Old Jun 05, 2010, 09:21 AM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Originally Posted by Sub culture View Post
Interesting way that hull is moulded, the lower hull is clearly two pieces, which it would have to be to clear the undercut. The deck looks like a one piece mould though, that perhaps is glassed in afterwards?
Is the hull polyester or epoxy resin?
Hello Sub culture,
The Hull is made of polyester with gelcoat, the deck is one piece and indeed glassed in afterwards, but for sure not made of Resin.
Only the lathes are made of Resin.
Greetings,
Jan,
Horseman is offline Find More Posts by Horseman
Old Aug 07, 2010, 04:30 PM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hello all,
Just to let you know I'm still busy and I like to show you some results,
The back of the hull is almost ready,
I'm busy with the last Resin hatch as you can see.
Then a photo of the gun foundation and it was a lot of work but it pays off very well at least I'm happy with it.
And a photo of the tower.
And a little impression of the Sub.
Now I'm almost so far that I can built the WTC in the hull and built the Sub up with out grinding 10000000 holes...
Kind regards,
Jan.
Old Aug 07, 2010, 04:44 PM
Jeff Van Hofwegen is offline
Find More Posts by Jeff Van Hofwegen
Joined Feb 2010
Beautiful work Jan! I get a headache just looking at all of those holes to be opened. What a massive job.
best wishes,
jeff
Jeff Van Hofwegen is offline Find More Posts by Jeff Van Hofwegen
Old Aug 14, 2010, 05:34 AM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
Fantastic.
Thanks for the pictures!
SJ is offline Find More Posts by SJ
Old Sep 19, 2010, 11:52 AM
DDG 51 is offline
Find More Posts by DDG 51
DDG 51's Avatar
EUrope
Joined Apr 2008
I get one of first Engels Type VII. This is most beautifull kit of sub, I ever seen. She is beautifull, and operates GREAT. Building go realy fast and easy. Everything fits.
DDG 51 is offline Find More Posts by DDG 51
Old Sep 19, 2010, 10:16 PM
Joined Feb 2010
How did you "fast and easy" cut out the one thousand openings?
best wishes,
jeff
Old Sep 20, 2010, 10:54 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hi Jeff,
I guess that he left that kind of work to somebody els
Sorry DDG 51 just kidding.
Greetings,
Jan.
Old Sep 20, 2010, 01:12 PM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
If you have the use a of a milling machine, it would certainly speed up slotting the deck.
Sub culture is offline Find More Posts by Sub culture
Old Oct 08, 2010, 03:47 PM
DDG 51 is offline
DDG 51's Avatar
EUrope
Joined Apr 2008
Driling and milling of thousands holes to the deck and hull was done for 3 days. I uses small diameter milling tools and drills. Everything make by hands.I do not know, how to put here pictures, I am sorry, but I will lern it. I will be back home on Oktober 22. I will put here some pictures. Making holes is a lot of work, but it is fun.
Old Oct 08, 2010, 03:55 PM
DDG 51 is offline
DDG 51's Avatar
EUrope
Joined Apr 2008
Horseman: Sorry man, I did not use for hole drilling guys from Vietnam or China. On my second submarine I developed good system for drilling or making of any type of holes to fiberglass. I will supply some pictures on end of the month. I am working out of states, sorry
Old Oct 09, 2010, 06:58 PM
alligator is offline
Find More Posts by alligator
skypirate
United States, FL, Sarasota
Joined Jul 2004
Very nice work Jan.
alligator is offline Find More Posts by alligator
Old Nov 05, 2010, 05:34 PM
DDG 51 is offline
DDG 51's Avatar
EUrope
Joined Apr 2008
On the pictures is step by step, how to make a milion holes to sub hull. You need strait steel bar, double site self adhesive tape, Dremel or similar tool, drilbit.And then just work
Old Nov 05, 2010, 05:39 PM
DDG 51 is offline
DDG 51's Avatar
EUrope
Joined Apr 2008
I do with this technology all holes to my fiberglass hulls, on the picture is hull of tug boat. On the end, is my final product, Engels Type VII
Old Nov 06, 2010, 03:46 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hello DDG51,
Thanks for your detailed explanation of how to deal with this kind of work.
And I can tel i do it in most cases the same way you did above.
However holding the spirit when making a very lot of this grindings holes can be become hard if you doing to much at the same time, your concentration will be decreasing and the change op mishaps will increase.
But your example is the way to do this.
Thanks for sharing,
At the moment the building continuous the rudders and dive planes in the aft are put in, the WTC tube is placed, the tower is almost ready, I'm started with the Guns, so its growing.
Regards,
Jan,
Old Nov 06, 2010, 07:42 AM
DDG 51 is offline
DDG 51's Avatar
EUrope
Joined Apr 2008
Hi, I am happy, when I can explain how to do something faster. My Type VII is ready for sea trail, but now I am again at work 2500 km from my house and for 5 weeks. Weather will be bad in december, for sub balancing.Next year I will be with Type VII in Neulengbach sub meeting in Austria
Cool 10 Foot Indoor C-47 Now with build pictures added R&RRC Foamies (Scratchbuilt) 132 Jul 18, 2014 02:24 PM
Build Log D-18/C-45, Build-up (ACME A.C. kit) Fly_Baby1A Scale Kit/Scratch Built 43 Jun 23, 2010 06:54 PM
Discussion C.N.C Machines are not necessary to build R/C airplanes! Mode One The Builders Workshop 38 Apr 20, 2010 12:35 PM
Question I want to build an Aviat Husky A1-C Vapor Trails Scale Kit/Scratch Built 26 Mar 19, 2010 07:28 PM
Engel Typhoon / Gato / U177 Build and Tips Wheelerdealer Submarines 40 Aug 07, 2007 10:27 AM
