Old Feb 05, 2013, 12:40 PM
nbrophy is offline
Find More Posts by nbrophy
Joined Sep 2001
A.I. Pietsukh’s PAI-67
The A.I. Pietsukh’s PAI-67 is interesting and unusual configuration.
If you the look at the drawings (assuming they are accurate) the fore wing appears have less angle of incidence than both the main wing and rear horizontal stabilizer. Both of which appear to have the same angle of incidence. This goes against my understanding that a stable tandem wig configuration where the fore wing should be the higher loaded wing.
The rear horizontal stabilizer is set much lower than most ram wing and lippisch reverse delta wigs...but the elevator is huge. I wonder whether the horizontal stability was controlled by the trim of front water prop drive and/or hydrofoil.
The main aft wing planform also very interesting. It could almost be considered a Double Delta Wing Bixel with anhedral.
nbrophy is offline Find More Posts by nbrophy
Old Feb 05, 2013, 02:36 PM
qxev is offline
Find More Posts by qxev
Joined Dec 2011
Originally Posted by nbrophy View Post
If you are interest in the joined wing, I know there was some early posts on the Yahoo Wig group concerning utilizing joined wing configuration in ground effect.
me interests box-wing in combination with it wing-in-ground
various options, like it
http://www.architectswanderlust.com/...stol-aircraft/
qxev is offline Find More Posts by qxev
Old Feb 08, 2013, 04:59 PM
qxev is offline
Joined Dec 2011
Old Feb 09, 2013, 11:20 PM
captarmour is offline
Find More Posts by captarmour
Joined Mar 2011
qxev, I thought Holden at homebuilt airplanes.com, Paul Weston Sea-Era thread told you the craft in these exact pictures you posted would not work IGE. He seems pretty qualified to know what he is talking about.
He mentioned the AC remains close to the Center of Area on the delta whereas rectangular or square wings AC moves back from 25% to 50% (center of area) IGE causing a negative pitching moment.
captarmour is offline Find More Posts by captarmour
Old Feb 14, 2013, 02:01 PM
qxev is offline
Joined Dec 2011
http://www.sunny-boxwing.de/Greenwings.html
http://www.patent-de.com/19860710/DE3500575A1.html
http://www.sunny-boxwing.de/wigwings.htm
conclusions by results of calculations.
this configuration showed high stability at good controllability
Old Feb 17, 2013, 04:37 PM
Joined Mar 2011
I tried something similar it only worked with flat airfoils, with camber and drooped LE, like slats it flies like an airplane, would not remain IGE.
Old Feb 17, 2013, 04:39 PM
Joined Mar 2011
VID 00009 20110607 1859 (0 min 21 sec)
Old Mar 25, 2013, 07:39 AM
nbrophy is offline
Joined Sep 2001
Delta-2 Lippisch-type ground effect glider
Gabriel,
I was watching your video of your “Delta-2 Lippisch-type ground effect glider" you posted last year in the thread. It appears really stable. Does your glider have flat or cambered airfoil? What is angle of incidence of the reverse delta main wing? What was the weight?
Old Mar 25, 2013, 06:33 PM
RdsG is offline
Find More Posts by RdsG
RdsG's Avatar
Hungary
Joined Jul 2009
Gabriel,
I've made plans today : https://www.dropbox.com/s/bac9nv7eie...sG_A4print.pdf
RdsG is offline Find More Posts by RdsG
Old Mar 25, 2013, 09:08 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
P
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Apr 01, 2013, 01:27 PM
qxev is offline
Joined Dec 2011
Airplane+wing in ground (5 min 6 sec)
Old Apr 03, 2013, 11:44 AM
Joined Mar 2011
http://m.youtube.com/#/watch?feature=plcp&v=mLAzm3sKVU8
Tried my delta canard IGE, but as you can see she doesn't want to stay low.
Old Apr 07, 2013, 08:03 AM
Pedrc is online now
Find More Posts by Pedrc
Pedrc's Avatar
Česká republika, Ústecký, Lipová
Joined Jul 2011
Hello, I think, it behaves very well
Pedrc is online now Find More Posts by Pedrc
Old Apr 10, 2013, 10:41 PM
Joined Mar 2011
thanks, how do u like these?
Low flying (2 min 26 sec)
Old Apr 10, 2013, 10:42 PM
Joined Mar 2011
oops
55 degrees (7 min 40 sec)
Yippee! On Topic - Cool General Aviation Stuff To Share szastoupil Valley Aero Modelers 164 May 09, 2016 08:36 PM
Cool Lun/Spasatel Ekranoplan build *IT FLIES! with photo's! hoverman RC Hovercraft 51 Jan 19, 2011 11:41 AM
Discussion "KASPIJSKI MONSTRUM" - PROJEKT KM (Ekranoplan) Petrovic Racing Boats - Electric 3 Jun 08, 2010 07:44 AM
