Old May 14, 2012, 03:01 AM
szymbura is offline
Find More Posts by szymbura
Joined Apr 2012
Originally Posted by szymbura View Post
I tried to remove this pin with a hammer and a small nail. With no results. I tried to push this pin out from the narrow,, smaller side of it. It is stuck! How do you do it? Plz see attach
Ok, I've done this but I had to cut the flybar a little bit.
szymbura is offline Find More Posts by szymbura
Old May 14, 2012, 06:53 PM
BThirsk is offline
Find More Posts by BThirsk
Brent 黑雁
BThirsk's Avatar
Canada, AB, Ponoka
Joined Jan 2012
Originally Posted by shahram72 View Post
Yep, bought two of those. The 9101 must have a different tail because the blade pitch is reversed so they won't work. Anybody want mine? 2 for $5
If you really want to use them, you probably could just switch the wires on the motor to reverse it. Either that, or open the transmitter and move the tail motor wire from on side of the reostat to the other.
BThirsk is offline Find More Posts by BThirsk
Old May 16, 2012, 10:23 AM
FilthyLucre is offline
Find More Posts by FilthyLucre
Joined May 2012
I got 9118 but its similar, so I'm going to ask my question here. Since I've changed my balance bar to the bar from 9077, my heli flies much slower. My guess is that the new bar is easier than the old one. Has anyone already had such difficulties?
FilthyLucre is offline Find More Posts by FilthyLucre
Old May 16, 2012, 03:52 PM
Auflyer is offline
Find More Posts by Auflyer
still a lot to learn!!!!
Auflyer's Avatar
Australia, NSW, Laurieton
Joined Jan 2012
When you sy speed to you mean forward speed or the rate of lift???? It didn't change the forward speed of mine at all
Auflyer is offline Find More Posts by Auflyer
Old May 17, 2012, 01:57 AM
Joined May 2012
Rate of lift. Because even at maximum, my heli goes down sometimes, and before that, it was going up like crazy.
Old May 17, 2012, 04:34 AM
Auflyer is offline
Auflyer's Avatar
Joined Jan 2012
9077 flybar didn't make a difference to mine, although haven't flown it for a while. I just finished rebuilding it last night after a massive nose dive into the road. New pcb, frame, floor and front motor holder. Went to fly it this morning and the gear stripped on the outer shaft. Rebuilt it again tonight so will try again tomorrow
Old May 17, 2012, 08:56 AM
bdee1 is offline
Find More Posts by bdee1
Joined Jul 2005
Wow this is a big thread. I see lots of people mentioning a "blade flip" mod and gettign a new tail rotor.
I am wondering what the blade flip mod is and what that accomplishes.
Has anyone found a good inexpensive tail rotor that can easily be swapped out for the factory one that can give this copter any forward or reverse motion?
I have only flown mine a few times but once its in the air it doesn't seem to want to move forward or back at all.
I tried digging through the thread for these details but its monstrous and I wasn't able to find much detail - just lots of mentions of these two mods.
bdee1 is offline Find More Posts by bdee1
Old May 17, 2012, 09:42 AM
Joined May 2012
I dropped this idea But there is another one. You can cut 50 mm from your old rotor blades and stick it to your tale blade. Ppl say it works, and I will definitly try it, as soon as I get my new rotor blades.
Blade flip is easy. Just turn your lower main blades upside down. It will give you a little bit more space between your lower and upper blades. I dont know if your heli will fly better, but there is much less possibility of blades crashing
The other thing is, I'm wondering, which batterie can I buy, that wont change my helis flying ability, but will give me something more than 8-10 mins?
Old May 17, 2012, 10:06 AM
bdee1 is offline
Joined Jul 2005
Oh ok cool that sounds simple - I assume its pretty easy to get the blades off and on?
So when you say to cot 50mm off the old rotor blades, do you mean the main blades? Unfortunately I don't have any blades that I'm not using - I am still on my original set. If this actually works - I wonder if there is any place to buy just the 50mm pieces? also - does anyone have pics of this? what are people using to stick it?
Old May 17, 2012, 10:15 AM
Joined May 2012
There are plenty of videos on youtube And there is a possibility to buy Sky King Rotor blade, but my guess is, that the previous idea is much better. New rotor blades are not THAT expensive, so its your choice
Old May 17, 2012, 10:35 AM
bdee1 is offline
Joined Jul 2005
Sorry I am really new to this... I would love more info on the Sky King Rotor blade... do they work? how much?
Old May 17, 2012, 12:28 PM
Joined May 2012
5 bucks I guess. But you should ask someone esle, since I dont have any exp with it.
Old May 17, 2012, 03:02 PM
Auflyer is offline
Auflyer's Avatar
Joined Jan 2012
Havng done both your conclusion in incorrect, the sky king rotor blade gives the 9053 the ability to move at quite a speed, so much that your have to be careful not to have a blade strike. On my last crash the forward thrust pushed the nose almost straight to the ground causing a blade strike and kissing the concrete. My own fault for not paying enough attention
Old May 17, 2012, 03:03 PM
Auflyer is offline
Auflyer's Avatar
Joined Jan 2012
Yes they work, eBay is your friend
Old May 18, 2012, 07:39 AM
Joined May 2012
I still have a question to ask. Which battery to buy with 2200 and a JST connector? Any ideas? Or can I just buy the battery with a XT-60 connector and then apply a JST connector to it?
Mini-Review 9088 Double Horse 3 ch. Apache helicopter skiesthelimit Micro Ready-to-Fly 27 Oct 30, 2012 02:14 PM
New Product new Double Horse s-9098 heli adma20 Coaxial Helicopters 88 May 05, 2011 11:03 AM
Discussion Double Horse 9074 3.5CH Gyroscope othmanskn Coaxial Helicopters 19 Oct 27, 2010 07:17 PM
Sold Double Horse heli POS for sale 10 cents jim breese Aircraft - Electric - Helis (FS/W) 5 Apr 21, 2010 05:08 PM
Whoops! Syma Double Horse 9083 And Helixx 3D Plane95 Micro Helis 4 Nov 04, 2008 07:15 PM
