Old May 29, 2010, 01:39 PM
ForeverFlying is offline
Find More Posts by ForeverFlying
ForeverFlying's Avatar
Christiansburg, VA
Joined Sep 2002
Fly Sky FS-TH9X Switch Error!
Hi Forum!
I just got my new radio from Leaders Hobby. When I turn the transmitter on I get the Switch Error! display. I am using NiMHy batteries. Is this OK? The manual does not say anything about battery compatibility or error codes. By the way; does anyone know what kind or range this Fly Sky module and receiver has?
Thanks!
ForeverFlying is offline Find More Posts by ForeverFlying
Old May 29, 2010, 02:17 PM
speedy72vega is offline
Find More Posts by speedy72vega
United States, OR, Portland
Joined Sep 2009
Mike, make sure all of the switches are in the back position, towards the rear of the radio. You will get a swtich error if any of the switches are forward.
speedy72vega is offline Find More Posts by speedy72vega
Old May 29, 2010, 03:36 PM
Christiansburg, VA
Joined Sep 2002
Great!!! Thanks, Speedy!
Old May 29, 2010, 03:56 PM
Christiansburg, VA
Joined Sep 2002
Another Question: I hold the buttons for 60 seconds or longer before the menu items change, if at all. Am I doing something wrong, or did I get a bad radio? Also, do I want PCM for 2.4Ghz?
Thanks!
Old May 31, 2010, 12:01 PM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Thanks!
Such a long wait is definitely not normal.
No, you don't want PCM. The 2.4 modules work only with the standard PPM signal.
Daedalus66 is online now Find More Posts by Daedalus66
Old Jun 30, 2010, 12:03 AM
romero2005 is offline
Find More Posts by romero2005
Joined Jun 2010
hi
Hi Forum!
Thanks!
I am still have this same error.can any one help me about this pls..
THanks
ROMA
romero2005 is offline Find More Posts by romero2005
Old Jun 30, 2010, 12:49 AM
Christiansburg, VA
Joined Sep 2002
Switch Error
Hi Romero,
Did you try this?: Mike, make sure all of the switches are in the back position, towards the rear of the radio. You will get a swtich error if any of the switches are forward.
It worked for me!
Good night,
Old Jan 23, 2014, 08:32 AM
streetrod1929 is offline
Find More Posts by streetrod1929
Joined Jan 2014
Jp
I installed a back light in my th-9x and when i turn on the switch i get a switch error all the switches are in the off position anybody know what the problem is ?
streetrod1929 is offline Find More Posts by streetrod1929
Old Feb 03, 2014, 08:37 PM
MumblingFumbler is offline
Find More Posts by MumblingFumbler
Joined Jan 2014
The menu and exit buttons on my transmitter seem to take some 'breaking in'. Initially, I had to push each one several times in order to get them to register. Now it is down to once or a couple of times. Maybe some oxidation in the switch, or poor components? I'm on the fence about whether to send it back or not.
WRT using NiMH batteries, they will work, however AA's that are slightly oversize like the Sanyo Eneloop X 2400mah will not fit properly in the extremely poorly designed battery box. I'd give the mechanical design and build quality of this transmitter a D.
MumblingFumbler is offline Find More Posts by MumblingFumbler
Discussion I have a problem with the FS-TH9X transmitter Dima Soukhman Radios 2 Jan 06, 2012 03:43 AM
Discussion imax/turnigy/Flysky FS-TH9X FM Tuner Modul 35 MHz rotaxquax Radios 0 Mar 30, 2010 02:15 PM
Help! flysky fx th9x switch orientation Rukee Radios 3 Mar 18, 2010 08:00 PM
For Sale FlySky FS-TH9X 2.4G W/ 3 Receivers Firefox675 Aircraft - General - Radio Equipment (FS/W) 3 Sep 18, 2009 03:48 PM
