Some humble advice for novice FPV pilots
It's only been about 4 years since I learned to fly FPV and RC. So take all this with a grain of salt.
![]() To get started in FPV, all one needs: - A slow, naturally or electronically enhanced stable platform- Your choice on how to get that... - A reliable (read SIMPLE...less to go wrong) Video system- A camera, Video Transmitter, Video Receiver from any of the reputable vendors (I like HobbyWireless, NGHobbies, and RangeVideo) will do. - A good video display...goggles or flatscreen, your choice...I prefer goggles. I use the slim R-visions, which allow me to easily peak out. Whatever you start out with, make sure you can see things. - A reliable spotter...I use my Wife or Son...Better than any OSD, all for the price of a kiss or a bacon wrapped polse (hotdog). - Good Environmental Conditions...If the wind is any more than 4 knots, it's raining, if the sun is low and always in the camera's view, just stay home...lols. - Lots of space...Takes away the complication of having to dodge anything...also keeps the line of sight clear for your spotters... That's it...Keep the gyros, co-pilots, super expensive OSD's, LRS radios, and hot planes on the ground until you get some experience...A complicated system is less reliable and REALLY EXPENSIVE. Why deal with that when you're just getting started? Keep it nice and close for now. Before you think of venturing out, learn how to handle the plane...take offs, landings, turns, climbs and descents. Discover your system's limits slowly...Push your limits one at a time. When expanding my system's envelope, starting from what is known flying within line of sight, I varied only one parameter at a time (altitude, range, endurance, speed...etc). Hope that helps someone and that others share some advice... and again, take all this with a grain salt...Consider the source...LOL. ![]() Some info for novice FPV pilots: FPV Podcast (EPISODE 96)- FPV talk starts at around 18 minutes.Progression and Upgrades |
How about
- Realistic goals If I had a nickel for every time someone posted something like "Hi, I'm new to FPV (or even R/C) but I'm looking for a system that will reliably allow me to fly 5 miles away.", I'd be rich. About 1% of the people here have ever flown that far. The other 99% have discovered that a tremendous amount of fun and challenging flying can be done in the 1/2 to 1 mile range. ian |
Latest blog entry: My 2012 FPV year in Review
USA, CA, Los Angeles
Joined Sep 2004
to put it into simpler terms: If you do a range test without a video transmitter, and one with video transmitter, you can make a fairly precise judgment on how your vtx affects your R/C range. If you just pack all your gear on and then do a range test, you don't have that frame of reference. Same applies to each individual component, with the various combinations that are likely to cause problems growing exponentially with every piece of equipment you add. This is exactly why modular systems are, from the point of view of a FPV flyer, a bad idea. If you have a "product package" you can assume it has been tested in itself, so you add a lot of features without creating a whole new set of failure points. in a modular system, each component you add can cause some issue somewhere in your system. EDIT: this obviously also applies to all other aspects of the hobby. e.g. if you fly with an OSD from the beginning, you will rely on the OSD and have difficulty navigating without it. if you rely on antenna tracking from the beginning, you will not know how antenna positions affect your flight. in short, once one of the systems fails on you, you're screwed. |
ya gotta be able to walk before ya can run.... |
| Thread Tools | |
| Discussion Some advice for HD cams which can be used for FPV | AnnihilaT | Video Piloting (FPV/RPV) | 18 | Aug 02, 2010 02:43 PM |
| Discussion SR vs. TREX 250 clone compairison by novice pilots | Gadflyii | Micro Helis | 71 | Mar 05, 2010 09:14 PM |
| Discussion looking for some Tandem Rescue heli pilots | Danpagesr | Micro Helis | 5 | Feb 01, 2010 12:10 AM |
| Discussion some advice for a novice???? | animaljosh | Racing Boats - Electric | 1 | Jun 07, 2008 12:16 AM |
| LMH Pilots 1st Voyager flights need some advice | JIMJAM | Electric Heli Talk | 6 | Jan 18, 2002 04:21 PM |
