Old May 26, 2010, 04:58 AM
kapteinkuk is offline
Find More Posts by kapteinkuk
Quad Whisperer
Joined Jul 2008
ESC Response Testing
I have tested a few different ESC's for throttle response time, that is, the time from full throttle given to the ESC gives full motor power.
Note that the test starts a low throttle (running motor), not zero, so the start up delay is not included.
This scope screenshot shows a turnigy plush 30a ESC's response to a instaneous increase in throttle from low to full. (1.1 to 2 mS at 50Hz PPM)
Red trace: motor current.
Yellow trace: PPM signal
100Hz.
A doubling in PPM frequency halves the ESC's response time, thus makes it possible to use higher gain, and therefore making the quad more stable.
This ESC and most other I have tested uses a finite response low pass filter based on the PPM frequency, on the throttle.
The filter has 7 steps at the biggest difference in the throttle, less at smaller differences.
200Hz.
400Hz.
Tested ESCs response time at 50Hz:
Unknown #1 (99% sure it is a Jeti Advance 8A, according to the owner): 80mS
Notes: very good
Turnigy Plush 30A: 137mS
Turnigy Plush 10A: 137mS
Turnigy Plush 6A: 137mS
TowerPro H40A:: 137mS
HK-HW30A: 137mS
Turnigy K-Force 40A: 175mS
Waypoint 15A: 200mS
HK 10A: 200mS
Turnigy Super Slow Brain 20A: 200mS
Notes: Response time is constant regardless of PPM frequency. Uses a constant time base for the filter, not the PPM frequency.
Otter BS 40A: 390mS
Notes: Also filters high to low throttle
Hyperion 10A: 490mS
I will update the list as I get my hands on more ESC's
kapteinkuk is offline Find More Posts by kapteinkuk
Old May 26, 2010, 05:27 AM
dcaspi is offline
Find More Posts by dcaspi
destructive testing expert
dcaspi's Avatar
Kiryat Yam, Israel
Joined Apr 2009
I believe the response time, at least for the Plush I have, is programmable. Which setting did you use?
Dror
dcaspi is offline Find More Posts by dcaspi
Old May 26, 2010, 08:22 AM
elossam is offline
Find More Posts by elossam
Joined Feb 2006
Are these tests done with the engine loaded with airscrew or not?
This graphics show i.e. the difference in engine response when using a simple ESC conected to a std receiver vs. the use of a ESC based in I2C like the ones of mikrokopter and others or the I2C has nothing to do here?
Any other ref about the Unknown #1: 80mS unit?
elossam is offline Find More Posts by elossam
Old May 26, 2010, 10:28 PM
rimshotcopter is online now
Find More Posts by rimshotcopter
rimshotcopter's Avatar
Joined Aug 2009
Not sure I am understanding here, of the ESCs tested, which one has the best response time?
thank you.
rimshotcopter is online now Find More Posts by rimshotcopter
Old May 27, 2010, 07:14 AM
Quad Whisperer
Joined Jul 2008
Dror
I have tried every setting. Still the same response.
Old May 27, 2010, 07:21 AM
Quad Whisperer
Joined Jul 2008
Tests is done with propeller. However, the response is the same without.
This has nothing to do with PPM vs I2C. It is simply the time elapsed from the ESC has recieved throttle change, until new power output from ESC is reached.
It also excludes RPM delay due to inertia. This is only the delay internal the ESC.
The unknown unit is a Jeti Advance 8A according to the owner.
Old May 27, 2010, 07:28 AM
Quad Whisperer
Joined Jul 2008
thank you.
The shortest time is the best, currently the 80mS unit.
Shorter delay means faster response in the whole system.
System is: gyro -> FC -> ESC -> motor -> propeller -> aircraft inertia
Old May 27, 2010, 07:31 AM
Joined Aug 2009
Thank you
Old May 27, 2010, 07:40 AM
cyborgcnc is offline
Find More Posts by cyborgcnc
The Drones are Coming!!!
cyborgcnc's Avatar
New York, NY
Joined Feb 2010
Thank you very much for doing this testing kaptein!
VERY useful information!
What software are you using, and what PC scope?
cyborgcnc is offline Find More Posts by cyborgcnc
Old May 27, 2010, 07:54 AM
jesolins is offline
Find More Posts by jesolins
Tri-Quad-Hexa-Octo-copters!!
Joined Feb 2007
Rolf,
Thanks for sharing this info. Along with the response time you measured, how do the number of steps an ESC has factor into the final quad control smoothness?
HKSS and Mystery ESC's are good PWM performers for quads too as well as being good I2c modification candidates. The Mystery ESC's have the very friendly quad and tricopter feature of being able to completly disable the LVC.
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
jesolins is offline Find More Posts by jesolins
Old May 27, 2010, 08:42 AM
dcaspi is offline
dcaspi's Avatar
Kiryat Yam, Israel
Joined Apr 2009
One important conclusion about control loop rates:
There were debates on the Quaduino and other threads that discussed controller software, about what sampling frequency of the control algorithm is required for stability. some even exaggerated and said that 1000Hz is required. My own experience has shown 100Hz to work very well.
Now, if the response times are 80msec or slower, then I would guess you could safely reduce to loop rate to, say, 30Hz with no impact!
Dror
Old May 27, 2010, 11:41 AM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
As I have 3 of the Jeti Spin 22 I would very much like to know the response time of these. The manual says it can be programmed down to 200mS.
Tritan
tritan is offline Find More Posts by tritan
Old May 27, 2010, 11:48 AM
outsider787 is offline
Find More Posts by outsider787
outsider787's Avatar
Canada, ON, Toronto
Joined Dec 2007
Keptein,
Interesting figures you've discovered for full throttle response.
It's not often that full throttle is given from a low rpm.
If only part throttle is given, is it safe to assume an equivalent fraction of the response time is needed?
So if only 1/10 of throttle adjusting is needed, can it be assumed that the response time is 1/10 of full throttle response to achieve the adjustment?
outsider787 is offline Find More Posts by outsider787
Old May 27, 2010, 05:28 PM
Quad Whisperer
Joined Jul 2008
The scope is a Owon PDS 5022, borrowed from a friend.
Old May 27, 2010, 05:35 PM
Quad Whisperer
Joined Jul 2008
Originally Posted by jesolins View Post
Rolf,
Cheers,
Jim
Are you thinking of number of throttle steps (resolution)?
I was thinking of number of steps (PPM pulses) for the filter to reach final throttle value. It has no impact on smoothness.
Discussion Testing ESC's? pdown1231 Power Systems 3 Feb 23, 2010 07:02 PM
Help! Hobbyzone Super Cub LP No Response from ESC/RX bladerunner2 Power Systems 0 Nov 14, 2009 12:30 AM
Help! Weird motor/ESC response to differant batteries. c/f Power Systems 19 Oct 26, 2009 06:49 PM
Video video of cyclic response testing : EVO450 GIGA_RC Electric Heli Talk 3 Sep 02, 2008 12:18 PM
Question ESC Response at low throttle. RGinCanada Dock Talk 14 Jan 07, 2005 01:36 PM
