline Find More Posts by firehawkzach
Old Mar 29, 2012, 02:43 PM
Go fast, pull up.
Joined Nov 2008
I setup the scimitar using an optima 7 and it was a PITA compared to my spektrum dx7...but I think the end result will be better. I used elevator to aileron mixing after setting the model up as a delta wing and it was difficult trimming throws for low and high rates as the mechanical linkage was not perfectly aligned.
Old May 05, 2012, 04:36 AM
usmc5811 is offline
Find More Posts by usmc5811
usmc5811's Avatar
United States, CA, Murrieta
Joined Apr 2012
Did not know this thread existed. Anyone have a Gaui 500x setup for the Aurora 9?
usmc5811 is offline Find More Posts by usmc5811
Old May 05, 2012, 05:35 AM
Go fast, pull up.
Joined Nov 2008
Are you using the gu344 or the Naza? It makes a difference in terms of EPA and what not. I have a setup using the Naza and I have switch f to go from ATTI mode to manual mode.
Old May 05, 2012, 05:51 AM
usmc5811 is offline
usmc5811's Avatar
Joined Apr 2012
Right should have mentioned that - I have the GU-344.
I can't get the quad off the ground without it tilting towards the #2 - #3 blades. So I reversed the facing of the GU-344 and the quad still tilts towards the #2 - #3 blades. I thought #1 - #4 blades were supposed to be the front.
And I need to know how this GU-344 works. I know it stabilizes, but is it automagical or do I need to invoke something.
Anyways if anyone can give me some pointers using this setup with the Aurora 9 that would be great.
Discussion Who has good cheap VPP set ups? epoweredrc Indoor Pattern/F3P 22 May 15, 2010 08:56 PM
Discussion Succsesful Power 160 Set-ups? tlh101 Power Systems 1 Apr 07, 2010 11:41 PM
Discussion 4g3 issues brushless set-ups. user0125 Micro Helis 8 Mar 17, 2010 12:59 AM
Sold Parkzone 2.4 Set ups x 2!!! DbleX Aircraft - General - Radio Equipment (FS/W) 2 Oct 14, 2009 01:36 PM
Discussion Power Set Ups - A tool for the Beginner GeorgeG97322 Scale Kit/Scratch Built 7 Sep 26, 2009 12:53 PM
