Old Feb 15, 2012, 07:14 PM
rotaryboots is offline
Find More Posts by rotaryboots
United States, MT, Columbia Falls
Joined Jun 2011
Yes, old thread. Current info comments though.
Okay, I have all the parts ordered for this Mod on my 9X. Just waiting for it all to arrive. Went with the 1W booster. Got it for a great price brand new in box here in the US. I'll probably take pictures of the mod and post them up. My setup runs a 900mhz video and 2.4ghz tx, so it's gunna work out nice when it's finished.
rotaryboots is offline Find More Posts by rotaryboots
Old Mar 01, 2012, 02:07 PM
dudz is offline
Find More Posts by dudz
Joined Mar 2012
Originally Posted by brettbb View Post
I was shopping around the other day and found http://www.alfa.com.tw/in/front/bin/...ategory=107049 wifi booster.
It's a really nice little booster that is easy to install requiring no additional connector and cables.
So here is what I did with it.
I first checked how it would fit onto the Transmitter with my FRsky module. Normally the antenna connector points upwards but I opened it up and drilled a new hole so it points backwards.
I then put a 5A BEC inside the transmitter and put a connector on the back for the 6v output to the amplifier. The BEC is wired through the power switch of the transmitter the amplifier is switched on and off with transmitter.
I have flown 1.1km away so far without any problems. havnt had the importunity to go further yet.
Hey Brettbb,
Have you tested the range any futher on this setup yet ?
dudz is offline Find More Posts by dudz
Old Mar 06, 2012, 12:07 AM
Gattorno is offline
Find More Posts by Gattorno
Checo
Monterrey
Joined May 2007
My Setup DX8 and booster
here is my setup
Greetings
Gattorno is offline Find More Posts by Gattorno
Old Mar 06, 2012, 12:26 AM
Gattorno is offline
Checo
Monterrey
Joined May 2007
Hi Crist, hi to everyone,
I have a question, when I reach the limit of DX8, telemetry Fails starts sending me this about 847mts (2778ft)
when I started this back to home, to someone this happened to the telemetry of the
DX8
This is my setup.
DX8
Booster 1W ARGtek
Atten 4db DC-6Ghz Narda
RC Logger Pro Camera
AR8000 whit SPM9548 Spektrum Full Range Telemetry Module
Elogger V4, OSD Pro and 10hz GPS V4
Electrostick 52.5"
Ranger Video transmiter 900mhz 800mh
V antena transmiter
Range Video receiver
patch antena
and two very large for go to flying
Greetings.
Old Mar 06, 2012, 05:45 AM
Upup is offline
Find More Posts by Upup
Upup's Avatar
Ilford,Essex, UK
Joined May 2006
Finally a nice day
sorry wrong thread
Upup is offline Find More Posts by Upup
Old Mar 06, 2012, 01:11 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
DX8
This is my setup.
DX8
Booster 1W ARGtek
Electrostick 52.5"
V antena transmiter
patch antena
Greetings.
I only have experience with a DX7. I'm not sure what you mean?
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Mar 06, 2012, 07:14 PM
Gattorno is offline
Checo
Monterrey
Joined May 2007
Ok Crist,
I think I'll return to my good old Radio DX7, which modify the same.
Thank you for your help.
Old Apr 27, 2012, 02:16 PM
Pilot420 is offline
Find More Posts by Pilot420
Can't Afford the Real Thing
Canada, ON, Oshawa
Joined Apr 2012
This might be the place to answer my question.
Spektrum Dx8
If I have the stock antenna connected and
connected to each other, and ran the booster as well, what could or would happen?
I ask as a fail safe to not having shared tx switched power to your booster. Also could be convenient for removal of the booster for indoor flying in the winter. resale with a booster port option etc.
Cheers
Pilot420 is offline Find More Posts by Pilot420
Old Apr 28, 2012, 06:26 PM
Jack2010 is offline
Find More Posts by Jack2010
Joined Jan 2012
Can you pls put some more details on how did you mount the SMA into the hole so nicely? Preferably some pic from the inside of the TX...
Jack2010 is offline Find More Posts by Jack2010
Old May 11, 2012, 12:52 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
whew, 34 pages read! good information sprinkled throughout.
TexasClouds is offline Find More Posts by TexasClouds
Old May 17, 2012, 07:44 AM
Jack2010 is offline
Joined Jan 2012
What should be the sequence of powering up the set: booster first and then the radio or radio on first and then the booster or it does not really matter as long as the antenna is on the booster and there is RF connection between the booster and the TX?
In my setup I will not be able to connect them both in the same time as there will be some distance in between them.
Old May 17, 2012, 08:01 AM
Joined Feb 2010
That is a good question, I'd like to hear the answer.
I read in the thread earlier that the booster doesn't power on until it gets signal from the transmitter. That would make me think that the booster could be powered first.
I've heard that powering on a transmitter without antenna can mess up the transmitter. Is that true?
Also, in a similar thread guys are saying these boosters can go out at any time and regularly. Is that true? Anyone here had a booster fail on them?
Old May 17, 2012, 08:14 AM
Jack2010 is offline
Joined Jan 2012
That one is easy - yes, it is true. You should not power up any radio TX witout the antenna.
Old May 18, 2012, 06:09 AM
WalneyCol is offline
Find More Posts by WalneyCol
youtube.com/seafax
WalneyCol's Avatar
United Kingdom, Barrow-in-Furness
Joined Feb 2011
Originally Posted by Crist Rigotti View Post
I needed a 6db attenuator which could be bought here. Do a search on eBay for 6db attenuator.
Note: I'm using a 4db attenuator now. (8/4/2010)
Hi Crist.
Can you explain why you used an attenuator. Wouldn't that just reduce the potential range?
Col.
WalneyCol is offline Find More Posts by WalneyCol
Old May 18, 2012, 07:39 AM
Joined Feb 2010
Originally Posted by WalneyCol View Post
Hi Crist.
Col.
The booster has a maximum amount of signal it will intake. The attenuators makes sure the radio transmitter doesn't get burnt up when excess isn't used. That is the redneck response...you can read the thread to get a more scientific one...it's been addressed several times.
Discussion A single Unit for long range control and video link markeydoo FPV Talk 1 Apr 06, 2010 02:18 PM
Discussion 2.4Ghz 500mW Pen Booster Range test sirocco FPV Talk 12 Oct 02, 2009 05:26 AM
Discussion Range issues with Spektrum DX7 jc9995 Radios 6 Sep 16, 2009 10:45 PM
Discussion Spektrum claims the DX7 has full range....does anyone know the actual range in ft? TheFlyingAce Radios 42 May 31, 2008 02:04 PM
Discussion DX7 or other 2.4 Ghz for long range E-glider bmwbob Radios 6 Mar 04, 2008 05:05 PM
