This thread is privately moderated by cleansurf2, who may elect to delete unwanted replies.
Old May 28, 2010, 08:55 PM
cleansurf2 is offline
Find More Posts by cleansurf2
cleansurf2's Avatar
Australia (Newcastle)
Joined Mar 2009
Cheap 2.4G HK T6 Tx'r overview & Review
I'm using a basic 2.4G Tx'r (US$32 + S&H from HK). Mostly because of the cheap Rx's available for it at <US$13 + S&H. This allows me to have a lot of basic planes for different conditions, applications and various atates of repair. As they get battered they get an even harder time low level etc, untill it's all over.
The only time I have ever had a glitch is when I put some lead balast on one of my gliders over where the antennas where installed, I try and set the antennas away from the CG points now where I may want to add balast.
Otherwise, a dozen operational planes on this Tx'r and no probs, recommended budget 2.4G rig. I recently got another one so I could configre for a 3D flyer setup.
The disadvantage of this model is memory loads have to be back at the PC. Not a real issue for me as I have set all my planes up the same, which does have some limmitations, as I would like to change ratios for elevator/aileron throw/mix for some planes, but I get buy fine. I even setup a airbrake on one plane using one of the Tx analouge knobs.
HK now have gone to V2 of this Tx'r, slightly cheaper, but Rx'rs are single antenna only (maybe range issues, it now has Freq hoping so hopefully that will compensate). The HK X9 now has Tx module built in and $9 2.4G 8chl Rx's, also compatable with the V2 T6 Rx's, reviews so far look good, may go this way next.
Some excellent links for the Tx'r.
T6 Tx
http://boydhobby.com/ExceedR2FC6chRa...rolSystem.aspx
http://www.mycoolheli.com/t6config.html
T6 Tx drivers etc
http://boydhobby.com/Downloads.aspx
T6 Tx trainner switch mod
http://www.rcgroups.com/forums/showp...postcount=1697
Sim Tx
http://boydhobby.com/Dynam6chFlightSimulator.aspx
Palm pilot software
http://www.rcgroups.com/forums/showt...6#post14776667
cleansurf2 is offline Find More Posts by cleansurf2
Old May 29, 2010, 03:40 AM
saucerguy is online now
Find More Posts by saucerguy
saucerguy's Avatar
United States, WA, Yacolt
Joined Dec 2005
Haven't done a lot of looking into HK lately, looking at those systems, just wowed, and am so much thanking myself for waiting on the 2.4 systems to get better in costs before making the plunge. I may be shopping there again for my next run of planes, going to be selling the kits I do, complete with new gear like this for those new to it all that don't want to wait or deal with China. When the weather gets normalized here, I suspect will have a ton of locals turned onto this hobby, and having the extra set's of gear, plane kits and all ready to go will make it a snap for them and save on their pocket books in the process compared to being limited to only the expensive lhs.
saucerguy is online now Find More Posts by saucerguy
Old May 29, 2010, 04:49 PM
ergocentric is offline
Find More Posts by ergocentric
Aircraft re-kitter
ergocentric's Avatar
15NM from CYYZ on 06L
Joined Feb 2007
old palm pilot to the rescue:
http://www.rcgroups.com/forums/showp...postcount=3230
more hack links in my blog, many more
ergocentric is offline Find More Posts by ergocentric
Old Oct 28, 2010, 01:16 PM
Russ The Flyer is offline
Find More Posts by Russ The Flyer
It flies or it dies
Russ The Flyer's Avatar
Deville, Louisiana
Joined Sep 2008
Hi Mates. Not sure if this thread can help but I'll give it a go.I'm mounting my RX in a Dirty Birdy. I notice that what seems to be an extended antenna for it. My question is, where do I mount the 2nd part of the antenna? Right now I'm running antenna wire for the extended part through the top of my plane where a fuel hose used to be. (Yes I've converted it to an electric) The little part with the wire coming out of it is installed next to the RX. Is this ok so long as the antennas point in different directions?Thanks a lot for your help with this. Russ
Russ The Flyer is offline Find More Posts by Russ The Flyer
Sold Airtronics SD-10G 10-ch 2.4G Tx w 2 Recievers 5ch & 7Ch FieldofDreamsFlyer Aircraft - General - Radio Equipment (FS/W) 7 Apr 28, 2010 05:55 PM
Sold 4 eflite blade cx3 2 cx2 multiple heli sellathon used new helicopter tx 2.4g blueindian Aircraft - Electric - Helis (FS/W) 1 Apr 19, 2010 08:21 PM
Discussion 2.4G VTx + 2.4G Tx ? kason FPV Talk 6 Aug 27, 2009 04:59 AM
Discussion 2.4G with 2.4g Tx??? MartinL FPV Talk 2 Apr 13, 2009 08:58 PM
For Sale CP pro TX & RX and CX2 2.4G TX tkoguy Aircraft - Electric - Helis (FS/W) 3 Jul 20, 2007 06:56 PM
