Old Jun 08, 2010, 03:18 PM
kreu01 is offline
Find More Posts by kreu01
kreu01
Joined Oct 2008
Originally Posted by Jacky_chen View Post
How about the video range? which one is the best choice between 900M and 1300M video transmitter? According to the RF theory 900M seems to fly farther than 1300M if with same output power. But some one say that 900M will interfere with servo? Is it right?
Both create interference. I'm anxious to see the answer
kreu01 is offline Find More Posts by kreu01
Old Jun 08, 2010, 04:07 PM
Jumpjet101 is offline
Find More Posts by Jumpjet101
Jumpjet101's Avatar
United States, CA, Santa Clarita
Joined Jul 2007
Originally Posted by Crist Rigotti View Post
You're right. This is for a DX7. Please start another thread for the Aurora.
Geez, I just asked one simple question since it was already brought up. I'm not trying to take over your thread! Sorry for bringing it up.
Jumpjet101 is offline Find More Posts by Jumpjet101
Old Jun 08, 2010, 08:36 PM
aallman72 is offline
Find More Posts by aallman72
United States, TX, Dallas
Joined Dec 2009
I just received the same amp from geeks.com for $40
http://www.geeks.com/details.asp?invtid=ARG-2301A&cpc=SCH
Did the mod to my DX6i. Will report back with results.
aallman72 is offline Find More Posts by aallman72
Old Jun 08, 2010, 08:44 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Wow, good price!
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Jul 12, 2010, 12:01 AM
teebok is offline
Find More Posts by teebok
teebok's Avatar
Pico Rivera, CA
Joined Apr 2004
I just finished doing this mod to my dx7. The only thing left to do is to power the booster. can anyone tell me wich is the positive & negative on the power cord that came with the booster?
teebok is offline Find More Posts by teebok
Old Jul 12, 2010, 05:09 PM
Krylon is offline
Find More Posts by Krylon
What goes up...
Krylon's Avatar
England
Joined Apr 2010
The standard is the negative is the lead with the writing on and the positive is marked with a white stripe. as for the connector its probrobly positive centre pin but the sticker / imprint on the booster should tell you that if you need to know. (or just stick a continuity meter across it)
Krylon is offline Find More Posts by Krylon
Old Jul 12, 2010, 06:01 PM
teebok is offline
teebok's Avatar
Pico Rivera, CA
Joined Apr 2004
Thanks.
Old Jul 12, 2010, 08:35 PM
Snaydher is offline
Find More Posts by Snaydher
Goi‚nia - Brasil
Joined Jan 2009
Greate, waiting for your results... I'll do this mod in my DX6i soon
Snaydher is offline Find More Posts by Snaydher
Old Jul 23, 2010, 07:13 PM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
Crist, are you using a low pass filter on ur vtx?
is it recommended for this mod?
Moe
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Jul 23, 2010, 08:17 PM
Joined Mar 2008
Moe
No. Just a toroid.
I don't know about the low pass filter.
Old Jul 23, 2010, 08:18 PM
Joined Mar 2008
BTW, this week I was able to fly out to 20,500+ feet without a hitch on both radio and video.
Old Jul 23, 2010, 09:10 PM
gblount is offline
Find More Posts by gblount
Joined Jun 2007
You know what they say: Without video it didn't happen
gblount is offline Find More Posts by gblount
Old Jul 23, 2010, 09:17 PM
Krylon is offline
What goes up...
Krylon's Avatar
England
Joined Apr 2010
Would this mod still work ok if you kept the original antenna in place and added an extra socket to the case to plug the booster into? (preferably so you can switch between the standard and the boosted output)
And if so would it work ok if the lead from the DX7 to the booster was about 2m long?
Id like to run a system like this but would prefer to place the booster on my ground station and not add all the equipment direct to the Tx. Not least as it would be kind of overkill for my blade msr.
Old Jul 23, 2010, 09:38 PM
Joined Mar 2008
Sure it would work if you kept the same antenna. See the DIY link.
If you using a 2m coax to the booster, then you wouldn't need the attenuator. Again, see the DIY link.
Old Jul 23, 2010, 09:55 PM
Joined Mar 2008
Oh ye of little faith.
The failsafe trigger was caused by me to see which way home was.
Deleted video because it served it's purpose.
Discussion A single Unit for long range control and video link markeydoo FPV Talk 1 Apr 06, 2010 02:18 PM
Discussion 2.4Ghz 500mW Pen Booster Range test sirocco FPV Talk 12 Oct 02, 2009 05:26 AM
Discussion Range issues with Spektrum DX7 jc9995 Radios 6 Sep 16, 2009 10:45 PM
Discussion Spektrum claims the DX7 has full range....does anyone know the actual range in ft? TheFlyingAce Radios 42 May 31, 2008 02:04 PM
Discussion DX7 or other 2.4 Ghz for long range E-glider bmwbob Radios 6 Mar 04, 2008 05:05 PM
