Old May 23, 2010, 06:37 AM
Horseman is offline
Find More Posts by Horseman
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Build Log
ENGEL VII42/C Build report
Hello all,
After building the Engel Gato I have chosen as the next project the Master scale Type VII /c the most used German U-Boot.
After building the Gato with all his triumphs and difficulties I trust that I can coop with the building demands this Sub needs to make her looks and working nice.
There not that many Boulder reports as far I know off, and mainly the sailing part is missing in most reports.
Well this one must sail.
After buying by Internet the waiting begins for the packets arrives.
And after four days they came
BIG BIGGER BIGGEST
In the little Box are the resin and brass parts nicely sorted.
Look at this,,
The stanchions all ready.
The Guns,
Tower,
With Brass exactly fitting deck
The nose cone and electro motors unit waterproof tested till 12,5 meter
And ready to run.
And a lot more of all this nice pieces.
Then I opened the BIG box with the Hull inside.
And Engel knows how to pack his stuff.
And in close-up really very nice craftsmanship,
So you understand that I was very happy to see this high quality because its not a cheap kit so I expected a lot and it worth the money but its not a easy kit to built.
But it looks easily and there a lot of work being done already, but all the flood holes must be done by myself.
There are more than 1000 so I'm busy for a wile.
However I started with the Techrek.
The plates with CNC abs
First I put together the Motor section.
And it fit perfect.
Than the section on the top of the aft dive tank.
Then I made the revolver section were the battery's must fit in.
And on top of that the second dive tank will be fitted.
And than its look like this,
And it really looks great and its tall also
It fits almost without any flaws, But there was a problem with the frame extension and one of the switches of the front dive tank.
And I can not find any reason why this frame are located there, so I take it away to make room for the switch..
So far the beginning of this report,
Greetings from Holland,
Jan,
Horseman is offline Find More Posts by Horseman
Old May 23, 2010, 12:43 PM
HelloMoto is offline
Find More Posts by HelloMoto
Ohio, IL
Joined Feb 2006
Looks like a really nice kit, should be much easier to build than the Gato. Are you going to cut out those drainage holes by hand, rotary tool or do you have a mill? Any special features planned for this kit, like the mast and radar on the Gato?
HelloMoto is offline Find More Posts by HelloMoto
Old May 23, 2010, 12:55 PM
CaptainNemo12 is offline
Find More Posts by CaptainNemo12
RC sub dude
CaptainNemo12's Avatar
Montreal, Quebec, CANADA
Joined Nov 2004
Have fun cutting all those holes out!
CaptainNemo12 is offline Find More Posts by CaptainNemo12
Old May 23, 2010, 05:19 PM
tsenecal is offline
Find More Posts by tsenecal
Submarines, etc.
tsenecal's Avatar
Arvada, Colorado
Joined May 2005
more please
tsenecal is offline Find More Posts by tsenecal
Old May 25, 2010, 06:35 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hello HelloMoto,
It looks easier indeed to build her but the real challenge will be mounting the WTC into the Hull at the exact spot so the fixing points fore and aft are at the same spot and I'm indeed using a Dremel moto tool with a 1mm tool to cut out the drainage holes and the rest by hand. I put in some photo's to let you see the progress.
And some details,
And some deck details,
I do about 20 holes a day to keep it funny and when it go's very good I do 50 holes and then I stopped because my focus will be lost then
I continues also with the WTC and build the Nose cone together.
And the assembly completed with the energy-coupling.
You can nicely see how the electrical pcb boards fits together.
There one board with spring loaded runners.
And the second board that accepts the runners,
And here the completed assembly,
So I'm going strong
Greetings,
Jan.
Old May 25, 2010, 07:03 AM
Heiko2 is offline
Find More Posts by Heiko2
Joined Mar 2009
Thread bookmarked :-)
all the best for this project Jan!
Heiko2 is offline Find More Posts by Heiko2
Old May 25, 2010, 10:30 AM
RC sub dude
Joined Nov 2004
Never seen an Engel VIIC build this up close before, it's a thing of beauty!
Old May 30, 2010, 04:41 PM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hello all,
I have finised the WTC and its now inside it's tube
And its fits beautiful however all the electronics are not fit yet.
The nose cone without the O-Ring
The WTC insite the tupe,
And the backside of the drive unit with the water inlets for the two water pressure sensors and dive tanks. And the holes for the two steering arm's. And of course the two main shafts.
Then I did some grinding and carving with the moto tool.
The front main deck is DONE
And some detail of the Gun support ,
And the front Resin deck latch and they are softer than Epoxy so it go's faster but also faster wrong
But not a problem when you take your time.
And the finished aria behind the Tower,
I use a proxon 18volts moto tool and a Dremel 220volts moto tool and its a good combination for this kind of job.
The Hull looks just wonderful with all his holes and shapes......
I'm a happy man, but there's still a lot of work to do.
I'm started with the stern hull now.
Will be continued,
Jan,
Old May 30, 2010, 07:01 PM
Ohio, IL
Joined Feb 2006
Looking good! How long did it take you do all those holes? I always thought it would take absolutely ages to do by hand without a PE deck and that has always put me off these sort of boats.
Old May 30, 2010, 08:56 PM
jaguar75 is offline
Find More Posts by jaguar75
jaguar75's Avatar
Sacramento
Joined Mar 2007
How many holes does it take to love it?
Great job Jan!
I use a Proxxon drill,too.
Regards,
John
jaguar75 is offline Find More Posts by jaguar75
Old May 31, 2010, 03:01 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Hello HelloMoto,
It's hard to tell how long it has takes so far, and I started this project in January so its not done in a few days. only the last days its going fast now
But if a man was able to maintain his accurateness then expect I that this job can be done in less than 30 hours.
But you will hate this hobby for always after done that I guess
Best regards,
Jan,
Old May 31, 2010, 02:27 PM
Jeff Van Hofwegen is offline
Find More Posts by Jeff Van Hofwegen
Joined Feb 2010
Hi Jan, thanks for doing this build thread! I have really enjoyed your progress on this magnificent model! Looking incredible so far!
best wishes,
jeff
Jeff Van Hofwegen is offline Find More Posts by Jeff Van Hofwegen
Old May 31, 2010, 07:12 PM
Ohio, IL
Joined Feb 2006
OK, that makes sense, I thought you managed to get all this done in like 5 days! Looking great.
Old Jun 04, 2010, 06:29 AM
Horseman is offline
Horseman's Avatar
The Netherlands, FR
Joined Aug 2008
Jan,
Old Jun 04, 2010, 12:28 PM
Sub culture is offline
Find More Posts by Sub culture
Man from Atlantis
Sub culture's Avatar
London
Joined Nov 2003
Interesting way that hull is moulded, the lower hull is clearly two pieces, which it would have to be to clear the undercut. The deck looks like a one piece mould though, that perhaps is glassed in afterwards?
Is the hull polyester or epoxy resin?
Sub culture is offline Find More Posts by Sub culture
Cool 10 Foot Indoor C-47 Now with build pictures added R&RRC Foamies (Scratchbuilt) 132 Jul 18, 2014 03:24 PM
Build Log D-18/C-45, Build-up (ACME A.C. kit) Fly_Baby1A Scale Kit/Scratch Built 43 Jun 23, 2010 07:54 PM
Discussion C.N.C Machines are not necessary to build R/C airplanes! Mode One The Builders Workshop 38 Apr 20, 2010 01:35 PM
Question I want to build an Aviat Husky A1-C HaventFlownSince2014 Scale Kit/Scratch Built 26 Mar 19, 2010 08:28 PM
Engel Typhoon / Gato / U177 Build and Tips Wheelerdealer Submarines 40 Aug 07, 2007 11:27 AM
