Old May 27, 2010, 04:49 AM
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
Rookie FPV How to Power the Rx Tx FPV..
Hello there..
I just purchase a TX RX 1,3 850mw system and i need some help right here...
First problem is powering the system ,with the TX i got a cable that have a Yellow ,white for Audio Video
And a red banana like plug (maybe power?)
and also a black plug
The problem is i do not know what modification should i do to the 500mha 3s lipo plug and where is the correct power plug of the TX , where is + - etc
also the other problem is this
where is the + - inside the RX
Some pictures of you simplest setup will help me !
Thanks guys
Nettraptor is offline Find More Posts by Nettraptor
Old May 27, 2010, 07:12 AM
On a holiday?
boopidoo's Avatar
Uppsala, Sweden
Joined Sep 2008
It looks like my FOX Rx, it has a standard DC plug with the V+ on the central pin.
boopidoo is offline Find More Posts by boopidoo
Old May 27, 2010, 07:20 AM
Bath, UK
Joined Feb 2010
You should be able to check the polarity by looking at the power adapters for the symbol which specifies if the tip is positive or not. It also looks like my FOX rx, which also has V+ on the tip (central pin). Then you can hack a connector (I cut one off of the supplied power adapters) into something which connects to your battery.
blaireau is offline Find More Posts by blaireau
Old May 27, 2010, 07:55 AM
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
thanks guys i get it..
this is the one..
http://www.fpvsystems.com/index.php?...products_id=51
so another question is that i wanna make a Harness for the system BUT use it with a camera that has video out Camileo p10.. not with a mini 12v camera.. and 12mic
the harness for audio and video have to be connected to the battery of the tx? or i will damage the camera?
if i make something like that
and connect to the video wire and audio wire the Output of the Camileo p10 i'll have problem?
Old May 27, 2010, 08:32 AM
The Flying Circus
ommadawn's Avatar
Adelaide South Australia
Joined Sep 2007
That looks ok for a mini 12v cam but cant see how you are hoooking in to the mini camcorder.
ommadawn is offline Find More Posts by ommadawn
Old May 27, 2010, 08:39 AM
MK Addict
Nettraptor's Avatar
Hellas
Joined Jun 2009
Originally Posted by ommadawn View Post
Looks ok to me. I would seal the whole lot with another single piece of heatshrink. I assume you are using a 12v camera? I accidentally fried a 5v camera once. I chopped up the camera lead and just used the plug. Wasnt aware that there was a 5V regulator moulded in to the camera lead. Ouch.
the camera is this
and i'll use it standard with her battery, i will not make any mods , just connect the video out to the TX... the camera is 5v
Old May 27, 2010, 08:47 AM
The Flying Circus
ommadawn's Avatar
Joined Sep 2007
In your pic you mentioned connecting video + to audio, vtx and battery+. Where is the video+ coming from if you are only connecting the video signal and -?
Discussion Likely FPV Candidate Elektro Rookie S by Graupner Neo360 Video Piloting (FPV/RPV) 26 Sep 24, 2010 09:06 AM
Discussion Camera SetUp? What frequence for Video? How much Power TX? bob4432 Video Piloting (FPV/RPV) 6 Jun 09, 2010 05:20 AM
Discussion Best rx & tx for FPV? metalfred Video Piloting (FPV/RPV) 16 May 08, 2010 12:14 AM
Sold 2 Watts TX/RX 2.4ghz for FPV crd Aircraft - General - Miscellaneous (FS/W) 4 May 07, 2010 08:35 PM
Sold FPV 2.5 1000mW, Tx, Rx. 250mW Tx Beauregard Aircraft - General - Miscellaneous (FS/W) 1 May 03, 2010 05:01 PM
