| Wingspan: | 47" (1194 mm) |
| Wing Area: | 390 sq in (25.19 sq²) |
| Weight: | 27 oz (770g) |
| Length: | 39 in (991 mm) |
| Servos: | Four 9g servos (dual aileron) |
| Transmitter: | Tactic TTX404 4-channel 2.4GHz |
| Receiver: | Tactic 6 channel 2.4GHz receiver |
| Battery: | Flyzone 1800mAh 11.1V LiPo |
| Motor: | brushless |
| ESC: | 25amp electronic brushless speed control |
| Typical Flight Duration: | about 10 minutes |
| Manufacturer: | Flyzone Planes |
| Available From: | Hobbico |
| Price: | $199 |
The SkyFly Max is the first member of Flyzone's Sport Series of Ready to Fly aircraft. It is fully ready to fly, features durable Aerocell foam construction, and boasts a power setup that's likely to put many other "RTF" airplanes to shame. From simple relaxing cruising to full sport level aerobatics, the SkyFly Max has no trouble handling whatever the pilot asks it to do.
The SkyFly Max arrives in a very small box. So small, I was worried the wrong plane had shown up at my door! Don't be fooled though- the small box is the result of some extremely compact packaging. I couldn't even find any "wasted" space in the box!
Out of its box, the SkyFly comes mostly ready to go, with only some minor assembly required. The build took me 30 minutes from ripping open the box to being ready to hit the field. Before starting on the build, plug the included 3s 11.1v 1800mAh battery into the included balance charger (so it will be ready by the time the build is finished).
The wings of the SkyFly Max come pre-installed with servos. All that's left for you to do is connect them together. The included ply spar slides nicely into the plastic pockets in each wing, and does a great job of keeping the wings from flexing. A little tape (included in the box, of course) to connect the two, and it's ready!
The SkyFly line all have a fairly unique pod and boom style fuselage. Assembly of this portion can be quick and easy, but it is very important. The boom comes pre-attached to the horizontal part of the tail- leaving the vertical tail attachment and fuselage attachment up to the pilot. The tail piece fits into the pre-formed slots perfectly, and requires a couple drops of CA to hold.
Boom and Fuselage joining can be tricky. Because the boom slides into a circular opening, it is very easy to inadvertently glue the tail on crooked. I found the easiest way to ensure a level installation was to hold the plane upside down, and level the horizontal element of the tail with the bottom of the fuselage. Be sure to apply PLENTY of CA all along the joint- as not applying enough can lead to disaster later. My first attempt was not sufficient to keep the tail in place, and it came loose on the first flight. Flying with a tail rotated 45º is not something I would want to happen again!!
The SkyFly Max comes Ready to Fly with the Tactic 4channel 2.4ghz radio and receiver pre-bound. All that needs to be done to complete the radio installation is to plug the aileron servos into the included Y-harness (already plugged into the receiver), and attach the push rods to the servos.
Once the wing servos are plugged into the Y-harness, be sure to check the orientation of the plugs. If one is plugged in backwards, the servo will not function. After the servo leads have been connected, the wing nicely fits into its grooved slot. The included rubber bands hold the wing onto the fuselage.
At this point, the manual calls for the push rods in the boom to be installed into the EZ-grip servo connectors. The instructions say to remove the servo arms from the servos, slide the push rods through the EZ-grips, then re-attach the arms to the servo. I found it a lot easier (and time saving) to do this step before I glued the boom in- allowing me to slide the boom AND push rods in at the same time. This saves having to remove the servo arms, then installing them again (while checking to be sure they are installed at the neutral point).
With the wing and tail attached to the fuselage, a simple click is all that is needed to slide the landing gear into place. The included 4 "AA" batteries need to be installed into the Tactic 2.4ghz transmitter, and then you are ready to check the servos.
When I first turned my radio on, the digital trims were not centered, but pre-trimmed to neutralize the SkyFly's control surfaces. This is helpful for a quick box-to-air transition, but I chose to spend the time manually trimming all the control surfaces.
Included in the kit is a nifty angle-checker for the elevator. The manual suggests 3º of "up" trim before flying, and the laser cut checker helps to quickly and properly trim the elevator. While checking all of my EZ grip connections, I found one of my aileron set screws to be fairly loose. A quick tightening with a screwdriver, and I was ready to put the propeller on for the final step. Even with this extra step, assembly still was very quick.
As soon as I had the SkyFly Max in the air, I could tell immediately this was a well mannered plane. It balanced perfectly with the battery in the back of the canopy, and was only slightly nose heavy with the battery shifted forward.
The SkyFly is a very floaty and graceful plane, gliding extremely well for a “sport” style aircraft. Once you open the throttle though, the big 8x6 prop on the back scoots it along very fast, especially out of a dive. The noise from that big prop on the back end is nothing but awesome!!
Taking off is easy with the SkyFly- whether it be a hand launch or taking off from the ground. Hand launches are very easy- just throttle up, and toss! The bottom of the fuselage is perfect for gripping and giving it an overhand toss into the air. There is no need to try an underhand toss- because between the lack of a good spot to hold it and the 8” of spinning fury on the top, you’re probably best off keeping your hand clear of that end. Ground takeoffs are easy as well, as long as you have a dirt or paved runway. Grass takeoffs are possible as well, but the grass must be very short. The SkyFly Max has no tail wheel, so the bottom of the tail is chewed up very quickly. Placing a piece of protective tape on the bottom will help to keep the tail from getting too dirty or scuffed up.
The SkyFly is even so floaty, it is fairly easy to grab it out of the air. Line up into the wind, cut the throttle, and fly the plane towards yourself with your Aileron/Elevator stick, and get the other hand ready to grab it. This may end in many stalls close to the ground, but the SkyFly shrugs it off easily.
Although the SkyFly Max caters towards beginner 4 channel flyers, it also is a great introductory acrobatic plane. Inside and outside loops, rolls, stall turns, inverted flight- it’s all possible with the SkyFly Max.
The Ailerons have the perfect amount of authority for a learning 4 channel pilot, and can easily be adjusted for more control for advanced pilots. Rudder and elevator control is plenty sufficient for a beginner. Knife edge flying is almost possible with the stock setup, and even outside loops are manageable from the available elevator throw.
I always suggest slow 3 channel planes to new RC flyers, as adding aileron control can be tricky to grasp at first. The SkyFly makes a great 2nd plane though- it can fly very tame as the pilot masters 4 channel control, and can also be a perfect plane for beginning aerobatics.
At the end of the day, the SkyFly Max is a great plane to have in your hangar, regardless if you are learning 4 channel flight, or a seasoned expert. It’s super tough, unique looking, and relaxing to fly. Also, thanks to the rear mounted propeller and plenty of power on tap, the SkyFly has the capability to be a great Aerial Photography or FPV aircraft.
Pluses:
Minuses:
Special thanks to Trevor McKinney for his photos, Flyzone for supplying the SkyFly Max, and our Editor Angela for all her hard work!
| Thread Tools |
| Thread Tools | |
| Article Flyzone Playmate 2.4Ghz RTF Review | Kmart | Micro RTF | 103 | Jan 18, 2013 09:32 PM |
| Article Flyzone Micro RTF Albatros Biplane Review | Michael Heer | Micro RTF | 149 | Nov 30, 2012 06:25 AM |
| Discussion Flyzone's Sky Fly 2 - RTF | Russ The Flyer | Parkflyers | 4 | Sep 28, 2010 06:05 PM |
| Question FlyZone Sky Fly Elec. RTF | call0300 | Electric Plane Talk | 3 | Jan 12, 2008 07:12 AM |
