Old Jan 14, 2012, 11:28 AM
Fly, crash, rebuild.
United States, NY, Shelter Island
Joined May 2011
Originally Posted by Thomas B View Post
Lots of extra work and maintainence, when the best bet is to not expose your expensive electronics to salt water.
I would estimate more time cleaning and maintaining than flying time, perhaps at a 2-1 ratio.
Indeed thomas, quiet the expedition in that case. Water takes everything to a new level and weight. I have a couple boats with 3 & 4S setups, sealed receiver box and marine escs and waterproof servos. Servos are Traxxas, but big, too big, for ailerons and flaps but perhaps a choice for the rudder steering.
I do a thorough rinse but its mostly aluminum. Less corrosion than steel and better grade stainless than in a plane.
Thanks for the ideas. I'll have to percolate more on this one.
H
shelterock is offline Find More Posts by shelterock
Old Jan 18, 2012, 10:43 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
Hi all
I had some advance making ICON-A5 by DZ hobby. I built in head lamps and fog lamps.
Small key-chain LED lights are useful as its brightness is enough even in the day light.
Yellow LEDs are good choice as fog lamps.
Now it’s time to make more.
shigetyann is offline Find More Posts by shigetyann
Old Jan 23, 2012, 07:55 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
At last I finished fuselage's modificatiion.
The last work of the hull was to modify main steps.
I find a question whether I should replace dark colored canopy with a clear one or not.
Old Feb 03, 2012, 07:37 PM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
Originally Posted by earaoz View Post
Hey Shigetyann, one more question. Your video refers to a "fixed mixing", could you please explain what channels you mixed? rudder/ail? throttle/elev?
Thanks!
E
To earaoz #495
Sorry reply late.
I've mentioned about the mixiting programs in the other thread "Small Icon A5 from HobbyKing-1.09 meter (NOT Guanli)" though.
I answer in this thread too.
I found the s288 ICON-A5 has a tendency that when you cut a motor power suddenly from horizontal flight, it’s inclined to nose up. The tendency is not big though, it’s a little difficulty to descend the plane without any control. If you are accustomed to fly R/C airplane, you may have elevator down slightly to keep its speed, or to make it to be in a gradual decline.
The Mixing from throttle position to elevator makes control a little easier.
The throttle curve from -100% to -75% has gradual gradient. This range matches to the plane keep a speed and gentle declination to touch down.
You should not to flare just touchdown, or the plane starts porpoise.
The easy avoiding way from porpoise is to power off immediately when the plane has the first touchdown.
Let’s enjoy!
Old Feb 05, 2012, 08:56 AM
Winnipeg, Canada
Joined Apr 2007
Excellent, thanks shigetyann!
E
earaoz is offline Find More Posts by earaoz
Old Feb 06, 2012, 08:58 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
E
It's my pleasure.
Shige
Old Feb 20, 2012, 06:43 AM
I'm BIG on micros
R.M. of Peel, ON
Joined Mar 2011
Nice. The issue I have with the Parkzone version is no retracts. Which model does have them?
JSS4 is offline Find More Posts by JSS4
Old Feb 20, 2012, 11:42 AM
lrplin's Avatar
Stockton CA.
Joined May 2007
The HK large scale A5 has retracts.
lrplin is offline Find More Posts by lrplin
Old Feb 20, 2012, 12:35 PM
I'm BIG on micros
R.M. of Peel, ON
Joined Mar 2011
Thanks.
Old Feb 29, 2012, 03:37 PM
Canada, AB, Sherwood Park
Joined Jan 2011
Where can you find a place to buy the 1800mm version other than the obvious HK, which is out of stock for weeks/months now and other overseas spots where you pay more for shipping than the actual plane.
I found 2 locations so far but both are out of stock....there has to be another place that has these....someplace!!!!!!
KTL13 is online now Find More Posts by KTL13
Old Mar 04, 2012, 10:11 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
At last, I got a clear canopy.
Big ICON A5 from DZ hobby, selling by Hobby King now, has a big canopy. The original built-in one is too dark to show cockpit.
Maybe everyone wants to replace a clear one. At last, I finished it today. Making a clear canopy was terribly hard job.
For me, try this one was beyond my boundary, but I wanted clear one cordially.
Since last autumn I imagined how to make it. It took about half year to finish the clear canopy.
Next I want to make the cokpit.
Regards
Shige
Old Apr 10, 2012, 10:04 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
Finally, ICON’s canopy was finished and colored. The cockpit has not finished, though. I’m trying to make a flight test in near future.
Old Apr 12, 2012, 10:41 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
flight test from the land
At last, I made a test flight from the land. “The flight test” means my ICON has not finished yet, mainly around the cockpit.
Its elevator trim was cruel at first. I had to push elevator stick up half…
In some way, I finished to check retruct gears and flaps those worked well.
The next flight test is from the water.
Flight Test From The Land テスト飛行 ICON A-5 (A488) (陸上から) (6 min 47 sec)
Old Apr 18, 2012, 10:03 AM
shigetyann's Avatar
centrea Japan
Joined Nov 2006
Still constructing cockpit.
I made two rack housings of instrument panel in my ICON.
At first, I made positive die from balsa block.
The housing was made of 0.5 mm thick PVC sheet.
Using heat gun, the sheet transformed into rack housings.
Then colored and cut, rack housings were finished.
Attached on dashboard it, and also fit a motor cowl, my ICON looked as if the model had finished.
I’m going to fly it from the water in the next chance.
Old Apr 18, 2012, 12:22 PM
lrplin's Avatar
Stockton CA.
Joined May 2007
Really nice works.
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 106 Jul 01, 2012 10:28 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale Electric Planes 4 Sep 04, 2011 05:22 PM
Discussion GuanLi Icon A5 for FPV popoti Video Piloting (FPV/RPV) 22 Nov 11, 2010 10:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 02:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 11:47 AM
