Old Nov 08, 2010, 08:31 AM
ssatoru is online now
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Hi Ken,
I am travelling since last week and cannot work on the model right now.. I am hoping to fly it by end of this month but it will be land based flight. I will check battery space and cg soon.
Satoru
ssatoru is online now Find More Posts by ssatoru
Old Nov 09, 2010, 11:03 AM
kitaro is offline
Find More Posts by kitaro
kitaro's Avatar
Italy, Tuscany
Joined Apr 2006
Originally Posted by Jürgen Be View Post
thats it
Firehawk989
I did the payment via banktransfer, the called it payment by T/T. First I was`nt shure, if I will do this to a forein country, but everything went fine. No problems with order, payment and shipping. But the shipping was nearly the same price, as the model
Also nice contact via email with the support. I checked everything by email, also ordered the model by email, not on the website.
Jürgen
hello from Italy
i'm waiting one ITEM A5 like your.
Please give me some links from HobbyKing (do you bought from they??)about:
  1. MOTOR (TYPE AND WEIGHT)
  2. SERVOS (7?)
  3. ESC (A?)
  4. BATTERY (mAh, CELLS AND WEIGHT)
some modding, precautions, substitutions items.... so i can order electronics ...
thanks
Andrea
kitaro is offline Find More Posts by kitaro
Old Nov 09, 2010, 11:20 AM
Jürgen Be is offline
Find More Posts by Jürgen Be
Jürgen Be's Avatar
near Stuttgart, Germany
Joined Oct 2008
Andrea,
hope you mean the "small" A5
I posted my items in post *8* on first page of the thread.
I`ve got the motor from this shop:
http://www.rc-brushless-shop.de/contents/de/d77.html
the type is AE2810-01E
prop is a 3 bladeed 6x4" Masterairscrew, from the same shop
http://www.rc-brushless-shop.de/contents/de/d93.html
ESC should be around 20A
Battery is a Dymond 2s 1350mAh from this shop
http://www.modellhobby.de/Akkus/DYMO...&c=3261&p=3261
I`m shure, you will find some similar parts at HK
Jürgen
Jürgen Be is offline Find More Posts by Jürgen Be
Old Nov 10, 2010, 03:26 AM
kitaro is offline
kitaro's Avatar
Italy, Tuscany
Joined Apr 2006
Andrea,
Jürgen
No... mine is the bigger (1800mm)
your is the smaller?? from your photos are similar to big.....
I need info about electronics inside to a big Amphibian Icon A5....
thanks
Old Nov 20, 2010, 07:55 PM
greggk is offline
Find More Posts by greggk
Joined Dec 2007
Is this the same plane from Easytiger?
http://easytigermodels.com/index.php...roducts_id=222
greggk is offline Find More Posts by greggk
Old Nov 20, 2010, 09:52 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Same airframe, but with the equipment installed. I have the kit with retracts en route and can easily complete it for far less than the 400 bucks that ETM charges for the PNP version.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Nov 20, 2010, 10:05 PM
greggk is offline
Joined Dec 2007
Thanks, where can I get just the plane? If i want to make it an exclusive seaplane does it come with the gear "doors" to seal them up like i did on the GP Seawind?
Old Nov 21, 2010, 03:52 AM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Try emailing Venice at this email addy:
nfdmodel@yahoo.com.cn
I've just paid for one myself, hoping it wont take too long to be delivered
AussieHoppy is online now Find More Posts by AussieHoppy
Old Nov 21, 2010, 12:12 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
As you can see from the various pictures in post number 24, there are no gear doors. The gear wells are closely cut to fit the gear and once on step, all gear wells would be clear of the water. Even when the model si not on step and moving in te water, I think there is no ill effect from the gear wells.
If you want to seal them up, some carefully cut close outs made of a couple of layers of 6mm depron would likely work well.
Old Nov 28, 2010, 08:23 AM
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
I finally got a chance to maiden 1.8m ICON A5, not from water but from land.
I ended up with Hyperion ZS3025-10 motor, Master Airscrew 12x6 3 blade prop and 4S Hyperion G3 35C 4200mAh lipo (450g) I had. It gives peak of 580W or so at 36-37A. I have not weighed AUW yet.
Good news is ICON A5 flew flawlessly stable. It was paved runway and take off was smooth. Need to control pitch to match speed to avoid sudden pitch up at take off (it wants to stay level until certain speed.)
Pusher prop gives very nice noisy sound as expected.
It can fly slow well even without flap. I applied a little aileron differential and did not need much rudder to turn without slipping.
This power seems to be enough. It can climb fast, can loop from level with speed. At this level of current consumption, probably I can enjoy touch and goes on water for 15 minutes safely.
CG was a little fore than specified. That pack was too light and I placed another 4S 3300mAh lipo as a weight. Floor center was occupied by linkage, so battery packs sit off center.
I also experienced periodic tail wag. It occurs at certain speed and under certain maneuver which I could not reproduce.
Applying throttle did not give pitch up or down. It wants to drop wing near/at stall speed which can be recoverable with small altitude.
I think I used Atlas DS11 10g servos for aileron, DS-13 18g for flaps and elevator, DS-13 metal for rudder and gear retract. Flap servos openings are layouted asymmetrically to control with Y cable (I used 8ch Rx though.)
Retract linkage is a pain. Required stroke of 2 retracts are too different, wire is too long to push for nose. I will think about to add one more separate servo for nose gear. Rest of build was straight and quick.
It seems I broke nose gear retract when I landed hard at the 5th flight today. I need to figure out how to cut around nose.
Waiting a chance to go to lake/river soon.
Satoru
Old Nov 28, 2010, 09:18 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
There is another plane very similar to this one , but it has a "water ski" instead of a float type hull , I had some pics and info but lost it .
Does anyone kmow of it ??
lake flyer is offline Find More Posts by lake flyer
Old Nov 28, 2010, 03:02 PM
Joined May 2010
Cessna 182/ 185?
Old Nov 28, 2010, 08:10 PM
1post is offline
Find More Posts by 1post
Joined Apr 2010
I think a Rufe would be closer than a 172.
Seriously, was it this by chance, although it has skis?
1post is offline Find More Posts by 1post
Old Nov 29, 2010, 11:16 AM
lake flyer's Avatar
Joined Nov 2005
This was a new plane on a hydro ski , I think the name started with F.
Old Nov 29, 2010, 06:59 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
This was driving me crazy, but I think I found it...the Shearwater?
http://www.shearwateraircraft.com/Te.../Hydroski.html
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 03:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 05:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 10:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 02:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 11:47 AM
