Old Sep 29, 2001, 10:32 AM
smsgill is offline
Find More Posts by smsgill
Scott Summersgill
smsgill's Avatar
Thousand Oaks, CA
Joined Feb 2001
Sr X-250 and Speed 480 question
My dad has the X-250 with the standard recommended power system and is looking for a little more power. I know some have upgraded to a speed 480 with great success. What is involved in replacing the standard 7.2V speed 400 with a speed 480? Is it a drop in replacement in the gearbox or do you have to deal with other pinion gears etc? Also what prop do you recommend with the speed 480? Still the 9x5 slim e props?
Thanks in advance.
Scott
smsgill is offline Find More Posts by smsgill
Old Sep 29, 2001, 03:06 PM
JTinCT is offline
Find More Posts by JTinCT
JTinCT's Avatar
New Milford CT 06776
Joined Sep 2000
The 480 that Dymond has will drop right in. You can use the same prop of play around to see what you like. I was using an Areonaut 9x6 folder on mine. The Graupner 480 is different so it will not fit the gearbox. JohnTracey
JTinCT is offline Find More Posts by JTinCT
Old Sep 29, 2001, 07:04 PM
Neil Morse is offline
Find More Posts by Neil Morse
Registered Snoozer
Neil Morse's Avatar
San Francisco, CA, USA
Joined Jul 1999
What John said. You have to be careful because the designation "speed 480" is used to apply to several quite different motors. The easy "480" upgrade that is just a drop in for the X250 is the motor that is sold by Dymond and Permax (Multiplex) and is just a speed 400 with a slightly longer can. It has a 2.3 mm shaft, like a speed 400. The more sophisticated (and expensive) 480's from Graupner have a bigger shaft (I think 3.2 mm). Since the shaft on the "long can" motor is the same, you just need to pull the pinion off the stock motor and put it on the 480. As John says, then the motor just bolts onto the gear drive with the same screws.
Neil
Neil Morse is offline Find More Posts by Neil Morse
Old Sep 29, 2001, 08:58 PM
sampah is offline
Find More Posts by sampah
Joined Sep 2001
i have a new e-motor it is TRAXXAS
and the TRAXXAS motor name is STINGER
my question is can i used STINGER from TRAXXAS as e-flight ?
if you have an example (picture) wich plane i could use with
STINGER ?
can i used STINGER as ZAGI or ZAGSTIK ?
Thank's
sampah is offline Find More Posts by sampah
Speed 480 Question Mr Hat Foamies (Kits) 1 May 10, 2002 03:39 PM
MF 480 and Speed 480 question Sabrejock Electric Ducted Fan Jet Talk 12 Dec 11, 2001 12:18 PM
SR X-250 power options/Mini Kaos BTerry Sport Planes 3 Oct 15, 2001 04:17 PM
Can anyone recommend any SR X-250 Performance Improvements? p-zag Sport Planes 7 Oct 06, 2001 05:23 PM
I'm confused. Speed 480 question. smsgill Electric Plane Talk 2 Sep 30, 2001 02:58 AM
