Old May 20, 2010, 04:07 AM
Add1ct3dd is offline
Find More Posts by Add1ct3dd
Add1ct3dd's Avatar
United Kingdom, England, Worcester
Joined May 2010
Help!
Turnigy Plush 25A & Turnigy 2627 4200kv motor
Hi,
I just wondered if anyone knew in which way the wires connected? on the speed controller it's labelled as A, B, C, and all the wires are red :| and on the motor i have red, black and a white motor, and so im not sure which wire goes where and don't wanna risk burning anything!
With the motor wires i assume we have positive red, black negative, and the other brushless wire (controller?) as white, but which is which on the controller
Matt
Add1ct3dd is offline Find More Posts by Add1ct3dd
Old May 20, 2010, 07:13 AM
Pete Miller is offline
Find More Posts by Pete Miller
Beaumont, TX
Joined Feb 2007
It doesn't matter. Hook up the three wires on the controller to the three wires on the motor. If the motor is spinning the wrong direction, switch any two of the three wires. The colors have nothing to do with positive, or negative. They could be all black on the motor also, or green or yellow, or any other color that the manufacturer had in stock at the time.
As a side note, DON'T EVER switch the battery leads to reverse the motor direction. Fried controller will be the result.
Pete Miller is offline Find More Posts by Pete Miller
Old May 20, 2010, 07:44 AM
Add1ct3dd's Avatar
Joined May 2010
ohhh ok, thank you
makes alot more sense now
Old May 20, 2010, 10:16 AM
Beaumont, TX
Joined Feb 2007
Don't feel bad, the question comes up at least once a week on some electric forum, from someone who has never run into the situation before, because a lot of the motors and esc's don't come with any directions that tell you this little detail!
If you buy matched components from the same manufacturer, such as e flite, then your esc wires and motor wires will have the same colors and you just match them up. (Even though you don't really have to) The same rule applies for changing motor direction, though.
When you get stuff from different manufacturers, they could be any color. No problem, just do like I said in my first post and you'll be fine.
If I am using bullet connectors to hook up the esc and motor, I will use different colors of heat shrink on the esc connectors and there corresponding motor wires just as an aid on how to hook it back up for proper rotation direction if I ever have to take it apart.
Help! turnigy plush 25a beeps syed Power Systems 3 Apr 17, 2010 03:54 PM
Wanted Turnigy 2627 4200kv / 3800kv brushless motor HeliStyle Aircraft - Electric - Helis (FS/W) 0 Jul 27, 2009 05:06 AM
Sold Turnigy 25a plush esc rcbirk21 Aircraft - Electric - Power Systems (FS/W) 6 Jul 06, 2009 08:30 PM
For Sale HDX300 4200Kv motor + Esky 25a ESC Dragonfish Aircraft - Electric - Helis (FS/W) 5 Jun 03, 2008 04:23 PM
