This thread is privately moderated by Dan.Cummins, who may elect to delete unwanted replies.
Old May 31, 2010, 12:35 PM
Dan.Cummins is offline
Find More Posts by Dan.Cummins
Launching!
Dan.Cummins's Avatar
Chula Vista, CA
Joined Jul 2006
Wing tube drill jig
Wing tube drill jig
I need to drill some wing tube holes for some TWF wings, and I need to dial in as much dihedral as I can get between the top skin and bottom skin over 5 or 6 inch wing tube....so I made up this little wing tube drill jig.
It allows me to set the root entry point (wing in the bed), and then the maximum dihedral (wing out of the bed, extend drill tube until it just touches the bottom bed).
Materials used for Wing Tube Drill Jig:
- 3/8" brass tube (for 11/32 wing tube for 5/16 wing rod)
- Two 1/4"-20 brass button head machine screws + nuts + washers
- 8"chunk of 1X3 poplar
- Two chunks of a wood yard stick
Materials used for Sub-Rib Drill:
- 1/2" Copper Pipe Repair Coupler
- 1/4" Piano wire for handle
Dan.Cummins is offline Find More Posts by Dan.Cummins
Old Jun 04, 2010, 09:10 AM
The_Builder is online now
Find More Posts by The_Builder
God Created me to Create
The_Builder's Avatar
Joined Nov 2009
That is VERY COOL !!!! YOu should post that is the composites forum.
The_Builder is online now Find More Posts by The_Builder
Old Jun 05, 2010, 01:03 AM
Launching!
Chula Vista, CA
Joined Jul 2006
Thanks, I will post the link in the composites forum.
DC
Old Jun 08, 2010, 01:12 AM
fcbflyer is offline
Find More Posts by fcbflyer
Sloping the Financial Cliff
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Nice!!!!
Did you glue the tube to the bolts?
fcbflyer is offline Find More Posts by fcbflyer
Old Jun 08, 2010, 09:21 AM
Launching!
Chula Vista, CA
Joined Jul 2006
Originally Posted by fcbflyer View Post
Nice!!!!
Nope, just used a dremel and a sand drum to shape the bolt heads to conform and then just silver soldered them using paste flux......I tried to break em off by hand and couldn't do it....so they're pretty strong.
Since the photo, I cut the tube length a little so that my 11/32 drill reaches through so that I can drill the root rib when it's in place.
DC
Old Jun 14, 2010, 09:16 PM
Bagger is offline
Find More Posts by Bagger
Wing Bagger
San Diego, CA
Joined Dec 2005
check mine out it has bling sliders/uprights. Thanks Dan for the slotted poplar
Bagger is offline Find More Posts by Bagger
Old Jun 14, 2010, 09:20 PM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Cool, are you guys going to have a jig build off? Next put on some chrome parts
Old Jun 14, 2010, 09:49 PM
Launching!
Chula Vista, CA
Joined Jul 2006
Putting that mini-mill to work.....very cool........not that HD yard sticks aren't cool, but machined aluminum is cool.
DC
Old Jun 16, 2010, 08:31 PM
Bagger is offline
Wing Bagger
San Diego, CA
Joined Dec 2005
Got to say Dan good design. I cut 4 pairs of spar tubes holes perfectly and quickly.
Old Jun 16, 2010, 11:39 PM
fcbflyer is offline
fcbflyer's Avatar
USA, CA, Santee
Joined Oct 2007
Cool, I totally expect the cores to come pre drilled from now on
Old Jun 17, 2010, 12:38 AM
Launching!
Chula Vista, CA
Joined Jul 2006
Their already drilled, you need to pick em up and get em off my bench
Discussion Wing tube drill jig Dan.Cummins The Builders Workshop 5 Jun 01, 2010 11:38 PM
Sold DL-50 w/2 Props and Drill Jig dfrazier Aircraft - Fuel - Engines and Accessories (FS/W) 4 May 30, 2010 08:18 PM
Discussion Diy drill jig for use when making your own folding blade holders gloworm Coaxial Helicopters 7 May 02, 2010 01:06 PM
Wanted DL 50 Drill Jig flyingj Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 15, 2010 01:09 AM
