Old Aug 01, 2010, 09:38 PM
Crist Rigotti is offline
Find More Posts by Crist Rigotti
First to go over 106K feet
Crist Rigotti's Avatar
United States, TX, Waxahachie
Joined Mar 2008
Tonight I went out a whopping 30,350 feet. 5.78 miles or 9.31 km. Video was very good and I started to get failsafes so I turned back home. Maybe I'll try a patch antenna on the DX7 to see if I can get further out.
Crist Rigotti is offline Find More Posts by Crist Rigotti
Old Aug 01, 2010, 09:41 PM
aviatordave is offline
Find More Posts by aviatordave
I AP'd myself again......
aviatordave's Avatar
Yawn....Iowa
Joined Mar 2005
Amazing Crist. Give me a yell next time you do that! I'll come down.
Ha, it says we are 176 miles apart...more like 17.6 miles
aviatordave is offline Find More Posts by aviatordave
Old Aug 01, 2010, 09:58 PM
Joined Mar 2008
Thanks Dave will do. Might even go out tomorrow evening.
Old Aug 01, 2010, 10:35 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
A patch will do wounders. That distance so far is outstanding.
Martin Y is online now Find More Posts by Martin Y
Old Aug 02, 2010, 01:55 AM
Ian Davidson is offline
Find More Posts by Ian Davidson
Old Blighty
Joined Apr 2010
I use a 1W booster with 18dB patch antenna. Works faultlessly.
Ian Davidson is offline Find More Posts by Ian Davidson
Old Aug 02, 2010, 02:17 AM
guipedroso is offline
Find More Posts by guipedroso
guipedroso's Avatar
Brasil, PR, Curitiba
Joined Apr 2010
Cris, what downlink frequence are you using with? And its power output?
Thanks!
guipedroso is offline Find More Posts by guipedroso
Old Aug 02, 2010, 03:30 AM
Old Blighty
Joined Apr 2010
When you were 5.78 miles out, at what altitude were you flying at ?
Old Aug 02, 2010, 06:47 AM
Joined Mar 2008
Thanks!
See post #1 for details except I'm going with the 1W booster now.
Old Aug 02, 2010, 06:48 AM
Joined Mar 2008
5K feet. Next time I'm out that far I'll try it at the 10:1 ratio.
Old Aug 02, 2010, 07:27 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
Obviously you didn't know that 5.78 miles is impossible with 2.4. It's not even worth trying. Not even worth discussing.
Keep up the interesting work!
Gary Evans is offline Find More Posts by Gary Evans
Old Aug 02, 2010, 09:11 AM
Joined Mar 2008
Thanks Gary. I will.
Old Aug 02, 2010, 11:10 AM
garris2 is offline
Find More Posts by garris2
Australia, VIC, Glen Waverley
Hi Christ, I've read that your going to (maybe have already) put a 6db attenuator in place of the current 4db. That would lead to a reduction in output power, May I ask why you are doing this and what is the thinking behind it?
Thanks Geoff
garris2 is offline Find More Posts by garris2
Old Aug 02, 2010, 11:23 AM
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Geoff
The Attenuator go's between the radio and booster. It's used so it doesn't damage the output of the radio which puts out more power than the input to the booster needs to operate. The dx7's output power cant be reduced as in the dx6i which can be turned down.
Old Aug 02, 2010, 11:24 AM
Joined Mar 2008
Thanks Geoff
Neither attenuator reduces the output power of the booster. They only reduce the input power. Input power is not direct relation to output power. BTW, I started with a 6db attenuator then switched to a 4db attenuator because my brother was using one and I wanted to "proof" it for him. I never bothered to change back to the 6db attenuator.
Old Aug 02, 2010, 12:32 PM
garris2 is offline
Originally Posted by Martin Y View Post
Geoff
Yes I understand that. My understanding is also that the RF amp does not put out a fixed 1W of power. It has a gain of around 15dB, so a reduction of input power (because of the greater attenuation of 6 of 4dB) would lead to an overall reduction of output power.
So I was curious to know why Christ might want a reduction in output power (of the amp). Because the output power of the RC Tx can't be changed.
Discussion A single Unit for long range control and video link markeydoo FPV Talk 1 Apr 06, 2010 02:18 PM
Discussion 2.4Ghz 500mW Pen Booster Range test sirocco FPV Talk 12 Oct 02, 2009 05:26 AM
Discussion Range issues with Spektrum DX7 jc9995 Radios 6 Sep 16, 2009 10:45 PM
Discussion Spektrum claims the DX7 has full range....does anyone know the actual range in ft? TheFlyingAce Radios 42 May 31, 2008 02:04 PM
Discussion DX7 or other 2.4 Ghz for long range E-glider bmwbob Radios 6 Mar 04, 2008 05:05 PM
