Old May 25, 2010, 05:02 AM
3Don is offline
Find More Posts by 3Don
3Don's Avatar
Joined Nov 2004
New axi2203/40vpp
Hi guys, i have interesting news to share. After IITOP competition when we saw Andres Leoni experiments with 2203/46 motor and VPP, we decide to tune this engine and make special version for Mamo models Upsidedown system. Martin Muller, Andres Leoni, Gernot Bruckmann and myself were involved in helping AXI make right adjustments. And here is result AXI 2203 /40VPP, specially designed to fit Martin Muller upsidedown propeller. I will be testing new motor in MM Extra 300 that i won in last German F3P championship organized by DMFV. I still like Sultimate, but decide i want to try something new, besides if i don't do it now i have feeling this kit will stay not assembled for long time
Here is prototype test by Andres:
test2203/403607,4 (2 min 58 sec)
test2203/40360-7,4 (3 min 0 sec)
3Don is offline Find More Posts by 3Don
Old May 25, 2010, 05:45 AM
JanneL is offline
Find More Posts by JanneL
Janne Lappi, F3A Team Finland
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
This will be an interesting new little motor! What is the power like compared to normal AXI 2203/46 or Race? What kind of servo does this need?
When will this be available?
Janne Lappi
JanneL is offline Find More Posts by JanneL
Old May 25, 2010, 06:43 AM
3Don is offline
3Don's Avatar
Joined Nov 2004
Janne i would guess power will be between 46 and Race. 18,5g motor capable of VPP flyin on 2s is very nice for small light models and small European halls. From Andres experience, plane weight is very important. Goal with this motor is about 150g rtf.
I know Gernot and Devin had some tests with Upsidedown prop and and Race motor, in that case motor become hot, so this really was not option for average customer. In any case with super light plane trust was impressive:
2010 ETOC Devin McGrath Freestyle 1.avi (2 min 50 sec)
For release date, i will let you know as soon as i hear back from AXI.
Old May 25, 2010, 06:51 AM
xtremeRCpilot is offline
Find More Posts by xtremeRCpilot
xtremeRCpilot's Avatar
Cleveland, Ohio
Joined Sep 2006
WOW, that is awesome Don!! I was hoping to see this combo, the AXi motors are all I use mainly the 2203-46 for my indoor models, this will make a great combo. I have a Mamo unit waiting for this motor
John
xtremeRCpilot is offline Find More Posts by xtremeRCpilot
Old May 25, 2010, 11:37 AM
Devin McGRath is offline
Find More Posts by Devin McGRath
Team Futaba
Devin McGRath's Avatar
Rochester New York
Nice spinner Don
Devin McGrath
Devin McGRath is offline Find More Posts by Devin McGRath
Old May 25, 2010, 12:07 PM
3Don is offline
3Don's Avatar
Joined Nov 2004
Yes Devin bling bling spiner from capable airplane, thx again for it mate. By the way what size blades you and other pilots were using in ETOC?
Old May 25, 2010, 01:25 PM
3D-Seth is offline
Find More Posts by 3D-Seth
3D-Seth's Avatar
United States, FL, North Port
Joined Jan 2007
Donatas,
I used 8" blades but on a 3S battery. Most others used 9" on 2S batteries.
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old May 25, 2010, 02:22 PM
JanneL is offline
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Can the axi /40vpp handle 9" vpp prop with 2s?
What kind of servo do you ETOC guys use in vpp?
Janne Lappi
Old May 25, 2010, 03:35 PM
Team Futaba
Rochester New York
I used 8" on 2 cells
Devin McGrath
Old May 25, 2010, 05:01 PM
aleoni is offline
Find More Posts by aleoni
Joined Jan 2009
Hello.
Janne Lappi, I use Dymond D47 for VPP, this servo work very well for this system, and the weight is just 4,7 grams. Mr Martin Muller use a little servo (3,7 grams) and work perfectly on his Extra.
About blades, i prefer 9" for 2S setup, with 360 mha and 25C in continuos i made 3 minutes constantly negative torque roll. The plane, like DOnatas said, must weight 150 grams, less is better for sure.
Is a very fun system and motor because the low mass, i crash a lot of times my plane training and I need just change the blades!!!
I hope this help you.
Regards.
Andres Leoni.
aleoni is offline Find More Posts by aleoni
Old May 26, 2010, 01:43 AM
Andycap is offline
Find More Posts by Andycap
Inspired by the wings of an An
Andycap's Avatar
Leeds
Joined Mar 2003
Cant wait as I love my axi 2203 motors and really look forward to trying this set up
Andycap is offline Find More Posts by Andycap
Old May 26, 2010, 04:15 AM
JanneL is offline
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Thank you Anders. I'm surprised about the small size of the servo. I thought it has to be much stroger. I've heard that with other vpp systems servo has to be stronger than an average indoor plane servo. So it's very nice to be able to use that light servo, as you said, the lightness of an indoor plane is very important and the vpp adds always some weight. I've noticed 150g is maybe a bit too much for about 85cm Freestyle/3d plane. 140 and above it are good.
How do you use the variable pitch feature on your throttle stick, is there some standard style to set the throttle positions and flight modes? Is the vpp always on or do you have a flight mode for normal flying, too?
Old May 26, 2010, 05:24 AM
aleoni is offline
Joined Jan 2009
Hello.
Normally I use a Heli program for VPP style. Is the best way for keep the control in normal phase of flight. Program Normal phase, this is only with positive pitch, works like standard propeller and the function is very simple, lineal throtle curve. In Idle up 1 the program is different, here we have postive and negative pitch with "V" throtle curve. The more important is the hold function, this help you in dangerous situation, is just throtle cut off.
Hope this help you.
Regards.
Andres Leoni.
Old May 26, 2010, 08:59 AM
aleoni is offline
Joined Jan 2009
Hello friends.
Here a put other view from the same video on You Tube:
Andres Leoni, Prueba de Motores Modificados HD. (2 min 53 sec)
Regards.
Andres.
Old May 26, 2010, 11:18 AM
JanneL is offline
JanneL's Avatar
Helsinki, Finland
Joined Sep 2008
Thanks again Andres, it will help!
Is this VPP system that you use exactly the same as the one that mamo-models sells on their web site?
http://www.mamo-modelltechnik.com/pr...er/upsidedown/
I'm thinking to try this VPP with 46 axi. First I could broke my old 46 by training VPP flying (=crashing) and then buy the new /40 motor
New Product The new blade sr/advice for new heli BLADEMCX Micro Helis 17 Mar 22, 2010 02:17 AM
For Sale Tamiya tb-02>>>new new new!! lectroglide Cars - Cars and Parts (FS/W) 0 Nov 14, 2009 12:23 PM
Sold Hellfire SS RTR ...New ad...new pics...NEW Price lwkoss Cars - Trucks and Parts (FS/W) 5 Oct 26, 2009 10:35 PM
Sold new Hitec Laser 4 tx; MFS-04 rx; 2 New Hitec 1425CR servos; 1 New DX mystery HH gyro airsoft1779 Aircraft - General - Radio Equipment (FS/W) 1 Oct 06, 2009 11:25 PM
Sold Brand new T-REX 450 XL CDE NEW NEW NEW scottb Aircraft - Electric - Helis (FS/W) 7 Nov 18, 2005 08:10 PM
