Old Nov 23, 2012, 08:44 PM
KTL13 is offline
Find More Posts by KTL13
Canada, AB, Sherwood Park
Joined Jan 2011
Finally got my hands on my 1800 Icon A5, should be here shortly. Already ordered servos for it, thanks to the guys on this forum for brainstorming that topic. What size of motor would fit on this plane? I am aiming on using a 6s setup, Id like more power than required. Can you fit a 50mm or larger one? I cant seem to find a 6s compatible motor in this 40mm size range, but maybe im not looking hard enough. Any suggestions are appreciated!
Thx.
KTL13 is offline Find More Posts by KTL13
Old Nov 23, 2012, 08:53 PM
davecrash is offline
Find More Posts by davecrash
Fly now crash later
davecrash's Avatar
Canada, ON, Newmarket
Joined Nov 2006
Originally Posted by SuperCub Man View Post
Frustrated!! Tried three times today and couldn't get off the ground - and then the new Robarts nose gear ripped loose!! Lousy foam broke. Now I'm really frustrated. I have a G46 but the can dia. is too big at 50mm. Looking at the G32 but it comes in three flavors.530KV 600KV and 770KV. The 530KV takes a 12" prop, but to be honest I don't know what these numbers really mean other than revs per volt. Is the 530KV stronger than the 770KV? It has a 42mm dia. can so it may fit the motor mount. Just flailing around here! May just put it on the shelf. The little Seawind flys great but the Ventus is a pig! I'm thinking these foamys may not be my bag after 50 years of working with wood. Perhaps I should look at some wood plane kits that will take a little more abuse as I convert to E-Power.
are you running the 530kv on 6S? Thats what it needs
davecrash is offline Find More Posts by davecrash
Old Nov 25, 2012, 10:37 AM
SuperCub Man is offline
Find More Posts by SuperCub Man
Joined Apr 2005
Thanks Lupy - I will try the G32 770KV. Specs call for 3~4 cell battery so I don't think I should go to 6 cell for power. Intended to use the two 3000 Mah's I've got up front for balance, to get 6000 Mah for longer flights.
With the lousy weather I've devoted my time to the gliders I've got in the pipeline. The Icon should work well in the snow a little later. Willl build up the nose gear mounting with wood and re-balance. Maybe tape over for the time being.
SuperCub Man is offline Find More Posts by SuperCub Man
Old Feb 08, 2013, 01:16 PM
KTL13 is offline
Joined Jan 2011
Got the Icon all built and successfully maidened it. Im running a 60 sized motor with 6s and a 12x6x3 prop. Its so noisy, I love it! Here is a question for those of you that have built and flown theirs.......did anyone need to shim the motor up or down? When flying the Icon has a big tendancy to pitch down on throttle. It made for a very difficult landing since I had trimmed it so much up to compensate for that nose down attitude. I was reading about the CG and the rear prop and how it depends the line of thrust. I was thinking of putting some washers on the top part of the motor to effectively push the prop angle down towards the tail but perhaps the opposite would be true? Anyone experience this?
EDIT
I did some research on other rear prop planes and now I do in fact think the opposite is what I need. Tilt the motor up with washers at the bottom. If anyone can attest to this please chime in.
Old Feb 15, 2013, 08:18 PM
SENTRY 62 is offline
Find More Posts by SENTRY 62
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
SENTRY 62 is offline Find More Posts by SENTRY 62
Old Feb 16, 2013, 03:19 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
I disagree with Sentry. All of my high thrust line models do much better with the motor thrust line angled up to the front, looking from the rear of the model to the front of the model. Works on my large A5, works on my Seawind, works on my own design Skimmer, worked on my long ago scratch built Ken Willard Seamaster. Keth Sparks discovered the same thing on his Macchi M5 design.
If it is a tail mounted motor like a Polaris with the prop far back on the model, then the downthrust does work better than upthrust, generally.
Whe the prop is located roughly somewhere between the trailing edge of the wing and the leading edge of the wing, an up thrust line can do a lot to prevent nose overs at high power settings and low air speeds.
Also, with the T-Tail arrangement of the Icon, excessive downthrust as Sentry shows can affect the air blast on the horizontal tail, causing an additional nose down moment when power is applied, as the prop would be angled towards the bottom surface of the stab.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Feb 16, 2013, 03:37 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
Feel free to crosscheck in any of the pusher threads. You aren't disagreeing with me as much as you are disagreeing with aerodynamics
Here is example for you to test on your own plane : http://www.rcgroups.com/forums/showp...82&postcount=4
More information can be found in any pusher threads on here - the Easystar threads are a good place to research. Good luck.
PS: you can *cheat* by adding shims to the stab - but you're treating the sympton instead of resolving the problem.
Before doing anything - make sure you do power off glide tests to check CG. The rest is easy - and is as posted.
Cheers
Old Feb 16, 2013, 04:15 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
PS: you can *cheat* by adding shims to the vstab - but you're treating the sympton instead of resolving the problem.
Cheers
Sorry, but the aerodynamic and physics are more on my side than yours. I have used it and it works in many situations with most models. Think of it as a thrust vector diagram.
Please take a look at these full scale seaplanes and especially the engineering drawing of the full scale Seabee, which has a force arrangement exactly like that of the Icon.
Note the upthrust in the Seabee. It is there for a reason....
Also note the thrust lines of these two popular flying boats with high mounted motors, the Lake Renegage and the Osprey II. No down thrust....up thrust.
The extreme overkill downthrust does work OK on the Easystar, but properly done upthrust will work just as well and look more realistic.
Old Feb 16, 2013, 04:20 PM
KTL13 is offline
Joined Jan 2011
Well, here is a question, can it work both ways and is it just maybe better one way? I shimmed the bottom of the motor mount using a APC prop adaptor so its a pretty significant shim and went to test it and it worked. It still noses down a bit at full throttle but at low to mid speeds it remains relatively level. This is a huge improvement from the maiden!!!! I could probably even shim it a bit more at this point but I wont be flying max speed a whole lot so I think ill just save my time and live with it.
On a side note, the flaps on this plane are great. I took off with 1/2 and it was awesome, saved the fuse from getting dinged up while getting up to speed on the icy snow, and on landing with full flaps it did wonderfully.
Taxiing this plane on the snow is a lot to be desired. It likes to want to turn right but hardly left at all. Exactly the opposite of my other plane I fly and taxi on the snow (which makes sense because of the thrust pull.) Odd. Heres a dumb question, I have the motor spinning clockwise (pilot's view), is this correct?
Old Feb 16, 2013, 05:39 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Going with the upthrust instead of the downthrust will likely fix the last of the issue. Redirecting the airflow from the prop from impinging from the bottom of the horizontal tail, which is an effect of the down thrust line. If you blow on the bottom of the tail, it will tend to nose down. Get rid of that effect and it will be even better.
With the Seabee and the Lake Renegade, the thrust line blows a little more on the top of the horizontal tail, helping to keep the nose up at low airpseeds and high power settings.
Old Feb 16, 2013, 09:23 PM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
I'm glad my suggestion worked for you KLT. Thomas' example won't work (fully) bc he fails to see that his full scale examples wings are mounted on pods/pylons high above the wing centerline (which introduces other things that we won't get into, and the reason why the hor-stab on his 1st example is such an extreme angle). The biggest differece (and the one that matters the most) is that his examples the engine is almost directly over the CG. The A5s motor is on the chord line - TE of the wing (basically* level with the wings) and behind the CG. His examples are night/day different from the motor placement on the A5 and don't really apply here.
More data if you're interested in educating yourself ( http://www.rcgroups.com/forums/showthread.php?t=888546 )
Happy flying guys.
V/R
Sentry
Old Feb 17, 2013, 09:35 AM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
Happy flying guys.
V/R
Sentry
Sorry, but the Seabee example is not as you describe. The force arrangement is exactly as the Icon. I supplied the other examples to show that extreme downthrust on high mounted motors like the Easystar is not automatically the best way to go. The engineering is not made up. Further research on your part might well help you learn some new things....
Old Feb 17, 2013, 10:25 AM
I LIKE WAFFLES....
SENTRY 62's Avatar
Powder Springs, GA
Joined Sep 2010
My suggestion worked for the pilot - that's all that matters. Happy flying.
Old Feb 17, 2013, 12:29 PM
Thomas B is offline
Electric Coolhunter
Thomas B's Avatar
Joined Jun 2000
And my technique works on the Icon and other models and is favored by actual engineering practice....happy flying to you as well...
Old Feb 17, 2013, 12:59 PM
AussieHoppy is offline
Find More Posts by AussieHoppy
what goes up, must come down..
AussieHoppy's Avatar
Joined May 2010
in all seriousness, would this not be a scaling issue? There is a term for it, which eludes me atm, that refers to changes when a full scale design is scaled down.
I dont recall seeing a full scale pusher prop plane with exagerated thrust lines as we see in many scaled (and not so scaled )models.
I'm thinking in a way you are both correct...
Perhaps Thomas is correct with full scale & Sentry is correct with scaled flight?
Just a thought, you've both had me thinking on this too lol
AussieHoppy is offline Find More Posts by AussieHoppy
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 5 Jun 25, 2016 04:14 PM
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 03:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 05:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 10:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 02:00 AM
