Old Oct 26, 2010, 08:58 AM
baddb1 is online now
Find More Posts by baddb1
I'd rather be flying
baddb1's Avatar
United States, NY, Saratoga Springs
Joined Jan 2009
Originally Posted by lupy View Post
Wow Baddb1 sorry to hear about your in-flight failure.
On the ready2fly video, they are flying pretty normally, and not folding a wing. I wonder if they have increased the tube thickness since your's shipped? They may also have simply slipped a wood dowel into the tube to keep it from deforming. Didn't you mention that the wings have aluminum tubes in them that the joiner sits in? I think I can see them in your pic. Initially, I thought these were a good idea, but looking at your failure, they make the wing extra stiff, so that in a gust condition, all the flexing must happen right at the joint. Also they present a hard edge that will tend to crush the joiner tube at that point. A thicker fiberglass or carbon rod is definetly going to be a better choice than aluminum. If you get a tube, I would mix epoxy and fill at least the center section where it sees the corners of that wing insert to prevent it from crushing. Go to a Kite shop or search for carbon fiber tubes on line.
The tipping in any wind is another problem. I was wondering if that would be an issue. I know that a number of full sized seaplanes lack tip floats, but almost all RC seaplanes have them. I think it might be a scale issue as a plane is shrunk: as you scale a plane up or down, not everything changes in the same way, Wing span changes nornally, but wing area increases as a square, and float volume increases as a cube. This is why a full sized seaplane has floats that look tiny compared to an RC plane. If we just scaled everything down, the floats wouldn't displace enough water and the plane would sink. It's also the reason the aquastar sits so low compared to a seamaster, and why the sandbird was never a good water plane.
Could you mock up some right on the tips like the seawind has? That would at least keep the wing from getting under the water and sticking, then with full up as the plane gains a little speed, it should pop the wing free.
Looking at the video closer, I see some of the wagging you mentioned, it's easier to see in 420dpi on full screen. The more I see of this, the more I suspect that the vertical tail is too small to stabilize the huge nose this has. I would be tempted to hot glue a depron addition to the rudder, making it wider. That is what I did to my twinstar seaplane, and it really tamed things down.
I am really saddened to see all the problems this plane has. I was hoping to have a big foam seaplane to do some FPV work with, but the tipping and the wagging really put the damper on it all. It's a pitty too because the Icon is such a pretty plane. Hopefully, with a few mods it will work out. I think Chinese designed RC planes are a bit like beta testing software. At least we arn't actually riding in them....
Yes, it is a square alum. piece that the tube slides inside the wing. I agree, the tube could easily be crushed at the point where it joins with the fuse. I think the dowel in the tube should help with that. Mcmaster Carr does have several alum. tubes with a thicker wall, so I am checking into that.
I'm really wondering if there shouldn't be another set of screws holding the front part of the wings down? There seems to be a lot of stress on the small top part of the fuse where the tube slides in....?
I was thinking that another possibility of the failure is when I attempted the take-off in a 5mph breeze and the wing dug into the water. Maybe this caused some stress on the alum. tube??
I may add some floats for the wing tips as you suggested. It is frustrating that it needs to be a dead calm day to fly off the water.....
baddb1 is online now Find More Posts by baddb1
Old Oct 26, 2010, 08:59 AM
baddb1's Avatar
Joined Jan 2009
Originally Posted by ggcrandall1 View Post
baddb1,
Tower Hobbies has aluminium tubing in several sizes although only in 12" lengths.
http://www3.towerhobbies.com/cgi-bin...ube%3C%2FB%3Es
You might check other hobby shop sites.
I just remembered another source. Lengths to 6 ft.
http://www.mcmaster.com/#aluminum-tubing/=9fj48g
Glen
Thanks! Lots of stuff in McMaster!
Old Oct 27, 2010, 12:23 AM
Msioni is offline
Find More Posts by Msioni
Joined Oct 2010
OMG I LUV AIRPLANES THEY R SO COOL
AIRPLANES
AiRPLANES LOL
Msioni is offline Find More Posts by Msioni
Old Oct 28, 2010, 01:55 PM
lupy is offline
Find More Posts by lupy
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
Uhh, Whatever....
Just a thought, I have a fair amount of experiance machining aluminum. A lot of solid rod comes as 6061 T6, which is fine for making machined parts, but isn't really ment to resist bending like some tube stock. Before you invest time and $$ chasing solid aluminum, you might try flexing some of your remaining tube, and then the stuff you have seen at home depot. I have even found some solid rod that was dead soft, and ment to be bent into shapes, obviously this won't do you much good.
I still think going to a carbon rod is the best solution, they are so much stiffer and stronger than aluminum. Depending on the size, there are even some square carbon rods available. Can you get a precise measure of the old rod? And it's length?
lupy is offline Find More Posts by lupy
Old Oct 28, 2010, 04:08 PM
AussieHoppy is online now
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
Uhh, Whatever....
square section CF would be so perfect!
I'm still trying to buy one of these from ndf or whoever they are... quicker to have a tooth pulled lol
OT... your avatar... per chance Dog off footrot flats?
AussieHoppy is online now Find More Posts by AussieHoppy
Old Oct 28, 2010, 11:48 PM
lupy is offline
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
No, it's just a husky I found floating around the net. Actually, my RL dog is pretty close to dog from Footrot flats, but since he's black, it's hard to get a good shot of him.
Old Oct 29, 2010, 07:09 AM
baddb1's Avatar
Joined Jan 2009
Uhh, Whatever....
I agree. The rod at HD seemed to flex quite easy so I didn't buy it.. I ended up buying an Aluminum tube at McMaster Carr that had a thick wall and was listed as a "structural" piece. It has 3/32" walls and seems perfect! I installed it last night and once the winds die down here, I'll give her another go.
Old Oct 29, 2010, 07:41 AM
ssatoru is online now
Find More Posts by ssatoru
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
Hope your new tube works.
This is what come in my kit. OD 11.5 mm, ID 6.5 mm. Is this the same as yours?
I got servos and started to build mine.
Satoru
ssatoru is online now Find More Posts by ssatoru
Old Oct 29, 2010, 08:35 AM
baddb1's Avatar
Joined Jan 2009
Satoru
No way!! Mine has a much thinner wall...
The new tube I bought is now like yours.
Old Oct 29, 2010, 10:36 AM
lupy is offline
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
ssatoru, does the square aluminum tube in the wing come unglued? or is it just extra long?
Baddb1, glad to hear you found something. That new tube looks loads stronger, you might also round the top edge of the square tube where it pushes down against the round tube, this will help spread the load some and prevent crushing, although it dosn't look like a problem anymore.
Old Oct 29, 2010, 11:49 AM
ssatoru's Avatar
Chiba, Japan
Joined Jan 2002
baddb1, it seems manufacture is learning.. Let's see this tube works ok.
lupy. I am not sure the square tube was glued at all. The round tube is a tight fit and one of square wants to come out. I will glue it.
Square tube is in the fuse (where serve extension comes out) and vertical fin as well.
I found a transparent formed sheet in parts bag with motor mount. It fits here. I guess the manufacture is trying to protect water to come in.
Satoru
Old Nov 03, 2010, 11:44 PM
martialllaw is offline
Find More Posts by martialllaw
Australia, QLD, Narangba
Joined Sep 2006
has anyone tried the 1m version of this aircraft??
martialllaw is offline Find More Posts by martialllaw
Old Nov 07, 2010, 01:40 PM
kenfiori is offline
Find More Posts by kenfiori
Joined Sep 2010
Hi Satoru San , Could you PM me a foto of where to put the battery ? I am using a 4c 14.8V bulky battery , the main compartment is filled with wire rods from landing gear from front & back wheels , can't get it to fit nicely . also seems to be nose heavy . so i now put it in the aft compartment standing up . Try maiden in 20km wind yesterday head on , did not take off . Wing tip hit water like Baddb1 said .
Ken
kenfiori is offline Find More Posts by kenfiori
Old Nov 07, 2010, 06:45 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I have one of the 70" Icon A-5 models headed this way...I had a one time opportunity to add it to another container shipment headed to the US and my delivered cost will be $114 for the 70" kit with retracts. A couple of freinds and I were able to get this deal, but that ship has sailed....
I love the look of scale seaplanes with sponsons, but they typically do not scale very well for R/C models (small scale sponsons displace very little water.). I think the previous poster that mentioned it needing some tip floats for certain circumstances is likely right.
Will certainly double check the spar situation and make sure it is not a thin aluminum type.
Thomas B is offline Find More Posts by Thomas B
Old Nov 07, 2010, 07:04 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Originally Posted by baddb1 View Post
The A5 flew fairly well even though I was guessing at the COG point. The ROW was fairly quick and I was only at about 3/4 stick. I only had her up in the air a few minutes and noticed it was doing a little tail wag at times. What would cause that? COG not right?
Beleive it or not, certain R/C models with oversized vertical tails can actually have that tail wag that you noticed. The classic Bridi Kaos is a good case in point. I don't think that the tail wag was due to the large forward sail area of the fuselage. Even allowing for that, the vertical tail is pretty good sized and has a much larger moment arm than the fuse side area does.
In the case of the Icon, it is probably more likely some artifact of the airflow around the fuse at certain airspeeds mixing with the airflow from the pusher prop.
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 03:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 05:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 10:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 02:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 11:47 AM
