Old Jun 04, 2010, 06:19 AM
Patriek is offline
Find More Posts by Patriek
Fun Scaler
Patriek's Avatar
EHTX
Joined Jun 2007
Using 2S & 3S lipos in series – any disadvantages?
I am a happy user of Zippy Flightmax lipos, but now with the current shipping problems with Hobbycity and my desperate need of batteries for my MPX Mentor I am thinking about switching to “newer generation” lipo packs possibly. Especially looking at the Hyperion packs as they can charge up to 5C.
With two Hyperion EOS 720i Net3 chargers (250W each, both fired up by their own power supply) I could charge 1 Hyperion 3S1P 5000mah and 1 Hyperion 2S1P 5000mah pack simultaneously at 4C and use them in series on my plane as a 5S2P 5000mah. Charge time will be approx 20 minutes instead of 1 hour for a 5S1P
So now I have 2 questions:
1. Are there any disadvantages to using 1 3S 5000 & 1 1 3S 5000 in series as 5S2P 5000?
2. What about the 3 cell battery and 2 cell battery charged separately and used together in series? Good idea or bad?
Thanks in advance for your sharing your knowledge
Patriek
Patriek is offline Find More Posts by Patriek
Old Jun 04, 2010, 07:03 AM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
A 3S1P 5000 and a 2S1P 5000 in series is a 5S1P 5000 pack. As long as the cells are the same in both packs I see no reason that you can not use in series and charge in series .... or charge individually and then use in series. Electrically speaking you are fine.
When charging you need to know the proper hook-up procedure for series power and series balance or you risk causing a short.
Bob
http://rcsales.shutterfly.com
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old Jun 04, 2010, 07:45 AM
Patriek is offline
Fun Scaler
Patriek's Avatar
EHTX
Joined Jun 2007
Thanks Bob
As far as I know - when using two Hyperion EOS 720i Net3 chargers I can hook up one one lipo to one charger including balancer connectors as one would normally do, then connect the two chargers with a "network cable" so both chargers communicate with each other and match the cells voltage (sync charging).
In that case I would not have to make a hook-up harness like in your example, right?
Patriek
Old Jun 04, 2010, 11:24 AM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
I use a 3S & 2S in series in my H9 T-34 Mentor but I also charge them as such. I never use one pack for something else over the other.
I simply need to have 2 packs in order to fit where I wanted them and so series connecting a 2S & 3S was what I needed BUT I always treat it as such a 5S pack.
You do not want their mah capacity to be to out of balance between the 2 packs.
Just be carefull where charging in series cause one of the packs needs to have one of the balance wires removed and the order the pack are connected in the charger MATTERS.
freechip is offline Find More Posts by freechip
Old Jun 04, 2010, 09:24 PM
Duster_360 is offline
Find More Posts by Duster_360
Texas
Joined Aug 2006
Originally Posted by Patriek View Post
Thanks Bob
Patriek
I do the same kind of thing with a pair of older 0610iNet chargers and sync charge a pair of 3S packs or 2S and 3S pacs. In answer to your question, no, you don't need the harness you questioned.
You hook up each balance harness to each charger like you would normally as if charging stand alone. In sync charging, the chargers see all the connected cells for balancing.
Duster_360 is offline Find More Posts by Duster_360
Sold 2S and 3S Lipos Flying Chicken Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 12, 2010 01:23 AM
Discussion 2S, 3S Series Charging Board with Burnt Tracks. KC Batteries and Chargers 6 Sep 04, 2009 08:16 AM
Discussion Any disadvantages to only using metal gear on my Cularis? tekrunner Foamies (Kits) 7 Mar 13, 2009 09:56 PM
For Sale APEX 2S, 3S 1600 & 2S,3S 1350 Lipos RDD Aircraft - Electric - Batteries & Chargers (FS/W) 11 May 13, 2006 10:02 AM
Rave Mega 16/15/5 and 3s LiPos - any body using this setup? rc4metoo Power Systems 11 Apr 19, 2004 09:28 PM
