Old May 29, 2010, 09:35 PM
greenmonsta79 is offline
Find More Posts by greenmonsta79
Brazil,IN
Joined May 2010
How do you tell if you should use a Lipo battery that has been in a crash???
Hey guy's I have a question regarding a Lipo 4s battery that was in a crash today I am a newbie to EDF's and it went pretty well until the end of the flight!,
was a little too windy and it went into a flat spin and was unrecoverable, hit nose first 70mm F-16 and the battery is basically right in the nose, Well the battery looks smushed up on one end the end without the wiring, how can I tell if it's safe to re-use? If there is no way I will just throw it away. Thanks for all the great info guy's (and I have another fuse coming so I can fly it again!!)
greenmonsta79 is offline Find More Posts by greenmonsta79
Old May 29, 2010, 10:15 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Without some very good photos showing the damage no one should even offer an opinion other than a damaged LiPoly should be discharged to below 3.0 vilts per cell and disposed of.
If it is deformed then it will go down hill quickly.
http://www.rcgroups.com/forums/showp...13&postcount=1
Snip:
The other accelerator is the presence of "hangar rash" on the cells due to continuous handling and ding marks that cause salt crystals to start forming at pressure points. This is the primary reason for using IMPAD around packs to protect against impact. In other words, avoid the temptation to scrape a thumbnail over that envelope to see if it springs back!
Charles
Old May 30, 2010, 09:22 PM
Mark Wood is online now
Find More Posts by Mark Wood
characters welcome!
Mark Wood's Avatar
United States, CA, Bear Valley Springs
Joined Feb 2000
My personal guidelines say that if I have to ask myself that question, the pack gets disposed of. Many get away with reusing such a pack. I don't care for the odds and the fallout should I guess wrong.
mw
Mark Wood is online now Find More Posts by Mark Wood
Old May 30, 2010, 09:52 PM
ambientech is offline
Find More Posts by ambientech
ambientech's Avatar
Central Texas
Joined Jun 2008
As long as it doesn't puff up it should be fine. I currently have a Hyperion 3s pack that was smashed in a crash and is still perfectly fine over 30 cycles later. I would watch it closely and as soon as it starts to show any problem I would dispose of it.
ambientech is offline Find More Posts by ambientech
Old May 31, 2010, 07:56 AM
Eagleburger is offline
Find More Posts by Eagleburger
Electric Hippy
Brisbane
Joined Nov 2005
Do a cycle on a charger and monitor balance. This can indicate if one or more cells has lost capacity.
Second thoughts, I agree with EF, if you got to ask better not mess with it.
Eagleburger is offline Find More Posts by Eagleburger
Discussion how do you tell if you got the wrong esc from WOW.? user0125 Micro Helis 4 Mar 11, 2010 11:49 AM
Discussion How do you tell if your ESC has gone bad? tlr-boise Electric Plane Talk 10 Jul 21, 2009 05:13 PM
Discussion how do you tell if you have a dead cell in your pack AzJason Batteries and Chargers 4 May 12, 2006 06:27 PM
how do you tell if Lipo cells are end of life askman Electric Heli Talk 2 Apr 02, 2005 07:41 PM
