Old May 25, 2010, 03:38 AM
Yardbee is offline
Find More Posts by Yardbee
Yardbee's Avatar
United States, CA, Blythe
Joined Jun 2004
Gold Wing RC SBACH-342 50CC
Hello: I just picked up the 50CC GW SBACH-342 & will be converting to Electric. I'll be using the following equipment.
Motor: Hyperion Z-5045-18 & 22 X 10 Zoar Prop (3200) watts max on 12S
Turnigy Sentilion 100 Amp HV ESC
2 6S 25C Turnigy 5000Mah lipo packs
5 Power HD 1501 MG servos
Its one very nicely made ARF & construction looks solid.
Yardbee is offline Find More Posts by Yardbee
Old May 25, 2010, 06:15 AM
staggerwing is offline
Find More Posts by staggerwing
In NY's beautifull hills
staggerwing's Avatar
Binghamton Broome Cty, New York, United States
Joined Jun 2004
Great looking bird !
Did a quick search as for a price & source but all appeared to be off shore--would you mind sharing your cost & source ?
Whls & pants seem a bit dainty---maybe not for grass ??
Guess I found a source--Red Wing RC---waiting for a quote
staggerwing is offline Find More Posts by staggerwing
Old May 25, 2010, 07:25 AM
lmopar69 is offline
Find More Posts by lmopar69
Team Cobra!!! Ssssssss!
lmopar69's Avatar
United States, NE, Doniphan
Joined Feb 2005
That is a great looking plane. I really like the lines of it. I also would be quite interrested in what the cost is for the airframe.
EDIT: Looked it up, not a bad price at all! might have to get me one to have for when I get home from Afghanistan!
Laine.
lmopar69 is offline Find More Posts by lmopar69
Old May 25, 2010, 08:30 AM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
Nice looking plane Yardbee. A buddy of mine has the Pilot Sbach and loves it.
http://www.chiefaircraft.com/rcmsec/...C/SBach29.html
Ben
Ben-Rod is offline Find More Posts by Ben-Rod
Old May 25, 2010, 02:34 PM
jbarnes is offline
Find More Posts by jbarnes
United States, CO, Longmont
Joined Feb 2007
You might want to reconsider those HD servo's. I've seen two planes with those servo's have flight control problems. Both had issues with centering under load. Replaced them with Hitec servo's and had no issues. Jerry.
jbarnes is offline Find More Posts by jbarnes
Old May 25, 2010, 07:29 PM
Yardbee is offline
Yardbee's Avatar
Joined Jun 2004
Hi Jerry: Its seems to be a hit & miss with the Power HD's! Ive seen them perform flawlessly & have some issues. I really haven't decided which servo's to use yet, I just have 5 of these in the shop!! Thanks: Joe
Old May 25, 2010, 07:35 PM
Yardbee is offline
Yardbee's Avatar
Joined Jun 2004
Staggerwing: I got the SBACH in a trade from my buddy @ www.vallerviewrc.com he got it directly from Goldwing as a sample. From what Ive heard, the Goldwing 50Cc SBACH will be available in US by the end of June: Cheers: JP
Old May 25, 2010, 09:57 PM
OzparkPilot is offline
Find More Posts by OzparkPilot
Watts up ?
OzparkPilot's Avatar
Australia, NSW, Sydney
Joined Nov 2006
Hey - Looks great and will be doing one to soon. I built the Goldwing MX2 57` and did a review on RCG a few month back. Really nice plane.
OzparkPilot is offline Find More Posts by OzparkPilot
Old May 26, 2010, 12:33 AM
drstillpatient is offline
Find More Posts by drstillpatient
Joined Aug 2006
Yardbee, I am almost done with an electric conversion of a Sbach 50cc from a different manufacturer and had also looked at this one.
I've used the same motor as you have with 12S 5000mAh li-po. Would you consider a bigger diameter prop than the 22x10?
Good luck!
drstillpatient is offline Find More Posts by drstillpatient
Old May 26, 2010, 05:25 AM
Yardbee is offline
Yardbee's Avatar
Joined Jun 2004
Hi Guys: Thanks for all of the really nice Compliments!!! Drstillpatient: I am using the same power setup on on a 87" yak-54 only because Hyperion specs recommended that prop size. I have read where a 24 X 12 was also being used with good results for short periods of time. I am willing to try different props, any suggestions?
Thanks: JP
Old May 26, 2010, 06:29 AM
Joined Aug 2006
Thanks: JP
Yardbee, go with what provides you the performance and thrust. I've only used the Xoar 24x10 and Xoar 24x12 electric props on this motor and its been happy. How is the vertical with the 22x10 prop on the Yak and what flight times do you get? If you get good performance with a 22x10 prop on the Yak with its large round cowl, then this Sbach should have no problems at all.
Any pics of the interior of the plane?
Cheers!
Old May 26, 2010, 11:56 AM
Swen is offline
Find More Posts by Swen
Passion
Joined Sep 2009
I would also like to se the interior of the plane. How does the quality compare to the more expensive Pilot ARF. Then there is one from "GuiLin XinYing FeiXiang Aircraft Model Co." as well for cheaper. Anybody know about that one?
Swen is offline Find More Posts by Swen
Old May 26, 2010, 12:02 PM
Yardbee is offline
Yardbee's Avatar
Joined Jun 2004
Drstillpatient: The 22 X 10 Yields me 3100 watts (specs are 3200 watts for 10 seconds max) & plenty of vertical, and with some throttle management I get a solid 8 minutes of IMAC style of flying. The 24 X10 is well worth a try, I am also going to give a 3 bladed Xoar 22 X 8 prop a try. It would sure look wicked on the nose. I'll get some pictures of the interior posted today. Cheers: JP
Old Jul 13, 2010, 06:01 AM
dale69101 is offline
Find More Posts by dale69101
Joined Jan 2006
Just wondering what type of hardware it comes with. Is it the fiberglass horns like the 30cc planes and is there a tunnel for a canister muffler?
Cheers Dale
dale69101 is offline Find More Posts by dale69101
Old Jul 20, 2010, 05:42 PM
Redwing RC is offline
Find More Posts by Redwing RC
Redwing RC's Avatar
Ballwin MO
Joined May 2010
Hey guys - I have the orange 50cc available first week of July. ONLY 8 of them , and have a few spoken for already. If you have questions let mek now. this version has metal posts and ball links. The 30cc MX2's I have do have the fiberglass horns and canister.
If you have any questions let me know.
Redwing RC is offline Find More Posts by Redwing RC
Site Sponsor
New Product Pilot RC's SBach 342 30cc!! FlattyFlier Scale Fuel Planes 28 Dec 29, 2010 08:28 PM
Discussion New SBach 342 and MX2 - by Redwing RC Redwing RC 3D Flying 27 Sep 02, 2010 05:25 PM
Cool Sbach 342 - The wait is over!! FINALLY RC! rcxmachines Giant Scale Airplanes 85 Jan 20, 2010 02:47 AM
Video Sbach 342 - The wait is over!! FINALLY RC! rcxmachines Fuel Plane Talk 0 Aug 21, 2009 01:29 AM
Discussion Two Seat Sbach 342 james-bai Fuel Plane Talk 1 Jul 21, 2009 12:05 AM
