Old Jun 03, 2010, 04:21 PM
jaguar75 is offline
Find More Posts by jaguar75
jaguar75's Avatar
Sacramento
Joined Mar 2007
Old ProBar Sailwinch?
I'm trying to solve the mystery of who made the sail-winch.
Any comments welcome and information where I can obtain plastic or metal gears?The worm gear is worn and needs replacement.
Is the winch still in production or the maker offering up any parts?
I can get the original RE-360 MFA-COMO motor,new and improved Hall's Effect potentiometer and new digital servo amp control.
Regards,
John
jaguar75 is offline Find More Posts by jaguar75
Old Jun 05, 2010, 01:02 PM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
I think it was made by Dumas.
Then again it might not have been
A little further digging revealed the late (?) Don Prough of Probar Design
martin richards is offline Find More Posts by martin richards
Old Jun 05, 2010, 08:25 PM
csjsail is offline
Find More Posts by csjsail
Cleveland, Ohio USA
Joined Nov 2006
Try stockdriveproducts.com for almost anything, we use them at work for obsolete and hard to find drive components. Great service. Clyde
csjsail is offline Find More Posts by csjsail
Old Jun 06, 2010, 11:49 AM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Mystery Sail-Winch
It is not a ProBar winch according to the photos of his winch.His winch gearset is sandwiched between 2 plate frames and does not resemble this one.Maybe you can post an image but I am skeptical.
Thanks for the web-link : stockdriveproducts.com
Regards,
John
Old Jun 19, 2010, 12:14 PM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Regards,
John
There must be someone out there that was using this model sail-winch in the 1990's?
Regards,
John
Old Jun 19, 2010, 07:19 PM
csjsail is offline
Cleveland, Ohio USA
Joined Nov 2006
John, I recently inherited a Magic Dragon US One Meter from my father circa 1983. The winch looks a lot like yours. It was purchased from Ray Ozmun (Magic Dragon designer and molder) and is a Probar winch. It is different from the "Dumas" Probar winches. Clyde
Old Jun 20, 2010, 02:17 PM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Discussion Old ProBar Sailwinch?
Hi Clyde,
Thanks for the info.
I sourced out all of the gears from Berg.The gears are aluminum anodized 303 stainless steel with the exception of the bronze final gear on the potentiometer shaft.The potentiometer can be upgraded to a Hall's Effect type for better control.The analog servo amplifier can be upgraded to digital.All of the bearings are upgraded to stainless steel flanged ball bearings.Also changing the ss chassis to a milled extruded aluminum.
Regards,
John
Old Jun 21, 2010, 12:30 PM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Sail-Winches
Here are some images of the Probar and Probar-Dumas winches.
Old Jun 27, 2010, 11:25 AM
csjsail is offline
Cleveland, Ohio USA
Joined Nov 2006
John, I just went into the musty dusty archives in my basement. If yours has a stainless steel frame then it is a W-75 Probar winch. Quote from info sheet " The W-7 is geared for boats of 1100 sq. in. or less (transit time is less than 5 seconds). The W-75 uses the same gearing as the W-7 but has a stainless steel frame that weighs 1/4 oz. more. The extra stiffness provided by the SS frame allow this winch to be used on boats of larger sail area than the standard W-7." My father's boat uses the W-5 (less than 700 sq. in. sail area). W-6 has a capacity of up to 900 sq. in. sail area. Hope this helps, Clyde
Old Jun 28, 2010, 11:28 AM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Regards,
John
Old Jun 28, 2010, 01:14 PM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Clyde,
Can you e-mail the info sheet?
I will reward you!
Regards,
John
Old Jun 29, 2010, 08:00 PM
csjsail is offline
Cleveland, Ohio USA
Joined Nov 2006
John, I tried to scan the sheets that I have. The originals are not good enough. I will take them to work and try the copier. These pages were catalog sheets with "how to" information and items for sale. Have not found any other information on my father's W-5 winch (he kept everything else HAHA). Will keep looking. Clyde
Old Jun 29, 2010, 09:45 PM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Thanks Clyde.
You are an officer and a gentleman!
Any photos of the winch would be great,too
Regards,
John
Old Jul 01, 2010, 02:42 PM
jaguar75 is offline
jaguar75's Avatar
Sacramento
Joined Mar 2007
Clyde,
I'm dying from the suspense here!
It is sort of a forensic autopsy mystery.
My winch is spread out on the workbench in pieces and I am redesigning the entire winch.I sourced out a really good Hall's Effect potentiometer that is water-proof,metal gears,Boca ceramic hybrid ball bearings,digital servo amplifier and extruded aluminum chassis.I will also make a molded polycarbonate dust cover for the motor and servo amp.
Regards,
John
Old Jul 02, 2010, 01:49 AM
Useful Idiot
Asturias, Spain
Joined Mar 2001
John, once it's finally assembled, tested and installed, a video of the boat sailing would be great. It's really been a model of determination and perseverance.
Discussion Hitec HS785BB Sailwinch Niver Hitec/Multiplex USA 4 May 09, 2011 07:16 PM
Discussion sailwinch wolfsong Sailboats 26 Apr 04, 2010 11:03 AM
Discussion Como probar un Motor Electrico. manuel v Mexico 2 Feb 06, 2010 12:10 PM
Question ProBar 2.0 vs ProBar 3? asm_ Batteries and Chargers 1 Aug 08, 2006 03:35 AM
sailwinch mindbender_tm Sailboats 7 Jul 15, 2005 09:39 AM
