Joined May 2010
Quad Propeller Guard - Sharing ideas, videos, photos
Hi Guys
I am trying to build some sort of a prop guard for my quad, like the Parrot Drone or something, so that it can become a better park flyer. A lot of people fly at home and in parks and I think protection is equally important as having a stable flight. I am looking at plastic, wood, foam, bamboo or anything which is strong and also doesnt hinder the flight. http://www.youtube.com/watch?v=5KDVbk2Sunk |
--Eric-- http://www.youtube.com/watch?v=sDqbOg-NA_8 |
I was thinking about starting a thread like this -- I am working on one as well.
My quad is much bigger than the one in the video above -- it's 8 lbs with payload, and I'll need a cage 3.5 feet across. Part of the reason (besides safety) is that my craft is top-heavy and tips over easy anyway. I've already broken 2 props. I'm currently looking at using cheap plastic extensions zip tied to holes in the arms -- I'm using plastic tube sold for hiding wire. 4' costs $4. Then, I'm going to try using 50lbd test fishing string wrapped around (or through) holes drilled in the outermost points. This is cheap and lightweight, and should reduce damage in a tip-over or bump into something. Photos later
I like the Asctec Pelican protection system. Does anyone know if this can be purchased. I get a timeout when I try to go to www.asctec.de.
- Jeff OK, I can get into their site but it doesn't look like they sell this. |
VA
Joined Nov 2009
I was wondering if one of the guys with a CNC machine could cut skeletonized top and bottom shroud plates from G10 and we could use nylon standoffs around the edges. That way they could be used on any quad just pick the right diameter for the prop used. Nothing is going to stand up too good to a full impact from several hunded feet up but G10 is pretty tough stuff.
Joined Jun 2010
Quadrotor Design Help!!!
Hi Guys, i have a question. I would be very happy if someone gave me an answer to this. I am using a Futaba 6EX radio control and i am trying to get my micro controller to read the pwm signal from the receiver. i have looked at the signal via an oscilloscope and know the characteristics; frequency, amplitude, duty cycle. Does anyone know a good scheme of reading the signal with uC and then controlling the ESC?
Joined May 2010
| Thread Tools | |
| Build Log Taking FPV ON! Ideas, Considerations, Build Log, Videos | Bandarra | Video Piloting (FPV/RPV) | 244 | Oct 17, 2010 05:10 PM |
| Discussion Friday Night Photos/Videos | Jim T. Graham | ETOC - Electric Tournament of Champions | 20 | Apr 11, 2010 04:11 PM |
