Old May 28, 2010, 11:41 PM
Joined Mar 2010
Skywing Monster
Look what the cat dragged into my house this morning!
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old May 28, 2010, 11:46 PM
3D Crazy
Meez's Avatar
Putrajaya, Malaysia
Joined May 2010
wait for your flight report.................what is the material?
Meez is offline Find More Posts by Meez
Old May 29, 2010, 12:22 AM
Joined Mar 2010
The fuse in made of 5mm and solid block EPP(behind the firewall)..close inspection reveals 2 flat CF with one placed at the centre of the fuse and another one at the bottom of the fuse all the way to the tail.
The ailerons and tail fins are made of 3 layers of EPP stacked together..The EPP is of better density compare to Techone.
The fuse is quite stiff so tail twists should be minimum.(i hope)
This one should be a fast build but i still have to wait for the arrival of my MG servos.
Old May 29, 2010, 01:05 AM
Ride Blue
jholen's Avatar
United States, WA, Sammamish
Joined Aug 2006
Nice - looking forward to your build!
jholen is offline Find More Posts by jholen
Old May 29, 2010, 01:47 AM
How many planes is too many?
groovejet's Avatar
Melbourne, Australia
Joined Aug 2007
It looks good. I just came home from a couple of hours at the park with a few planes including my Skywing Tough and my Skywing Katana. I really like my smaller Skywing planes and I look forward to hearing your thoughts on this larger Skywing plane.
groovejet is offline Find More Posts by groovejet
Old May 29, 2010, 02:56 AM
khen's Avatar
Utah USA
Joined Jun 2002
i've been on the fence on ordering one of these..
khen is offline Find More Posts by khen
Site Sponsor
Old May 29, 2010, 07:27 PM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Thanks for photos, FlyingMcCoy.
I cannot watch your youtube videos. When I click on your Souka video, I would get a message saying "this is a private video." Do I need any permission to watch your youtube videos?
Feda
feda is offline Find More Posts by feda
Old May 31, 2010, 12:51 AM
Joined Mar 2010
Thanks guys..here are the electronics that i intent to use on my Monster.
2818/900 Torque motor and 35 amps ESC.
D933MG 12g 2.0kg servos x 4
2200mah 3s Emax li-po.
I should be able to put everything together in one evening because all the work has been done for by the factory including hingers, control horns and servo mounts installation. Airframe minus the all the electronics weights in at 600g.. Another thing i have to mention- the instruction manual is just 2 pcs of paper in Chinese and not a word about where the CG is. But i'm sure those with experience in building planes can do away the manual anyway. If you're a beginner you wouldn't have bought this plane in the first place would you?
HK..where are my servos??
Feda..the problems with the videos has been rectified..you should be able to watch it now.
Old May 31, 2010, 06:25 AM
groovejet's Avatar
Joined Aug 2007
Thanks for posting this info FlyingMcCoy. It's good to know that the larger Skywing planes are also virtually pre-assembled at the factory like the smaller ones.
Old May 31, 2010, 11:15 PM
Joined Mar 2010
Finally my servos have arrived from HK..hope i'm able to put everything together in time for maiden this coming weekend.
Cheers.
Old Jun 01, 2010, 03:26 AM
groovejet's Avatar
Joined Aug 2007
Keep it coming!
Old Jun 01, 2010, 07:20 PM
Ride Blue
jholen's Avatar
Joined Aug 2006
Yes, more pictures. Video is better!
Old Jun 02, 2010, 04:13 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
I received my Monster from feda it also has carbon in the tail and ailerons.
Very nice. I will start by fixing the main wings to the fuse.
The main wing is in two pieces and needs to be lined up with each other.
I test fit everything first.
J.Douglas is offline Find More Posts by J.Douglas
Old Jun 02, 2010, 05:56 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
As I wait for the glue to set up on the wings I started to mount the tail servos and pull wires. There are openings above the mounts for the wires.
Old Jun 02, 2010, 06:46 PM
Old Skool
J.Douglas's Avatar
Joined Dec 2003
FlyingMcCoy, I hope you dont mind me posting my build here I hope we can help each other out .
I wanted to beef up the wing mount some. I have this foam cutter and maid the holes for the wing joiner bigger so I could pack some glue in around the tube. This could be done as the wing are put together.
New Product Skywing's new design for their big YAK54 feda 3D Foamies 260 Jun 04, 2012 11:38 PM
New Product Skywing "Tough" EPP 3D ARF groovejet 3D Foamies 266 Nov 23, 2011 11:06 AM
New Product Skywing Sbach 342 feda 3D Foamies 269 Oct 19, 2011 10:57 AM
New Product Skywing Katana EPP 3D ARF groovejet 3D Foamies 55 Jun 01, 2010 01:48 AM
Sold Skywing 200A ESC NIB setxws6 Aircraft - Electric - Power Systems (FS/W) 2 Dec 17, 2009 10:41 AM
