Old Nov 03, 2012, 08:36 PM
AndyKunz is online now
Find More Posts by AndyKunz
AndyKunz's Avatar
Illinois
Joined Sep 2001
Time to revive this thread!
I was supposed to be working on a Kraft radio conversion but I forgot my battery! So I pulled my 40"-ish Shrike off the "work on me" bench and started back on it today. Instead of the Habu 32 fan system I decided to go with a Power 25. The fuselage sides are sitting on the bench now with the glue drying.
Photos soon!
Andy
AndyKunz is online now Find More Posts by AndyKunz
Site Sponsor
Old Nov 03, 2012, 09:46 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Here you go. The fuselage is 3" wide internally simply because it made it easy for me to do and have lots of room. I want to stick a lot of telemetry toys inside.
It's going to be a little boxy, too. I'm getting pumped up now!
Andy
Site Sponsor
Old Nov 05, 2012, 10:12 AM
nickeast is offline
Find More Posts by nickeast
nickeast
United States, FL, Vero Beach
Joined Mar 2009
Looking good....
nick
nickeast is offline Find More Posts by nickeast
Old Nov 07, 2012, 09:34 AM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Started a new thread to document the big Shrike. Find it here: http://www.rcgroups.com/forums/showthread.php?t=1765875
Andy
Site Sponsor
Old Nov 26, 2012, 02:20 PM
4dogspete is offline
Find More Posts by 4dogspete
Land O Lakes, FL
Joined Jun 2007
First Shrike 40
Fianlly got aroudn to finishing up the Shrike 40.
Added retracts - probably should have examined Andy Kunz's build detail.
Saw somehting about the front gear door, but did not think that would work without another servo.
Powered with a Webra 50. Have pipe for it, but wanted to start with a fairl stock but hot engine.
I believe the retracts are from Hobby King - says no greater than 2.5KG which is about 5#.
All up finished - dry weight is 4.5#.
Not too surprising since most of my models come out on the heavy side.
Also adding to the weight - had to add 6 oz of lead in the tail to make the CG come out per the plans.
Haven't had it's maiden yet - actually waiting to find some canopy glue to seal up the canopy. Don't want Mr Einstein to get too drafty.
Any clues on the first flight off a grass field???
Pete
4dogspete is offline Find More Posts by 4dogspete
Old Nov 26, 2012, 02:27 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Pete,
That looks really nice! Great job!
You'll be fine without a door, you have a nice skinny slot to retract into. As long as nothing gets bent you should be golden.
I found that with the gear down it needs a bit of up-trim to compensate for the extra drag. Nice color scheme. You're going to love it!
First-flight videos are mandatory!
Andy
Site Sponsor
Old Nov 26, 2012, 03:50 PM
Land O Lakes, FL
Joined Jun 2007
Thanks Andy - My thumbs will be shaking!
Pete
Old Dec 02, 2012, 08:31 PM
nickeast is offline
nickeast
Joined Mar 2009
4dogspete,
Nice build .... just fly it ... grass might be a little tuff depending on the size of wheels that you have.
Nick
Old Dec 23, 2012, 12:14 AM
crazyflyer92 is online now
Find More Posts by crazyflyer92
United States, FL, Sunrise
Joined Oct 2012
nickest its jeff from markham im gonna get started on mine with the werba 40 soon
crazyflyer92 is online now Find More Posts by crazyflyer92
Old Dec 23, 2012, 09:04 AM
Land O Lakes, FL
Joined Jun 2007
I did the maiden thing - twice so far. The first time it didn' t get off the ground becuase the wheel struts just were not stron enough and it bent one of the struts. Also I had to reinforce the front wheel mount by adding a plywood mount across the fuse to support the front retract servo.
All that fixed, and moving the battery fully to the rear and removing some of the rear weights, rechecked the CG balance and went back to the field to do another maiden. This was an Oh My - it turned out to be quite tail heavy.
Some of this is due to where I mount the fuel tank which is behind the CG due to the normal place for the fuel tank being occupied by the front retract and servo. So it was pretty scary and I killed the motor and tried to hold full down just to keep it straight, and it went into some high grass moving pretty slo. I was so surprised that it just did not snap when flying so slowly - just went in at about a 20 degree angle and did not do much damage at all.
Now I've reset the G a bit nose heavy by removing virtually all of the rear weights except for the 4-cell NiCad battery.
Will give it a shot again later this week - allowing for lower wind conditions and will post results.
Pete
Old Dec 23, 2012, 01:30 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
It will fly slow if you can slow it down, but you're right, once it decides to depart you're just along for the ride!
Andy
Site Sponsor
Old Dec 23, 2012, 01:34 PM
nickeast is offline
nickeast
Joined Mar 2009
Pete,
The CG on thid plane is very sensitive.... get it where the plans call for .... esp for the first few flights and then find the sweet spot. Remember a forward CG flies poorly and an aft CG flies ONCE.....
Nick ( I do a lot of crash testing)
Old Dec 23, 2012, 01:55 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
Crash testing or Test Crashing, Nick?!?!?
Andy
Site Sponsor
Old Dec 24, 2012, 12:28 PM
nickeast is offline
nickeast
Joined Mar 2009
Andy,
Test crashing seems to be the most often.... results arre always bad.
Merry Christmas!!!!
Nick
Old Dec 30, 2012, 03:34 PM
nickeast is offline
nickeast
Joined Mar 2009
Ok... I'm at the farm this week and the WX has been awful ... so I did not bring any toys. Somebody must have done something..... I need a Shrike Fix
Nick
Discussion Shrike Build Question isoarthenland Slope 56 Aug 10, 2007 08:27 PM
Aerocommander Shrike build jzanutto 1/2A Planes 19 Sep 18, 2005 11:15 AM
Shrike Build Correction SkyKing RC Slope 4 Dec 11, 2004 10:13 PM
Shrike Build Suggestion SkyKing RC Slope 4 Aug 16, 2004 06:14 PM
