Old May 23, 2010, 06:16 PM
$WMc% is offline
Find More Posts by $WMc%
Its not rocket surgery
$WMc%'s Avatar
Joined May 2010
BS2 and the sabertooth 2x25
Hello All
I'm new to this forum so please bare with Me.
I have a new D.E.sabortooth 2x25. I want to control this with a BS2 using simple serial commands. So far my results have been random at best.
The D.E. Docs state that sending a "character" of 1 - 127 will control M1 and 128 - 255 will control M2. The Docs also state the 64 is the center-off value for M1. This does not stop the motor on M1 however I can send a 0 and stop the motor.0 is the ALL-Stop command for the 2x25.
Its more than obvious that 127 is not half of 255 (127.5) and half of 127 is not 64 center-off (63.5). Is this a program problem with the D.E.2x25?
Has anyone had any luck with simple serial and the D.E.2x25??
$WMc% is offline Find More Posts by $WMc%
Old May 23, 2010, 06:25 PM
jettrooper02 is offline
Find More Posts by jettrooper02
jettrooper02's Avatar
USA, WA, Bonney Lake
Joined Aug 2008
wait whats happening? i think i know of the esc your using, isn't it a dualmotor speed control? it sounds like(if i'm getting this correctly) that your esc isn't stopping the motors when it is supposed to. i think the only way would be to find a way to program it to work. but i'm still not sure of the issue.
jettrooper02 is offline Find More Posts by jettrooper02
Old May 23, 2010, 06:49 PM
$WMc% is offline
$WMc%'s Avatar
Joined May 2010
jettrooper
You remind me of snake-guy.You know the guy with the snake around his neck,The guy whos desperately seeking attention.And then one night his snake gets out and | You know rest.
Thanks for the reply____________$WMc%
Old May 24, 2010, 04:21 AM
nickelflipper is offline
Find More Posts by nickelflipper
Oregon, USA
Joined May 2010
Have you got both motors going forwards and backward? Is that the problem, or just finding center off?
My read on it is with a character over serial, is like a serial print or Bin2Ascii command. So going full forward would be something like SerPrint ("127255"), stop SerPrint ("064192"), and full reverse SerPrint ("001128"). If that's not working for you, then check the baud rate, or any other settings that are required.
As far as the center off of 64, and 192, just go with the flow and not worry about splitting hairs.
nickelflipper is offline Find More Posts by nickelflipper
Old May 24, 2010, 04:28 AM
m4rs is offline
Find More Posts by m4rs
Happy Trees
m4rs's Avatar
Colorady
Joined Mar 2005
whats this have to do with rc off road cars?
Im sure theres a better section to discuss programing this somewhere else.
Try asking here
http://www.rcgroups.com/diy-electronics-199/
if you are seriously looking for an answer...
m4rs is offline Find More Posts by m4rs
Old May 24, 2010, 08:01 PM
Joined Aug 2008
jeeze, i'm just trying to help. i was going to get into the lightwieght 12lb class battle bots awhile ago, and that was the type of esc that we'd have to use.
Video OSD-232 with BS2 and PING range finder phoglite Electric Plane Talk 1 Jun 08, 2007 07:02 PM
Discussion Memsic MXD2125 Inclinometer with Parallax BS2 Geometrix UAV - Unmanned Aerial Vehicles 0 May 24, 2007 06:40 PM
