Old Oct 14, 2011, 06:57 AM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Originally Posted by fgene View Post
I have completed the mod on my JR X9503, it's essentially the same as Christ's with some cosmetic changes. I am using a 1W booster and 5db 18Ghz attenuator.
When I turn the radio on (the booster is also turned on at the same time) the booster's green LED blinks very rapidly for about a second, then dims for about half a second, then turns on again and stays on. It turns off when range button is pressed on the TX, and lights up again immediately when the button is released. During the initialization stage (first second, rapid blinks) the power draw of the system consisting of the TX and the booster powered by a 3A UBEC increases to about 1A, compared to 0.5 A which it consumes during normal operation. Does my description point to any abnormalities in my system? In particular, is this power fluctuation normal?
Seems normal to me.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Oct 14, 2011, 10:14 AM
fgene is offline
Find More Posts by fgene
fgene's Avatar
Brooklyn, NY
Joined Sep 2010
Originally Posted by Crist Rigotti View Post
Seems normal to me.
Thanks! It seems to be ready for field testing then.
fgene is offline Find More Posts by fgene
Old Oct 14, 2011, 11:48 AM
mkmkmk13 is offline
Find More Posts by mkmkmk13
mkmkmk13's Avatar
United States, CA, Orange
Joined May 2007
The amp doesn't work unless it's getting a signal
mkmkmk13 is offline Find More Posts by mkmkmk13
Old Oct 14, 2011, 04:35 PM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
Do you know if I can leave the power plug connected or will it drain the battery? If the amp is off, does it still draw a little current or is it using a zener diode to control the current and prevent draw when it's off?
chatch15117 is offline Find More Posts by chatch15117
Old Oct 14, 2011, 10:26 PM
Joined Mar 2008
My guess it is still drawing current when the amp is "off". BTW, what do you mean by "off"?
Old Oct 16, 2011, 09:16 PM
Joined Apr 2011
If my amp detects no Tx signal it turns off, and the light goes out.
Old Nov 13, 2011, 10:18 PM
Chris Moon is offline
Find More Posts by Chris Moon
Fort Worth, Texas
I have done some tests with my 9303, and using a calibrated power meter, I am only showing about 12-13 db out of the Spektrum RF Board. I know they are rated at 100mw, but this only equates to about 30 mw. Are the spektrum RF decks rated at 100mw input before the inefficiency of the the amplifier section? I really dont know that an attentuator is really needed on a setup like this. Can anyone confirm or give different measured results?
Also,
Used the same power meter to measure power after the booster, and came up with about 21dbm ERP. This is only about 100mw out of a 1000mw booster. I think some of these are a little overrated.
Chris
Chris Moon is offline Find More Posts by Chris Moon
Old Nov 20, 2011, 12:46 AM
Floater73 is offline
Find More Posts by Floater73
But often down to earth
Floater73's Avatar
Oklahoma, USA
Joined Sep 2010
Below is a link to the specs on one of the boosters sold many places. I got mine on Amazon. I'm waiting for the U.fl IPX pigtail. I found that the power plug is like the one on my old Nokia phone chargers. I did have to trim a little of the rubber back so it would go all the way in to the jack.
http://www.premiertek.net/products/n.../PL-2301A.html
It states "Full output power of 1W is achieved with only 5mW input into the Booster." But later it says "Transmit Input Power Max. 100mW, Min 6mW." In either case attenuation of the input doesn't appear to be critical as long as the input doesn't exceed 100ma (20db).
Steve
Floater73 is offline Find More Posts by Floater73
Old Nov 20, 2011, 02:45 AM
Joined Apr 2011
I'm giving my booster 7.82v(just tapped the battery pack at some random point and wired it up). What type of resistor do I need to put in there to get it down to 6v? Or near 6v?
Also what is a good way to test that the booster is actually working?
Old Nov 20, 2011, 03:56 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Just buy a $4 ubec from HK mate.
Teamsherman is offline Find More Posts by Teamsherman
Old Nov 20, 2011, 03:58 AM
Member #1
Joined Aug 2011
To test? Do a full range test without booster with a friend by speaking to him what you are doing with a mobile phone, then turn on booster and add distance between you. If you have a mountain nearby get him to drive to the top and repeat the test. That's what I'm going to do, as the distance I only want to fly is from my park to around the mountain.
Old Nov 20, 2011, 04:05 AM
Joined Apr 2011
http://answers.yahoo.com/question/in...4162225AAe5gOp
lol
thanks ill try the range testing
Old Nov 20, 2011, 04:13 AM
Member #1
Joined Aug 2011
Ahahahaha I really did LOL when I clicked that link!
Old Nov 20, 2011, 06:49 AM
RaptorAP is offline
Find More Posts by RaptorAP
Gainesville, FL
Joined Nov 2005
Ive sold all my Spektrum gear and went Dragonlink for FPV, Ill never look back.
RaptorAP is offline Find More Posts by RaptorAP
Old Nov 20, 2011, 02:39 PM
Joined Apr 2011
for christmas I'm getting Turnigy 9x + dragonlink
Discussion A single Unit for long range control and video link markeydoo FPV Talk 1 Apr 06, 2010 02:18 PM
Discussion 2.4Ghz 500mW Pen Booster Range test sirocco FPV Talk 12 Oct 02, 2009 05:26 AM
Discussion Range issues with Spektrum DX7 jc9995 Radios 6 Sep 16, 2009 10:45 PM
Discussion Spektrum claims the DX7 has full range....does anyone know the actual range in ft? TheFlyingAce Radios 42 May 31, 2008 02:04 PM
Discussion DX7 or other 2.4 Ghz for long range E-glider bmwbob Radios 6 Mar 04, 2008 05:05 PM
