Old Jun 05, 2010, 04:29 AM
RdsG is offline
Find More Posts by RdsG
RdsG's Avatar
Hungary
Joined Jul 2009
General Ekranoplan Topic
Almost ready to fly. It's green, and ugly, but I hope it will fly (in ground effect).
First test flight will be in two weeks or so.
"Green monster" rc ekranoplan 1 (0 min 28 sec)
RdsG is offline Find More Posts by RdsG
Old Jun 07, 2010, 09:35 PM
metroidrc is offline
Find More Posts by metroidrc
Micro EDF addict
metroidrc's Avatar
Upstate NY
Joined Jun 2007
looking forward to the video!
metroidrc is offline Find More Posts by metroidrc
Old Jun 08, 2010, 07:41 AM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Here's another take on WIGs you might be interested in.
http://www.twitt.org/Bixel_WIG.html
DT56 is offline Find More Posts by DT56
Old Jun 08, 2010, 06:26 PM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
Thanks!
I've read this article. Green M. also have a flat wing profile, I hope it will work. I chose this, because it's simple, and it has almost the same flight characteristics in and out of ground effect. So jumps should be a problem (in theory).
Old Jun 13, 2010, 03:32 PM
hoverman is offline
Find More Posts by hoverman
hoverman's Avatar
Netherlands
Joined Sep 2006
Hey Rdsg,
any progress yet?
Inspired by the Bixel story, which was posted above, I decided to build a small model, using this principle. I looked up the patents of Mister Bixel, which contained some further information on his design.
So.. it has to be a flat plate(or a fairly thin symmetrical profile). The Aspect Ratio on my model is .32 for the large centre wing, the same is for the outer wing panels. Bixel advises the AR to be somewhere between .25 and .50
I also added a stabiliser(Clark Y) ontop of the two vertical fins, which can be hinged to finetrim the model.
I was totally surprised to find that this model won't flip under any circumstance. I shifted the CG for 15 cm's, it just wouldn't flip. Depending on the angle of the stabiliser, it would either pitch down, skipping along the street, or fly totally stabilised in GE for 20 meters, or it would rise out of the GE at 30 degrees, but even in that extreme case, it wouldn't stall and flip backwards, it would just loose speed and after several meters, fall back to the street.
Damn, this Bixel concept works perfectly!
So, I thought it would be nice to compare it to a totally different WIG. Together with some triplex, styrodur and a foamcutter, I build a small Lippisch style Wig.
The wings & the Vertical Stabiliser both have Clark Y profiles, I glued the stabiliser at about 3 degrees positve alpha.
Then, after some testing it needed about 30g to place the CG at approximately 30 - 40% of the Chord. If launched appropriatly it will "skim" the street for up to 20 meters, completely stabilised at 8 cm's above the ground.
If launched too nose up, or simply to hard, it will jump up to half a meter, gradually pitch down and descent directly back to the ground. If this is done too enthousiasticly it actually impacts with the street.
Ofcourse, the Lippisch model is able to fly slower and seems to have better "performance", probably due too it's airfoils. However, on the Lippisch model, it is the same as on all the other ground effect types(even worse on the square ram wing types), they are very sensitive to the way they are trimmed.
The Bixel however..well I just couldn't crash it, without placing the CG at absurd positions
So Finally...I get how the guy's at Du-groundeffect.com (no longer active) managed to get their models so stable! On the pictures of their site I had seen they were all using this sort of Bixel shape, and they allways used thins symmetrical profiles, I just never figured this works so well, just due too the Bixel principle.
So..Looking forward too you're results!
Marijn
The Netherlands
hoverman is offline Find More Posts by hoverman
Old Jun 13, 2010, 06:47 PM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
Hi!
I'm not home since last Tuesday and I won't be back at least for a week...
Before I left I tried to fix the esc with no success.
In the meantime a new ESC arrived. So when I arrive home, I just put in the new esc, and it's ready to fly. (I hope the weather will be good enough)
You make me very curious about this Bixel WIG. Could it be the "ultimate" configuration? I guess we have to find out.
Gabriel
PS: Where is the CG on your flat winged ekranoplans (without air injection)?
Old Jun 14, 2010, 10:46 AM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
The CG of my flat winged models is mostly located between 25 and 50% of the chord, it is totally dependant of the size proportion between the main wing and the stabiliser. Normally when you place the stabiliser at 4 degrees positive alpha, you'll need you're CG at about 30% chord.
Guess you'll just have to test it, carefully
As I was comparing the Lippisch craft too the Bixel model, I thought it would be nice to add another concept, the Tandem.
So a bit of foamcutting and sanding and I came up with this:
The front wing has a very thin, slightly curved airfoil, positioned at 6 degrees alpha.
The rear wing has a slightly thickened Clark Y profile, and is positioned at 4 degrees alpha.
This is pretty much comparable too the Jörg boats, the rear wing is designed to provide less "ground effect" lift, and is therefore less dependant on it's flight altitude.
The CG was placed on the trailing edge of the front wing and eventually was shifted forward for another 3 cm's.
The model behaves as aaaall the Tandem wing models I've ever build or seen, with tandems it is alway's quite easy to get a stable ground effect flight, add enough noseweight and, at a certain speed, it will skim along you're whole street.
It is just that... allthough it will never tend to flip out of itself..(if it's balanced correctly ofcourse ), it only needs about 10-20 degrees pitchup, by hitting a stone in an uneven street for example, and it won't be able to recover, resulting in a backwards flip.
It is like...yes, placing two wings behind each other close to the ground, will give you a very stable flight...just that it's actually quite unforgiving, make an error and it will flip.
It goes withoud saying that I've yet to see a an actual build tandem Wig, that Hás got an elevator. Ofcourse they don't need the elevator to achive stable GE flight, that's the beauty of it, but it also shows that these crafts are in no practical way able to fly out of GE, aslong as they are trimmed for practical GE flight.
I've build I don't know how many of these tandem's, and I never managed to build one which I trust completely.
So....I guess this put's the Bixel on place 1, the Lippisch coming close in on place 2, the Tandem with it's extreme but untrustworthy stability at place 3.
Please comment on this if you managed to build a tandem model which deserves a higher place, and I'm just telling a lot of nonsense.
So, again a lot of writing about a piece of foam
The succes of the Bixel model really draws me to start drawing plans for an RC version.
Marijn
Old Jun 14, 2010, 12:09 PM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
Hi
I also built simple tandem free flight models, and i had the same result.
I thought far placed tandem wings could solve the stability problem in weaker ground effect zone, but i wasn't right. In this video you could see some various model towing with far placed tandem wings. There is a part when they try to lift the model out of ground effect, and the model flips over (~@ 7:00).
I wonder why I can't find more information about the Bixel wig.
There is only that web page, and this photo of a full scale(I guess) craft.
On the other hand I don't really understand the double wing concept of the Bixel wig. In theory Bixel wig's body is a lifting body (it's the second wing). Am i right?
But the body is almost a box. I mean at the "tail" section. So i wonder if I build a bixel wig with this "box-ended" body, could it perform as well as the flat one?
Your flat bixel model is looks like a WIG, and flies like a WIG. The original Bixel concept looks more like a brick with very small wings .
PS:
We talked about plane-type, tandem, Lippisch-type and bixel-type ekranoplans. There is two more type (one and half) I know and I didn't experiment with:
-Reversed Rogallo type. It's is similar to Lippisch just more simple. It use a flexible airfoil like a hang glider. http://www.wuala.com/en/api/preview/...g?mode=gallery
-Box wing.
http://www.youtube.com/watch?v=VJOyDe4J8DQ
I think the last one worth a shot.
Old Jun 14, 2010, 01:31 PM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
I don't quite understand the Bixel wing concept either, the extra pair of wings probably add to the stability of the entire model, on the other side, they have the same angle of attack as the main wing/body.
In the Patent scripts of Bixel, which can be found as a PDF on google, it sais that the smaller rear located wings improve the roll stabilisation of the model. I wonder if they also add to the longitudinal stability?
The drawings of the Large sized Bixel crafts indeed look like flying bricks, still, there is something too these blunt trailing edges, as at least some of the models at Du-groundeffect.com had the same thing.
I'll post some pictures of their models, pitty their site has been offline for a few years, there are still some video's on youtube though:
A free flying Bixel model:
http://www.youtube.com/user/flaircra.../1/HjGFpvvX3fI
The Aircat, also a kinda Bixel model, with a stabiliser:
http://www.youtube.com/user/flaircra.../3/qTfFNZnyuZE
http://www.youtube.com/user/flaircra.../4/MRJzVKR066E
Here are some pictures of the Aircat, their best model, clearly inspired by the Bixel concept!
At first it didn't have a stabiliser:
It is hard to see it on the pictures, but I remember that on one of the pictures of the rear of the craft, the trailing edges of the side wings & of the hull were both blunt.
Later on they added a stabiliser:
They also sold a conversion kit for a airboat, called Wiggy:
It isn't a 100% the Bixel shape, it does have a flat profile though
One of their newer models was called the Drag'n'fly, a Wig which i remember was flying lower than the aircat, resembling Tandem wing performance:
Also..Graham Taylor, designer of the Whizzywig and many other more or less succesfull models, build a Bixel Wig model, just before his site also went offline:
His model failed to take off though.
The latest model that was sold at Du-groundeffect was called the Gemini, it consisted of a flat plate wing, together with two hulls located side by side, with the wing in between. I don't have a picture of it
So.. this is about all I could find about Bixel stuff, I don't think there is very much more to find on the net.
Marijn
Old Jun 14, 2010, 01:38 PM
Gary Mortimer is offline
Find More Posts by Gary Mortimer
Gaftopher
Gary Mortimer's Avatar
Nottingham Road South Africa/Bedford UK
Joined Feb 2007
What an interesting thread, I'm making myself subscribed!!
Gary Mortimer is offline Find More Posts by Gary Mortimer
Old Jun 14, 2010, 02:38 PM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
By the way,
The boxwing from Flyboat.co.uk is a simple square ram wing, with a positive lifting stabiliser. It works the same as the stabilisation of my Spasatel model:
Make a large positive lifting stabiliser on the rear, and shift the CG rearward, as soon as the model climbs, the front wing looses lift as it loses the ground effect, the rear wing(stabiliser) doesn't change, therefore the model gets noseheavy and descents back to the ground.
Still can't completely figur out how the Bixel manages to fly stable without this system:P
About the Rogallo type, I wonder if it actually behaves different than a Lippisch type reversed delta?
Old Jun 14, 2010, 03:58 PM
RdsG is offline
RdsG's Avatar
Hungary
Joined Jul 2009
Originally Posted by hoverman View Post
By the way,
I don't know much about the reversed rogallo. I know only two of them (i have photos of two version, but i have drawings about other rogallo type WIGs) ES-2 and ES-2M. ES-2M was very similar to Lippisch-type, it just had flat, flexible wing, while ES-2 had more hang glider style wings. They were modified Blanik L-13 gliders. Interesting fact is that they both have regular tails (original Blanik tail).
ES-2: http://www.wuala.com/groundeffect/Do...ect/képek/001/ Photo in my previous comment.
http://www.se-technology.com/wig/index.php
ES-2M: http://content.wuala.com/contents/gr....JPG?mode=list
Old Jun 14, 2010, 08:27 PM
DT56 is offline
Joined Aug 2005
Hey Rdsg,
any progress yet?
That's what Bixel said! Glad to hear it worked well for you!
One of the big advantages to the Bixel type WIG is the improved ground clearance created by the increased ground effect of the long chord.
I found it interesting that Bixel discovered the advantages of the flat foil / long chord combination by conducting experiments with gliders.
Old Jun 16, 2010, 02:42 PM
hoverman is offline
hoverman's Avatar
Netherlands
Joined Sep 2006
Yeah, I also found it cool that his whole story works. If I throw the model higher than in Ground effect, it will have a very shallow gliding angle, glide for about 10 meters, slowly pitching up, stalling at the end and falling back to the ground, exactly as he describes in his story.
I had some pictures of a model in my database, which seems to be designed around the bixel principle, the only difference is that it uses a rather thick symmetrical profile, instead of using a flat box shaped profile. Sadly I don't know how the model performed, would be interesting to know if it functions the same as the flat profiled gliders..
Marijn
Old Jun 16, 2010, 03:20 PM
DT56 is offline
Joined Aug 2005
Marijn
That's an interesting model! Reminds me a bit of the "Square Foot Plank".
I think the main advantage to the flat foil is one of longitudinal stability due to the reversed travel of the Cp. It's also easier to construct!
From the Bixel article:
The flat airfoil charts show its CP travel characteristic are reversed to the standard airfoils. The flat airfoil CP remaining nearly stationary, (slowly creeping aft), from high speed to normal cruise flight angles. During slow speed high angle, (+ 15 to + 26 deg.), flight the CP rapidly moves aft to reduce the angle of attack and resist stalls. The reversed CP travel direction and differing flight reaction characteristics are the primary reasons, all flat airfoil aircraft posses strong level flight stabilizing characteristics.
Yippee! On Topic - Cool General Aviation Stuff To Share szastoupil Valley Aero Modelers 163 Dec 27, 2015 12:39 PM
Cool Lun/Spasatel Ekranoplan build *IT FLIES! with photo's! hoverman RC Hovercraft 51 Jan 19, 2011 12:41 PM
Discussion "KASPIJSKI MONSTRUM" - PROJEKT KM (Ekranoplan) Petrovic Racing Boats - Electric 3 Jun 08, 2010 08:44 AM
