Old May 18, 2010, 11:29 PM
dJC_0175 is offline
Find More Posts by dJC_0175
Joined May 2010
Question
Electric Water pumps for cooling
I've searched and haven't seen much on this issue. I'm tinkering with a build and I know everyone uses forced water pickups but when you stand still heat is still released from the motor, and the esc. So what about constant cooling. Pro's / Con's??
I ask because I've come across some micro pumps, 1.5-2.5L/m (0.4 - 0.8G/m), .3A, ~50g, 6-12V, and only 20x30mm in size.
Thinking about running it off the BEC or testing on a regular 9V battery separately. Just curious if anyone has really experimented with this. Do you still need to run external pickups, or can you keep it flat with the hull. Does speed of the boat play a role or will the water output remain constant?
Right now I'm just playing with the idea and want some input on what others have tried and found.
JC
dJC_0175 is offline Find More Posts by dJC_0175
Old May 19, 2010, 12:31 AM
Jeff Wohlt is offline
Find More Posts by Jeff Wohlt
www.rcraceboat.com
Jeff Wohlt's Avatar
Jefferson City, MO
Joined Feb 2009
We did a lot of work on that concept and it works great. Read this.
http://forums.offshoreelectrics.com/...ad.php?t=10810
Jeff Wohlt is offline Find More Posts by Jeff Wohlt
Old May 19, 2010, 07:05 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Hey djc.............I did just what you are referring to in my big Dumas. Works great, i run it on an "AA" 8 cell pack(toy car pack), it keeps a constant 10-12 inch stream going. When i bring it in I let it sit there for a couple minutes just to cool it more as that is the time the temp starts to go up........after the run. I also have the option of stopping anytime out in the water and it continues cooling.
http://www.ehobbies.com/sot1249.html
Pic of it in action:
scorpion1 is offline Find More Posts by scorpion1
Old May 19, 2010, 08:27 AM
idocdave01 is offline
Find More Posts by idocdave01
Joined Mar 2010
I have thought about using a 12 volt windshield washer pump on a lower voltage to reduce the water flow.
Dave
idocdave01 is offline Find More Posts by idocdave01
Old May 19, 2010, 09:06 AM
dJC_0175 is offline
Joined May 2010
Thanks for the link Jeff. Learned a lot not only on the cooling but also how to build a better Mystery ESC. I may have to try that LOL.
Scorpion - LOOKS GREAT!! What are the specs on that? I haven't been able to find them yet. L/m, G/m, size, weight? How do you pick up the water? Do you find the cooling more or less effective than normal forced water systems? Any information on how speed plays a factor in picking up the water?
idocdave - I like that idea although for the weight you'd be almost better to try a fuel pump from a car. More efficient and possibly lighter depending on the model, but I'm thinking Chevy applications.
I'm definitely going to give this idea a try. Especially this being a commercial BRUSHLESS pump. Rated temp for the pump is -40 - 100+ Celsius. I don't think I'll go as far as making it a closed loop as this is purely for more fun than racing. Just looking at optimizing the cooling of the system with the least amount of weight added. And 100g (~3.5oz) seems like a really good trade off, especially if I can run it off the BEC, or a 9V battery (45g).
Old May 19, 2010, 09:09 AM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
That's exactly why I use an 8 cell even though it's rated for 10 cell, I think with added pressure at full speed it flows about like it would with 10 cells and therefore not over revving the pump motor. This system works great.
Edit: it's about 1 1/2 inches wide and tall and about 4" long, doesn't weigh much at all.
Question Maintenance for Water Cooling Tubing? <All set - thanks!> Old No7 Dock Talk 10 Apr 06, 2010 07:02 AM
Question Boat ESC in plane? air cooling through fuel line like water cooling? flythreedee 3D Flying 7 Apr 01, 2010 01:40 PM
Cool The unique water-cooling brushless outrunner motor with water circling in the center AEO_Tang Racing Boats - Electric 27 Oct 15, 2009 07:40 AM
Discussion Looking for water pump for motor cooling RCBoater Dock Talk 8 Sep 11, 2009 06:59 PM
Poll Water pumps or no water pumps richclausen Racing Boats - Internal Combustion 4 Jan 29, 2009 11:49 AM
