Old Apr 20, 2011, 06:44 PM
LowWatts is offline
Find More Posts by LowWatts
Seattle, WA
Joined Mar 2006
No Flaps Flight Condition
Flight Conditions =
Normal
Launch
Reflex
No Flaps
No Flaps takes priority, but this could be changed.
Positive camber on Left Slider, (LS).
No Flaps is on SW "D".
Normal, Launch & Reflex on SW "E".
Aileron to Flap coupling on SW "G" applicable to all Flight Conditions except No Flaps.
LowWatts is offline Find More Posts by LowWatts
Old Jul 08, 2011, 04:17 PM
Alan C is offline
Find More Posts by Alan C
are we there yet?
Alan C's Avatar
USA, AZ, Surprise
Joined May 2004
Xp-3
Here is the program I use for my XP-3 DLG.
Flight Conditions:
Launch
Normal
Cruise
Thermal
flight modes are on switch E.
I have moved the momentary switch from the right to the left, by un soldering and resoldering them.
I have the flaps on the left stick. For the most part I only use Launch and Normal flight conditions. I use the flap stick to add camber. I have found that doing this I can adjust the camber as needed.
Alan C is offline Find More Posts by Alan C
Old Jul 13, 2011, 01:54 PM
xiamardle is offline
Find More Posts by xiamardle
Grand Duchy of Luxembourg
Joined Nov 2004
Originally Posted by nahum View Post
When updating from V1.07 to V1.08 the cularis program was completely unusable.
It was much easier to start a new program from scratch.
So here it is
5 flight modes controlled by C and E.
Motor controlled by J3 in all Flight modes except Landing.
In landing mode: Motor off, butterfly controlled by J3.
Camber controlled by Lt with adjustment from CT (can be fine tuned separately in every flight mode)
Enjoy
Nahum
Hi Nahum,
I have downloaded your template.
But I don't understand how in LANDING mode the motor is turned off and Butterfly is linked to J3 ?
I see only one mix in your setup but I really don't understand what is it for :
AUX3->AUX1
with LANDING 0% and ALL OTHER CONDITIONS 100%
So in such a mix "AUX3->AUX1" , AUX3 (J3/THROTTLE) is the "master" and in all conditions except for LANDING, if the throttle is moved, AUX1 is moved of the same amount.
But AUX1 is NULL ....
Thanks for your help,
Eric http://www.dramaix.com
Regards
xiamardle is offline Find More Posts by xiamardle
Old Jul 14, 2011, 03:01 AM
squigg is offline
Find More Posts by squigg
What goes around comes around.
squigg's Avatar
Joined May 2011
Anyone have a setup guide for a multi copter, trying to set up a hexakopter with the Aurora9, not sure whats what, have had the new Aurora in my hand for a few days now but its still all new to me.
squigg is offline Find More Posts by squigg
Old Aug 20, 2011, 05:50 PM
oliver1071 is offline
Find More Posts by oliver1071
Joined Jul 2011
Trex 250, 450 Pro, 550e 3GX profiles.
Here you go my 250SE-3GX, 450 Pro 3G, 550e-3GX Aurora 9 Profiles.
All of them still have 40% Expo since I was just learning and they're all FBL so they're fast enough at 40%.
oliver1071 is offline Find More Posts by oliver1071
Old Aug 23, 2011, 01:15 AM
TTRotary is online now
Find More Posts by TTRotary
Rangers Lead the Way
Joined Mar 2010
Anyone have a basic TRex 450 (SE V2) setup they can send me so I can understand the swash servo setup, EPA, etc. on the A9, thanks. This is a plain vanilla stock TRex with HS65s on the cyclic, Futaba tail servo, and GY401. I understand the part about neg. expo vs the Spektrum way. I cannot download any of these pgm files in here, so if I can get this in plain english, that would be great, thanks. Again, this is basic stuff: what servo goes to what channel, which need to be reversed, etc., and any quirks this radio may have with the gyro, vs the DX-7. Right now, I am learning hover - I'm a loooong time away from idle-up / 3D at this point.
Also, in terms of response, I noticed with my planes that the control inputs seem more responsive with the A9 than they were with the DX-7. I had gotten to the point with the TR 450 where I was hovering with almost all expo removed. Should I put some back in initially with the A9?
TTRotary is online now Find More Posts by TTRotary
Old Aug 28, 2011, 12:55 PM
Dirt-Torpedo is offline
Find More Posts by Dirt-Torpedo
...just an earth bound misfit
Dirt-Torpedo's Avatar
Joined Mar 2010
Phoenix Sim setup for 3D/scale (Heli or Plane)
A setup that works for scale and 3d planes and helis in the Phoenix RC flight simulator. The setup is a superset of my crusty old DX6i, so I can use either TX on Phoenix.
Ch1 THRO, Ch2 AILE, Ch3 ELEV, Ch4 RUDD, Ch5: GYRO/SMOKE, Ch6: PITC, Ch7: AUX1(GEAR), Ch8 AUX2(FLAPS)
Controls are as follows:
LS - Flaps
SW(A) - [0] landing gear down, [1] landing gear up
SW(F) - [0] high rates, [1] low rates
SW(G) - [1] COND "HOLD" - throttle cut for autorotations
SW(E) - [0] COND "Normal" - linear throttle curve, no smoke & rate mode gyro
......... - [1] COND "SMOKE/HH" - linear throttle curve, smoke & heading hold gyro
......... - [2] COND "IDLE UP" - flat throttle curve, heading hold & smoke
Dirt-Torpedo is offline Find More Posts by Dirt-Torpedo
Last edited by Dirt-Torpedo; Aug 28, 2011 at 05:51 PM. Reason: Forgot to mention flaps...
Old Aug 28, 2011, 03:09 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Tks, added:
Aurora - Simulator function Set-up
Alan T.
A.T. is offline Find More Posts by A.T.
Old Sep 10, 2011, 05:15 PM
mfpage is offline
Find More Posts by mfpage
NORDPAC S3
mfpage's Avatar
United States, OR, Estacada
Joined Jan 2009
Below are two Hitec Aurora 9 "Set" files for Heng Long & Tamiya IR 1/16 scale RC tank
The attached file for a Hitec Aurora 9 "Set" file which enables your Tamiya Tank to perform from your A9 Transmitter.
Set A9 on MODE 2
Right Stick:
Up = tank forward
Down = tank reverse
Right = tank right turn
Left = tank left turn
Left Stick:
Right = turret traverse right
Left = turret traverse left
Half way up = cannon elevates up
Half way down = cannon lowered
All the way up = cannon fires
All the way down = machine gun fire
The attached file for a Hitec Aurora 9 "Set" file which enables your Heng Long Tank to perform from your A9 Transmitter.
Set File for Infrared Heng Long Tanks modified by www.rctankwars.com
Set A9 on MODE 2
Right Stick:
Up STARTS the Motor
Up = tank forward
Down = tank reverse
Left Stick:
Up = cannon fire IR
Half way down = machine gun file
All the way down = cannon elevation/depression
mfpage is offline Find More Posts by mfpage
Last edited by mfpage; Sep 21, 2011 at 01:41 AM. Reason: correction on left stick controls
Old Sep 10, 2011, 08:58 PM
A.T. is offline
Joined Aug 2002
AURORA 9 - TEMPLATES Index.
. Links are to the post containing relevant zip file, read pertinet notes before downloading.
. Requires use of Hitec HPP-22 2.4GHz Programmer to Download/Upload files.
extract ".Data Transfer to From PC or Laptop - Internet Connection Is Not Required.- Pictorial Instructions."
. Some files set mode 1<>2 may need tweeks to suit your mode.
Aircraft (Acro)
Fun Cub EP (MPX)
Stryker F29Q with Dual Rudder Airbrakes (Proportional & On/Off).
Also suitable for the MPX Twinjet, MPX Funjet, SkyArtec/HK Funjet and other Delta or Flying Wing.
GLIDER (SAILPLANE)
Glider - Typical Set Up., no Flaps Flight Conditions
Sailplane and Motorised (EP) Sailplane Typical Set Up.
Bingo
Calypso (EP with 4servo wing)
Cularis - MPX - EP Fullhouse Glider
Enigma Hotliner
HyperDX 2.2. 4 Servo wing, X tail glider.
F3F Sailplane
F3J/TD Open Class Sailplane Stratos setups
Ibis-ET 3m Glider ( Art Hobby)
MIBO e-Wasp EP Mini Hotliner.
Omega 2.5 w/flaps
Pace DSH & F4
Pike Perfect - Standard tail with Launch, Crow, and the camb/reflex settings on a switch.
Radian Pro (Parkzone)
Radian Pro - 4 Servo wing, servos rejigged for max throws.
SpeedFire F5B - 4 Servo wing V tail F5B hotliner.
Spirit Elite (Great Planes)
TM Cz Stilleto - EP Speed 400 Racer.
Tanga F3B - especially designed for the competition flying.
Vento - V-tail with Crow and camb/reflex setting on the slider
VooDoo F5D-400 - EP Speed 400 Pylon.
GLIDER (DLG)
2013-F3K
XP-3 DLG
HELICOPTER:
Dynam E-Razor CF Edition 450
Mini Titan V1
Trex 450 Sport
Trex 250, 450 Pro, 550e-3GX profiles.
RC Rock Crawler
Rock Crawler programming, Reverse and 4WS (Thread, still await a zip file)
RC TANKS
Heng Long (modified by www.rctankwars.com)
Kanoh's Model Sailplane Workshop
. Aurora 9X - Kanoh's Model Sailplane Workshop
Whilst not zip type templates, refer to attached photos for model types.
. Aurora 9- Kanoh's Model Sailplane Workshop
Again whilst not zip type templates, refer to attached photos for model types
including those without drawings in box below.
That page also has good review and layout of the A9 transmitter.
SIMULATOR
This index, linked to FAQ page, will be regularly updated.
Aurora 9, AFHSS Spectra Modules, Optima Transceivers & Telemetry
- FAQ & Undocumented Features
- Mixes, Setups, Tips. {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Old Sep 22, 2011, 12:37 AM
Ian Downunder is offline
Find More Posts by Ian Downunder
Ian Downunder
Ian Downunder's Avatar
Bass
Joined Aug 2008
Hi. Got a link to come to this thread. Hope you can help.
I have just bought an Aurora 9 with its 'user friendly' 131 pages of instructions. I fly Mode 1.
I note that despite it coming set as Mode 1, the tranny is set up as:
Ch1 Aileron J1
Ch2 Elevator J3 (not J2 as you would expect)
Ch3 Throttle J2 (not J3 as you would expect)
Ch4 Rudder J4
I figure the radios are all set to Mode 2 in the gimble region only for programming purposes. I hasten to add, everything works correctly in Mode 1 as the radio came set up.
My Problem: I want to keep my flaps on the throttle stick as was done on my previous radio but I also want to use the 3-way switch 'C' to be able to have Aileron/Flap camber. i.e. on - up camber, middle - off, on - down camber.
Let's just work on the Aileron/Flap Camber procedure first. To do this, firstly I worked out that I had to use 6 channels otherwise the Aileron/Flap feature would not show up on the menu.
As I have it now the channels are set to.
1 Aileron
2 Elevator
3 Flaps
4 Rudder
5 Aileron2
6 Flap2
Digressing slightly, I wonder what is the difference between Flap and Flap2 and the like?
Anyway I did all this (and with one flap reversed) but only the flaps work (not the ailerons as well) and I can't change the + and - on the graph to alter the degrees of camber I require.
If anyone can sort out this feature I will be forever grateful.
Also, can I still have the flaps manually operated on the throttle stick as well as having Aileron/Flap Camber on the 3 position switch 'C'?
I have my slope soarer set on ACRO as opposed to GLID. Is this correct?
Perhaps I am asking too much but I bought this radio because I was told you can do just about anything on any switch.
By the way, I can't open the zip files here either. Can you please send any info via PDF, JPEG or WORD?
Ian.
Ian Downunder is offline Find More Posts by Ian Downunder
Old Oct 15, 2011, 08:38 PM
amanoussakis is offline
Find More Posts by amanoussakis
Joined Oct 2011
Help With Mini Titan setup With Aurora 9
Hi all
Here is my setup file for the Mini Titan V1 with all stock ACE Radio gear and Trex 600E Pro EFL
Cheers
amanoussakis is offline Find More Posts by amanoussakis
Old Nov 10, 2011, 04:00 PM
Hogwash is offline
Find More Posts by Hogwash
Devon UK
Are there no wizz kids on here who could write a PC app to display and edit these .set files?
I am surprised hitec have not done it as a cool looking PC program would help sell thier gear.
Hogwash is offline Find More Posts by Hogwash
Old Nov 11, 2011, 07:57 PM
Hugh P is offline
Find More Posts by Hugh P
Quincy IL
Joined Jul 2006
I am thinking about it. Something like what I wrote for the 4 button 4 function chargers with a USB port.
Going to take some access to Aurora design details (not likely but we can wish) or lots of making single changes to a setup and then downloading the set and comparing data to develop a road map. Once done it should not be hard to develop the code.
Hugh P is offline Find More Posts by Hugh P
Discussion Who has good cheap VPP set ups? epoweredrc Indoor Pattern/F3P 22 May 15, 2010 08:56 PM
Discussion Succsesful Power 160 Set-ups? tlh101 Power Systems 1 Apr 07, 2010 11:41 PM
Discussion 4g3 issues brushless set-ups. user0125 Micro Helis 8 Mar 17, 2010 12:59 AM
Sold Parkzone 2.4 Set ups x 2!!! DbleX Aircraft - General - Radio Equipment (FS/W) 2 Oct 14, 2009 01:36 PM
Discussion Power Set Ups - A tool for the Beginner GeorgeG97322 Scale Kit/Scratch Built 7 Sep 26, 2009 12:53 PM
