Old Jan 14, 2011, 09:48 AM
hotdog1 is offline
Find More Posts by hotdog1
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Originally Posted by Crist Rigotti View Post
30,563 feet
480TVLSony CCD camera off eBay
Great
Thanksfor the info
hotdog1 is offline Find More Posts by hotdog1
Old Jan 14, 2011, 03:38 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
Why is the attenuator needed? If i just followed the steps on the DIY Drones website and powered it off of a 6V BEC would i need one?
beginner4life is offline Find More Posts by beginner4life
Old Jan 14, 2011, 03:43 PM
lovegroove is offline
Find More Posts by lovegroove
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
The attenuator is needed because the power output of the DX7 is too high for the booster and you risk blowing up the booster without it.
lovegroove is offline Find More Posts by lovegroove
Old Jan 14, 2011, 03:45 PM
Joined Mar 2008
I am using a Dx6i, if i put it on euro settings is it still an issue?
Old Jan 14, 2011, 04:18 PM
Martin Y is offline
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Still need one. Or you can use a 1m piece of rg174 coax.
Martin Y is offline Find More Posts by Martin Y
Old Jan 14, 2011, 04:54 PM
Joined Mar 2008
Okay thanks
Old Jan 15, 2011, 02:52 PM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
so I did a search on google for "4db attenuator" but i'm not sure what I'm looking for is it a mini SMA Female to male ?
Old Jan 15, 2011, 05:42 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Yes, SMA connector and at least 3ghz.
Here is an example:
http://cgi.ebay.com/Meca-Attenuators...item3cb3ecc395
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Jan 16, 2011, 08:08 PM
outngo is offline
Find More Posts by outngo
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
Originally Posted by Inakto View Post
cool, thanks anuarf, here is info for dx6i
0.128 W = 21.1 dBm
X1TXN 2.4GHz DSSS Module User Manual.
Horizon Hobby Inc., 1657 Country Club Dr., Milpitas CA 95035 USA 408 945 9800
1. Features
• 2.4GHz Direct Sequence Spread Spectrum (DSSS) radio transceiver module. • Operates in the unlicensed worldwide ISM band (2.4 GHz to 2.483.5GHz) band • Fully integrated power regulation with a wide input unregulated operating range
2.4 to 3.6V. • Fully integrated local oscillator and 12MHz 20ppm reference crystal • 200mA operating current • Transmit power - 200mW EIRP • Receive sensitivity up to -95dBm • DSSS data rates up to 250kbps • 1 mile operating range • Full packet assembling and disassembling • Auto transaction sequencer • Fully buffered digital interface with high voltage tolerant inputs
2. Pin description
Pin Number
Name
Description
1
GND
Module Ground
2
VDD
Module power input
3
IRQ
Interrupt Request
4
RST
Reset, active High
5
MOSI
Master out, slave In data
6
nSS
Slave Select, Active Low
7
SCLK
SPI data clock
8
MISO
Master in, slave out data
9
GND
Module Ground
10
XOUT
Clock output from module
11
TXRX
Switch antenna to transmit direction
12
RXTX
Switch antenna to receive direction
3. Specifications
4. Module User Requirements
4.1 This module must be integrated into a device where the user cannot access the antenna connector and should not be able to remove/install the module.
4.2 Only a 2dBi antenna can be used with this module. The antenna must meet and not exceed the gain and pattern of the supplied Inpaq DAM00BM11500209 folded dipole antenna.
4.3 This module must not be co-located or operated in conjunction with any other antenna or transmitter.
45.4 The device must contain the following permanent labeling on the exterior of the device as follows:
Contains FCC ID: BRWDAMTX10
Parameter
V alue
Units
Storage Temp
-65 to 105
Degrees Celsius
VDD
2.4 to 3.6
V olts
Receive Sensitivity
-95
dBm
Transmit power (conducted)
21
dBm MAX
Transmit power (radiated)
23
dBm MAX
Idle current
1
mA
Receive current
22
mA
Transmit current
200
mA
4.5 The user manual of the device must contain the following paragraph:
4.6 This module meets the requirements for a mobile device that may be used at separation distances of more than 20cm from the human body. It may be used in hand- held controllers that provide a separation distance of at least 5cm between the antenna and the body (excluding hands/wrists). The instructions to the user for the host device must include information requiring the product be used in a manner to ensure the appropriate separation (20cm or 5cm) between antenna and body and requiring that the transmitter not be collocated with another transmitting device.
This device complies with part 15 of the FCC rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation.
Caution: Changes or modifications not expressly approved by the party responsible for compliance could void the user’s authority to operate the equipment.
This product contains a radio transmitter with wireless technology which has been tested and found to be compliant with the applicable regulations governing a radio transmitter in the 2.400 GHz to 2.4835 GHz frequency range.
The following countries associated regulatory agencies recognizing the noted certifications for this product as authorized for sale and use are:
USA
Canada
Belgium
Denmark
France
Finland
Germany
Italy
Netherlands
Spain
Sweden
UK
bahaha. I have a hard time believing that storage temp for dx6i that is -86F!!!
outngo is offline Find More Posts by outngo
Old Jan 17, 2011, 07:26 AM
hotdog1 is offline
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Here is an example:
Great thanks Crist
Old Jan 18, 2011, 07:00 PM
captaingeek is offline
Find More Posts by captaingeek
master of the universe
captaingeek's Avatar
USA, CA, Novato
Joined Jul 2008
crist really well done. You must have awesome vision to be able to see for 30k'
captaingeek is offline Find More Posts by captaingeek
Old Jan 26, 2011, 01:22 PM
Joined Mar 2008
http://cgi.ebay.com/Stronger-2W-33DB...item4152477db2
Anyone use this?
Old Jan 26, 2011, 01:38 PM
USA, CA, Novato
Joined Jul 2008
i dont know but i've seen some consumer level 2.4ghz wifi boosters that ive been thinking of
Old Jan 26, 2011, 02:01 PM
Joined Mar 2008
You would need to know what the maximum input level is for that booster.
Old Jan 26, 2011, 02:44 PM
Joined Mar 2008
I think ill just get the one from DIY drones. How much cables would i need to properly attenuate the signal on euro power?
Discussion A single Unit for long range control and video link markeydoo FPV Talk 1 Apr 06, 2010 02:18 PM
Discussion 2.4Ghz 500mW Pen Booster Range test sirocco FPV Talk 12 Oct 02, 2009 05:26 AM
Discussion Range issues with Spektrum DX7 jc9995 Radios 6 Sep 16, 2009 10:45 PM
Discussion Spektrum claims the DX7 has full range....does anyone know the actual range in ft? TheFlyingAce Radios 42 May 31, 2008 02:04 PM
Discussion DX7 or other 2.4 Ghz for long range E-glider bmwbob Radios 6 Mar 04, 2008 05:05 PM
