Old Aug 28, 2012, 01:02 AM
Pedrc is offline
Find More Posts by Pedrc
Pedrc's Avatar
Česká republika, Ústecký, Lipová
Joined Jul 2011
Originally Posted by sfluck View Post
short question in between: did the a90 orlyonok have wheels for movement on concrete? I guess so!? Does anyone have a pic or something?
Hello.
I think yes. My Pictures aren´t good.
Pedrc is offline Find More Posts by Pedrc
Old Aug 28, 2012, 06:55 AM
sfluck is offline
Find More Posts by sfluck
Winterthur ZH, Switzerland
Joined Mar 2009
thanks for the pics! I stumbled over a pic just now:
sfluck is offline Find More Posts by sfluck
Old Aug 28, 2012, 01:27 PM
Pedrc is offline
Pedrc's Avatar
Joined Jul 2011
Interesting!
Too bad, that my Orljonok is for this too small
Old Aug 30, 2012, 12:52 PM
captarmour is offline
Find More Posts by captarmour
Joined Mar 2011
http://www.youtube.com/watch?v=m4NYiI0otz8&feature=plcp
GE run hands off (0 min 15 sec)
hope you can see them.
captarmour is offline Find More Posts by captarmour
Old Sep 07, 2012, 07:30 PM
Joined Mar 2011
Originally Posted by RdsG View Post
Yes, I tried. It doesn't like sharp turns :P When it banks in a bigger angle it loses its air cushion and touches the ground with one wingtip. But smaller angle banking isn't a problem.
Yes, plans would be great. However I couldn't built it soon. I don't have a foam cutter and I can't find bigger foam blocks :/ At the same time it would be a big help designing my further models since it would be the first plan of a RC WIG I have ever seen on the Internet (and elsewhere).
Gabriel
ps: I uploaded the last video to youtube because it loads faster.
http://www.youtube.com/watch?v=SU_XcpDBeSY
The best about this Lippisch desing is its efficiency. In the first "part" of the video the battery was empty (the ESC cut off setting was very low). GM2 Bixel always needed at least 70-80% thrust.
Gabriel
I know this is old but I sometimes go back and compare what we know now with what we knew before.
I was just wondering just as sailors say the 'length of the luff" is where all the performance comes from.
Could it be the wider wingspan is what made your Lippisch more efficient than your bixel?
Did they fly easily OGE? Or were they a 'handful'...difficult to fly?
My quest is a design that when trimmed for IGE, is 'nose heavy' OGE!
Rgds
Old Sep 30, 2012, 04:57 PM
Joined Mar 2011
It's a shame that our forum is dying...I guess that's life
Old Sep 30, 2012, 05:01 PM
Joined Mar 2011
Originally Posted by Pedrc View Post
Hello.
Is it the shadow? Or are the LEs very sharp? I would think it would need nice fat round leading edges.
Old Oct 01, 2012, 02:48 AM
Sirglider is offline
Find More Posts by Sirglider
Joined Sep 2011
Ekranoplan ready for take-off
Hi all!
No captarmour, subject is not dying I'm watching it every day trying to find some answers for our project.
But today I'm very proud to show it to you. Our model is about 550mm wingspan (with tips) and weights 1140g.
The first test session was very interesting and showed that our two EDF were not correctly aligned with our CG and push too much downward. The result is that the Ekranoplan lifts its nose over the water but the tail drags a lot into the water. Videos were of very bad quality but I'll post some from the next session (hopefully tomorrow) I'm very excited with it as it took us about 2 months to design it and an other 5 months to build it.
Comments are very welcomed.
Cheers
Sirglider is offline Find More Posts by Sirglider
Old Oct 01, 2012, 03:49 AM
camoesas is offline
Find More Posts by camoesas
camoesas's Avatar
Portugal/Ovar/Válega
Joined Mar 2007
Hello and congratulations.
It looks nice but, please dont take me wrong, Take in consideration changing the wing profile, it looks like a circle segment and, this is not the better way of providing lift.
Try to change the wing profile and use a simple and proved design such as the old "Clark Y".
The cg should be around 30-40% from the front of the wing.
Best regards,
Carlos
http://www.ovarcraft.com
camoesas is offline Find More Posts by camoesas
Old Oct 01, 2012, 03:53 AM
Joined Sep 2011
No worry camoesas, we've done a few simulations as well with that profile and it should bring us enough lift at pretty low airspeed with good GE. We'll make some more tests before building a second wing
Thanks for your comment
Old Oct 02, 2012, 11:00 AM
qxev is offline
Find More Posts by qxev
Joined Dec 2011
Originally Posted by captarmour View Post
Nice, what's this?
BWIG Box Wing In Ground (2 min 48 sec)
qxev is offline Find More Posts by qxev
Old Oct 02, 2012, 12:43 PM
sfluck is offline
Joined Mar 2009
I am too looking in here every day and hoping for some news .
Has anyone ever tried the Gurney Flap on a ground effect model? That seems like a very handy easy modification that could help producing even more lift and achieving higher flying altitudes (opposed to that: additional drag).
Found a paper about it: http://soar.wichita.edu/dspace/bitst...pdf?sequence=1
CL is definitely higher with a gurney flap than without.
brgds
Stefan
Old Oct 03, 2012, 02:45 AM
Joined Sep 2011
First test sessions
Here we go! Finally we could run our first tests yesterday.
First run 02.10.12 (3 min 8 sec)
After that first run, we changed a little bit the angle of attack of the engines and the result is better.
Second run 02.10.12 (5 min 5 sec)
Now a few more improvements before we'll put full throttle:
  • Move the CG a little more backward
  • Seal the middle cover. We finished with 5mm water inside the fuselage...
  • Raise a little bit the engines to avoid water to go through
  • Make a bigger elevator as at low speed it's not efficient at all
Now one issue you guys might help us with: Do you think our fuselage is too much "stuck" on the water, especially in the back? Should we make bigger cut-off to help the air to release the water under it?
Old Oct 03, 2012, 04:52 AM
Joined Mar 2011
On page 26 some tips on hull design by hoverman.
Remember at less than about 20% chord height above 'ground' the wing produces very little lift. Any lift is from 'ram' effect. That being the case if you remove some of the LE droop you will get more air flowing under the wing and may increase lift for take off.
IMHO every flying machine needs to be balanced to fly. We all know that our model planes are barely controllable with cg aft of 30% Mac. If we can somehow design the WIG to work balanced as an aircraft we will be very happy. Look at pg 24.
Longtitudinal stability requires that the forward wing has more incidence so as to achieve a higher aoa than the following wing.
Keep up the hard work, you have a gr8 model!
Old Oct 03, 2012, 05:01 AM
Joined Mar 2011
Would be nice to get some feedback on the videos in post 1069.
The model actually gets nose heavy OGE, therefore more stable.
Yippee! On Topic - Cool General Aviation Stuff To Share szastoupil Valley Aero Modelers 167 Jul 21, 2016 07:44 PM
Cool Lun/Spasatel Ekranoplan build *IT FLIES! with photo's! hoverman RC Hovercraft 51 Jan 19, 2011 11:41 AM
Discussion "KASPIJSKI MONSTRUM" - PROJEKT KM (Ekranoplan) Petrovic Racing Boats - Electric 3 Jun 08, 2010 07:44 AM
