Old Jul 16, 2010, 08:04 PM
ShredAir is offline
Find More Posts by ShredAir
slope'n somewhere in the Andes
ShredAir's Avatar
Chile, Región de Coquimbo, Elqui
Joined Mar 2001
Dean, dumb question: the white sockets for the green Multiplex connectors... what are they?
Dieter Mahlein, ShredAir
ShredAir is offline Find More Posts by ShredAir
Old Jul 18, 2010, 12:07 PM
Bernd Brunner is offline
Find More Posts by Bernd Brunner
dare to thermal
Mannheim, Germany
Joined May 2004
Hi Dieter,
i think this will help to understand...
http://www.nessel-elektronik.de/Mehr...en-03-ha-a.gif
Bernd
Bernd Brunner is offline Find More Posts by Bernd Brunner
Old Jul 18, 2010, 03:50 PM
DEAN GRADWELL is online now
Find More Posts by DEAN GRADWELL
I found them at Hobby Lobby. They come in a package with the 6 pin Multiplex connector.
DEAN GRADWELL is online now Find More Posts by DEAN GRADWELL
Old Jul 18, 2010, 06:25 PM
Packed up and leaving for Muncie in the morning.
Old Jul 18, 2010, 07:47 PM
jtlsf5 is offline
Find More Posts by jtlsf5
jtlsf5's Avatar
United States, CA, Folsom
Joined Jul 2007
See ya at summer camp. You know where I'll be.
JT
jtlsf5 is offline Find More Posts by jtlsf5
Old Jul 18, 2010, 08:44 PM
G Norsworthy is online now
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, AZ, Tempe
Joined Sep 2008
Good luck, show them how it is done.
G Norsworthy is online now Find More Posts by G Norsworthy
Old Aug 06, 2010, 04:33 AM
jgs99v is offline
Find More Posts by jgs99v
Joined May 2006
As I promised
Dean and Beardsley - Finally got the 4600mAh A123 cells in.
The plan 3 flat pack did not work was expected - so modified some stuff and went back to the 2x2 inlines.
Tommorrow we'll see - I moved the CG forward abit as suggested, but reluctant to move the tow hook just yet. So tomorrow will be the test.
FYI - Max current flaps loaded = 1.5A Voltage drop from 6.56DC to 6.12DC so there is alot of resistance in the wires. Need to look into this.
Now with the skid installed nose and tail - I'm at 5012 grams so after all that work it's still fat - gotta look at how much protection the batteries really need etc....
That being said - The LiFe 3200 will give a those grams back, but given the current consumption observed need to look elsewhere - ah hem wire harness to tail section as you did! I'll look up that source.
Here is a snapshot of where it's at now.
jgs99v is offline Find More Posts by jgs99v
Old Aug 06, 2010, 12:13 PM
yyz is offline
yyz
Find More Posts by yyz
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
Do you have to shave 12 grams plus the weight of a logger and batteries or is it just a matter of shedding nonessentials?
Was this a stock MXC build or have repairs been done?
yyz is offline Find More Posts by yyz
Old Aug 07, 2010, 03:03 PM
jgs99v is offline
Joined May 2006
Mike,
Looks like the 72MHz has to go - that will remove the antenna and tubing. It had to happen, now I'm forced to to it sooner. Don't need 22ga wire for the rudder servo - 26ga should suffice - then I should be under by quite a bit. I should be 4750 with the Extrex installed.
Old Aug 07, 2010, 05:59 PM
Jack,
I found that too much landing flap increased servo power consumption alot.
I use a Hangar 9 meter in series and adjust flaps according to power consumption rather than a certain angle. You have to decide for yourself what your comfortable with. It's just the way it is with the MXC. I check all the servos with a meter.
Regards Dean
Old Aug 08, 2010, 10:53 AM
jtlsf5 is offline
jtlsf5's Avatar
Joined Jul 2007
Dean,
How much flap are you getting at the point you have determined is enough current draw? I would suggest 30-45 degrees is plenty for XC, its not a spot landing event. Enough flap to slow the plane down to a managable landing speed is plenty.
JT
Old Aug 09, 2010, 11:27 AM
jgs99v is offline
Joined May 2006
Dean,
I will experiment with Crow - unfortunately I was not able to test this as I left my toolbox and setup notebook at Davis on Friday :23#$!#4134@#$!#$#$@$@#$@#
But this would provide the largest braking surface with the least amount of current - since it's not only landing you might need this feature. However Beardsley has noted that with his stiff layup he remedied it by cutting the surface of the top skin - it's the live hinge that the servo is attempting to overcome.
JT or any of the Davis guys - please stash my toolbox until next saturday pretty please
Help! Help me make my mind up for me! Safety Hawk 3D Flying 37 Apr 12, 2010 11:11 PM
Sold E-Flite Blade MXC Wing&aPrayer Aircraft - Electric - Helis (FS/W) 0 Mar 28, 2010 07:44 PM
Discussion mxc motor swap chbronco Coaxial Helicopters 1 Mar 13, 2010 12:50 PM
Question Blade mXC c5eng Beginner Training Area (Heli-Electric) 1 Jan 05, 2010 10:09 AM
Discussion new canopy for mxc ? Chooby Coaxial Helicopters 8 Aug 28, 2009 10:12 AM
