Old Aug 21, 2011, 01:48 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Thanks for those observations Gil.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Aug 28, 2011, 11:54 AM
aiko is offline
Find More Posts by aiko
Joined Aug 2011
Hello to everyone!
I made this mod too. I am with the European power settings of my DX6i and I hope I do not need an attenuator.
Everything is very simple and nice with this mod, but guys, don't you think that the RF radiation could be dangerous? - I measured more then 0.1 mW/cm2 intensity from about 50 cm distance.
What do you think about this aspect? I think the cancerous effect of the microwaves is already proven.
Regards!
aiko is offline Find More Posts by aiko
Old Sep 04, 2011, 07:23 PM
Sterlingjl is offline
Find More Posts by Sterlingjl
Joined Jun 2011
Hi aiko, I have a dx6i too and I was wondering what the verdict is on your installation without the attenuator. Thanks
Sterlingjl is offline Find More Posts by Sterlingjl
Old Sep 05, 2011, 06:01 AM
brettbb is offline
Find More Posts by brettbb
Joined Jan 2010
ALFA 800mw PEN Booster APA05
I was shopping around the other day and found http://www.alfa.com.tw/in/front/bin/...ategory=107049 wifi booster.
It's a really nice little booster that is easy to install requiring no additional connector and cables.
So here is what I did with it.
I first checked how it would fit onto the Transmitter with my FRsky module. Normally the antenna connector points upwards but I opened it up and drilled a new hole so it points backwards.
I then put a 5A BEC inside the transmitter and put a connector on the back for the 6v output to the amplifier. The BEC is wired through the power switch of the transmitter the amplifier is switched on and off with transmitter.
I have flown 1.1km away so far without any problems. havnt had the importunity to go further yet.
brettbb is offline Find More Posts by brettbb
Old Sep 05, 2011, 07:56 AM
Joined Mar 2008
Nice.
Old Sep 27, 2011, 10:41 AM
actionplus is offline
Find More Posts by actionplus
United States, CA, Rancho Cucamonga
Joined Mar 2005
Alfa
I have one those this in my drawer. I should try that.
actionplus is offline Find More Posts by actionplus
Old Oct 01, 2011, 02:44 PM
aiko is offline
Joined Aug 2011
brettbb, with the FRsky module only, you should achieve 1 mile at least and maybe even 2 miles. You do not need to burn your nuts and get eventually cancer for 1-2 mile distances.
Old Oct 03, 2011, 04:56 AM
Teamsherman is offline
Find More Posts by Teamsherman
Member #1
Teamsherman's Avatar
Australia, NSW, Picnic Point
Joined Aug 2011
Im close to doing this to my DX8, can someone tell me what sort of attenuator i can use, or how long i should have a co-axial cable if i cant find an attenuator for it?
Teamsherman is offline Find More Posts by Teamsherman
Old Oct 03, 2011, 08:52 PM
Member #1
Joined Aug 2011
Ummm, anyone?
Old Oct 03, 2011, 10:00 PM
galaxiex is offline
Find More Posts by galaxiex
my karma ranover my dogma
galaxiex's Avatar
Edmonton,Canada Eh
Joined Jun 2007
Ummm, anyone?
The attenuator is talked about *somewhere* in this thread.... page 3 or 4 I think....
Also search ebay for sma attenuator... there will be lots listed... the trick is picking the right one.... a 6db attenuator that works from DC to 3ghz or higher should be ok.
In lieu of an attenuator, about 4-6ft of coax should be enough.....
galaxiex is offline Find More Posts by galaxiex
Old Oct 04, 2011, 12:41 AM
chatch15117 is offline
Find More Posts by chatch15117
United States, FL, Maitland
Joined Apr 2011
I got the 1W amplifier and I'm pumping 7.5 to 8.0v through it. I assume it has some type of vreg circuit or a zener diode to keep it reasonable(6v input). No problems yet.
chatch15117 is offline Find More Posts by chatch15117
Old Oct 04, 2011, 06:02 PM
fgene is offline
Find More Posts by fgene
fgene's Avatar
Brooklyn, NY
Joined Sep 2010
Hello,
I am planning to modify my US-rated JR9503, which is internally very similar to DX7 (so hopefully my questions will not be considered offtopic ), and I have already ordered the prescribed parts.
My current FVP rig consists of the mentioned TX with a detachable 7" LCD monitor on top, plus a video/audio receiver strapped to the monitor along with an extra 3s 2200 mAh battery. The whole thing is quite portable and easy to take along in a backpack when you're going to some remote location on foot, but it also feels a bit heavy when you have to hold it in your hands for extended periods of time. Adding a booster would increase the weight even more, which is something I would gladly avoid.
Hence the question: do you think it is possible to get rid of the booster case (which looks quite heavy) and, ideally, mount all the electronics inside the transmitter case? I understand the booster case provides some RF shielding, so another question follows: if I remove the case, how damaging the radiation would be to surrounding electronics, and how badly would it affect the video reception? (My A/V system is 1280 Mhz, omnidirectional)
Thanks in advance,
Gene
fgene is offline Find More Posts by fgene
Old Oct 04, 2011, 06:17 PM
Joined Apr 2011
the booster is a big heatsink. You expect it to dissipate 1W easily?
Old Oct 04, 2011, 11:51 PM
fgene is offline
fgene's Avatar
Brooklyn, NY
Joined Sep 2010
AFAIK the booster is designed to work 24/7 indoor and could be installed in a place with no airflow, that is why it may need a large heatsink. I don't think all that metal is really needed when you're using it outside for 10-15 minutes at a time. A much smaller customized heatsink + couple ventilation holes should solve the problem, in my opinion. My main concern is RF pollution, especially in the vicinity of A/V receiver.
Old Oct 05, 2011, 06:29 AM
Member #1
Joined Aug 2011
Ive been pointed in the direction of either a 6db or 10db attenuator. Which one should i go with?
I really have no idea on how to tell which would do the job better so im trusting the knowledge of you forum folk!! lol
Cheers,
Alan.
Discussion A single Unit for long range control and video link markeydoo FPV Talk 1 Apr 06, 2010 02:18 PM
Discussion 2.4Ghz 500mW Pen Booster Range test sirocco FPV Talk 12 Oct 02, 2009 05:26 AM
Discussion Range issues with Spektrum DX7 jc9995 Radios 6 Sep 16, 2009 10:45 PM
Discussion Spektrum claims the DX7 has full range....does anyone know the actual range in ft? TheFlyingAce Radios 42 May 31, 2008 02:04 PM
Discussion DX7 or other 2.4 Ghz for long range E-glider bmwbob Radios 6 Mar 04, 2008 05:05 PM
