Old Jun 02, 2010, 02:53 AM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Video
SM100-45 EDF unit test run
Here's a quick test run of the soon to be released SM100-45 EDF unit. It's 100mm diameter and designed for up to about 5kW or so. This test unit is fitted with a Neu 1521-1.5Y, ICE HV160 esc and 12S XPS 5000's. Looks like a killer setup to me.
Stu.
stumax is offline Find More Posts by stumax
Old Jun 02, 2010, 03:04 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Very impressive Stu!
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jun 02, 2010, 03:24 AM
Extreme_RC is offline
Find More Posts by Extreme_RC
Extreme CNC Alloy EDF
Extreme_RC's Avatar
Australia
Joined Mar 2006
Nice Stu, can you get RPM as well, would be nice to know what its spinning to produce various thrust levels, maybe an rpm snapshot at 3kg, 4kg, 5kg, 6kg etc thrust?
Extreme_RC is offline Find More Posts by Extreme_RC
Old Jun 02, 2010, 06:52 AM
Burdo is offline
Find More Posts by Burdo
Guarantee at least one landing
Burdo's Avatar
Australia, QLD, Mooloolaba
Joined Aug 2007
Very nice....7kg of pull...Holy
Burdo is offline Find More Posts by Burdo
Old Jul 17, 2010, 04:14 PM
Doug Bateman is offline
Find More Posts by Doug Bateman
Doug Bateman's Avatar
Swarthmore, PA 19081
Joined Dec 2004
Foe some reason if i have to download a video i can't view it. I just get a screen full of symbols. But nice info on the 100mm Stu. I would probably run it around 3500 watts.
Doug Bateman is offline Find More Posts by Doug Bateman
Old Jul 17, 2010, 05:34 PM
SteveC68 is offline
Find More Posts by SteveC68
Oh Yeah!
SteveC68's Avatar
League City, Texas
Joined Sep 2006
Doug,
http://www.videolan.org/vlc/
Download that video player. It will play almost anything and works for this video.
Steve
SteveC68 is offline Find More Posts by SteveC68
Old Jul 21, 2010, 03:45 PM
markbrown1 is offline
Find More Posts by markbrown1
markbrown1's Avatar
Surrey England
Joined Apr 2006
Stu
I missed this one looks like it will be a killer.
Mark
markbrown1 is offline Find More Posts by markbrown1
Old Jul 21, 2010, 04:04 PM
Joined Dec 2004
Originally Posted by SteveC68 View Post
Doug,
Steve
Steve, thanks......
Old Aug 25, 2010, 12:05 PM
Gamalier is offline
Find More Posts by Gamalier
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Hello Stu,
I found an ideal candidate for the 90 mm but is a kit and its made of balsa but the weight is 2000g. If you need a bigger rotor I know where we can find one the only drawback is that most of the weight from 150-200 tons. LMAO!!!
Good luck with the project!!
Gamalier is offline Find More Posts by Gamalier
Old Jan 12, 2011, 05:57 PM
Joined Dec 2004
Originally Posted by Gamalier View Post
Hello Stu,
Looks like a high pressure turbine. Is it for conventional or nuclear?
Old Jan 12, 2011, 06:16 PM
Gamalier is offline
Gamalier's Avatar
USA, NC, Hope Mills
Joined Jan 2010
Its a HP rotor for a steam turbine located in Arizona. We cut the thrust bearings and installed and machined new seals.
Old Jan 13, 2011, 08:15 AM
Joined Dec 2004
A lot of angular momentum there dude....keep your shirt tucked in!! Doug
Old Jan 17, 2011, 07:59 PM
Joined Dec 2004
Doug,
Steve
Still no go on video. I'm determined to find video of the 100mm. Ill try this on windows at work. I have no luck with the so called user friendly Apple.
Video RCBee gear door sequencer test run ralf dvorak Electric Plane Talk 0 Dec 14, 2009 04:58 PM
Question Lipo test run failure deckert Batteries and Chargers 14 Nov 25, 2009 07:03 PM
Video Stumax SM110-52 EDF unit quick test run stumax Electric Plane Talk 10 Oct 02, 2007 07:58 AM
Question MEGA 16/17/2 EDF..... 1st run-up test. rjarois Electric Ducted Fan Jet Talk 4 Apr 16, 2007 03:46 AM
