Old May 22, 2010, 10:52 PM
sklsy is offline
Find More Posts by sklsy
Joined May 2010
Help!
Need help going for 14.8v!
Hi guys I'm new here.
I've brought a 4s lipo for my fpv plane which was previously running under 3s
the motor's kv is 1400
What Adjustment should I make to have the best efficiency out of it?
Could I simply change the propeller from 8 inches to a smaller one, like 6?
Or do I have to buy another 1000kv motor and keep the other setting?
Which solution is better? Smaller propellers seem to have a lower efficiency on a heavy fpv plane.
I'm going for the 1st because I might also run it under 3s, changing propellers is much easier...
Thanks!
Edward
sklsy is offline Find More Posts by sklsy
Old May 23, 2010, 07:09 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
The safest way is to use a wattmeter, (or just an ammeter), to make sure you are not overloading the system.
But, yes changing the propeller to keep the amps down, if increasing volts, or going to a larger prop if reducing the volts, is perfectly Ok.
You don't need to change the motor, BUT, check the ESC is Ok with 4s. Some, (make that most), ESC's limit the BEC side to 3s, as 4s can overload the voltage regulator.
You may find to go 4s, you will need a separate BEC/UBEC or 4.8v pack, and have to disconnect the ESC's red wire at the connector, (3 wire Rx connector).
eflightray is offline Find More Posts by eflightray
Old May 23, 2010, 11:52 AM
sklsy is offline
Joined May 2010
Thanks for the reply. about the BEC, Can I just put some diodes (maybe 3)before my bec to step the volt down a bit?
Old May 23, 2010, 01:40 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
No you almost certainly can't. The BEC is a circuit which is built into your ESC. You'd need to be able to modify the complex printed circuit it's built on.
Steve
slipstick is offline Find More Posts by slipstick
Old May 24, 2010, 03:09 AM
sklsy is offline
Joined May 2010
Steve
My bec is a ubec which is a seprate part from the esc.
Will it work then?
Old May 24, 2010, 04:11 AM
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Yes, just check the ubec's rating if your not too sure, but most ubec are rated to at least 6s.
Old May 24, 2010, 07:44 AM
cryhavoc38 is offline
Find More Posts by cryhavoc38
Why didn't they run? A pass???
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
why would you want to step the voltage down a bit for the Ubec?
As the other fella mentioned, ubec's are typically rated for 6s operation, unless its more of a voltage regulator that is specifically listed as 2s input such as the turnigy Megabec 8.
If its a turnigy 5a ubec, its a switchmode ubec and rated for 6s max input.
specifics of your hardware is always very helpfull if you wish to receive good advice.
cryhavoc38 is offline Find More Posts by cryhavoc38
Discussion Charger for 14.8V 2200mah 20C cgjohnst Batteries and Chargers 1 Mar 31, 2010 02:23 AM
Discussion Going out for the maiden need some help!!!!!! j3tman Foamy EDFs 10 Mar 22, 2010 07:03 PM
Help! 14.8V 5200milliamp LiPo Question Help! IAFFburnITup! Batteries and Chargers 2 Dec 06, 2009 01:38 PM
Wanted Looking for Lipo's. 2 7.4v or 1 14.8v DX6channel Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 12, 2009 12:02 PM
Discussion Need a Brushless SC for 40amp 14.8v LIPO Soupcue Power Systems 2 Feb 27, 2008 07:41 AM
