Old Jun 13, 2003, 10:59 PM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
How to clean out old gas tank??????
Pulled the tank from the old mans hotrod (Been sitting a LOOOONG time ), and the thing has ton of gunk in the tank. Looks really bad. Pick up is plugged. Gas was brown and smells more like varnish. Tank was custom made to fit in rear of the '29 Ford Lowboy.
Any ideas on how to salvage this certain tank and clean the gunk out??????
Mark
mrittinger is offline Find More Posts by mrittinger
Old Jun 14, 2003, 12:36 AM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
Hoo boy!!
First off Mark, wash your hands well if you've been handling this stuff.
Your dad ran lead spiked premium gas in this rig right? Tetraethyl lead is probably a goodly percentage of this goop, cleaning it out would take something along the lines of many, many, gallons of laquer thinner, but where would you dispose of this toxic slop afterwards?
Looooeeee! is offline Find More Posts by Looooeeee!
Old Jun 14, 2003, 01:47 AM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
Yellow pages.
William A is offline Find More Posts by William A
Old Jun 14, 2003, 05:05 AM
Oneson1 is offline
Find More Posts by Oneson1
Melbourne, Victoria, Oz.
Joined Oct 2000
You need to find someone who can A: steam clean the tank and B: dispose of the sludge in a proper manner. because you do not want to get tetra ethyl lead on your skin, not if you want to see your daughters marry you dont!
After proper cleaning I would put a bottle of metholated spirits (it's hydroscopic) into the first tank or two that you run through it. and keep the tank full.
hugh
Oneson1 is offline Find More Posts by Oneson1
Old Jun 14, 2003, 06:30 AM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
The tank had regular gas with a lead additive in it, so I'm not sure its as toxic as you think it is, thought it may be.
What to look under in the yellow pages?
I emptied the fuel into gas cans. There is a hazzardous waste dump not far from here to dispose of it.
What do you think about kerosene, or brake fluid to eat the gunk off??? Or should I just get a newer plastic tank?
Mark
Old Jun 14, 2003, 06:46 AM
martin richards is offline
Find More Posts by martin richards
Useful Idiot
Asturias, Spain
Joined Mar 2001
Most high octane leaded fuel had max 4 g/gallon lead (about 0.1%). TEL is fairly high boiling point so will not have evaporated to the same degree as gasoline. Oneson's suggestion to use steam seems sensible, though it's a job that would better done professionally, in view of health hazards.
martin richards is offline Find More Posts by martin richards
Old Jun 14, 2003, 09:42 AM
Oneson1 is offline
Joined Oct 2000
Here in OZ we used to take the tanks out of our rally cars to a company that proffessionally cleaned industrial tanks of all sorts, they came back spotless and fumeless, we were running avgas at that time. So we could start every season happy about our fuel systems (we did all the other stuff as well, like replacing all the lines, filters and stripping and rebuilding the webber carbies. But as it's a hot rod, perhaps , like my brothers, you need a polished 9 gallon stainless steel beer keg as a tank. V classy !!
hugh
Old Jun 14, 2003, 11:00 AM
Tacoma, WA, USA
William A's Avatar
Joined Jun 2001
"What to look under in the yellow pages?"
'T' for tanks.
(sorry, couldn't help myself)
But seriously, I'd take it in for one of those 'dip' acid baths.
Old Jun 14, 2003, 01:37 PM
Gravity sucks.
mrittinger's Avatar
Joined Dec 2000
I called a radiator shop that a hot rodder here reccomended, it's about $75.00 to dip it clean. Sounds fair, as if I got a plastic tank I would have to modify the setup and attachment of the tank, adding to the cost over the $100.oo plastic tank.
I'll try the radiator dipping, and if that doesnt go, I'll buy a newer square tank.
Old Jun 15, 2003, 03:29 PM
Dave Campbell is offline
Find More Posts by Dave Campbell
United States, MI, Commerce Charter Township
Joined Dec 2000
The old acid dip treatment will clean it up very well-there is/was a large outfit doing this downriver from us off of Eureka and I-275.
You might also have good luck by filling the tank with antifreeze (old stuff that needs to be recycled, of course) and heating it up to a boil for a few hours.
In any event you will want to go to a good motorcycle shop and get a Tank Kreme kit to coat and seal the insides. Otherwise you'll start to rust up and plug the little galleries and jets in your carbueretors, or if you leave it long enough the tank will rust through.
Dave
Dave Campbell is offline Find More Posts by Dave Campbell
Reply With Quote  (Disabled)
Old Jun 16, 2003, 05:14 AM
Mike C is offline
Find More Posts by Mike C
Mike C's Avatar
Roxboro, NC U.S.A.
Joined Sep 2000
I had a tank that had started to rust on an old truck back in the 80's. It kept clogging the fuel filter every 1,000 miles or so. I took the tank off and carried it to a radiator shop. The guy either cut or used a grinder to make a small hole in the top of the tank on one of the corners and cleaned it out. I don't know how he cleaned it, I was just amazed that he cut a hole in the tank and the fumes didn't ignite! After cleaning he brazed the hole shut and it worked great from then until we sold the truck a few years later. It wasn't very expensive, it seems like it was around $40 in 80's money. Good luck
Mike C is offline Find More Posts by Mike C
Old Jun 16, 2003, 10:22 PM
The Other Dave is offline
Find More Posts by The Other Dave
The Other Dave's Avatar
Colorado Front Range, USA, EARTH, Sol system, Milkyway Galaxy
Joined Nov 2001
Dave Campbell is exactly right about this.
After you get it cleaned out get the tank kreme stuff and seal
the tank off so even if the cleaning doesn't get it all out
it will seal it off.
I have done this on 5 or 6 different cars with great results.
Never had a plugged jet or fuel filter after that.
The Other Dave is offline Find More Posts by The Other Dave
Help! How to clean out a brushless? epwierman Electric Motor Design and Construction 2 Apr 05, 2006 12:04 PM
Help! How to Clean out PJS1000 Keith43221 Power Systems 7 Apr 08, 2005 10:33 AM
Question NF SF501 gas tank (how to fill) VRF201 Motorcycles 18 Apr 01, 2004 09:08 AM
How to clean CA off the foot of a covering iron?!? kiwip Power Systems 10 Aug 05, 2001 03:56 AM
How to clean monokote? jdmartin8 Parkflyers 6 Apr 24, 2001 07:44 AM
