Old Sep 30, 2011, 09:42 PM
Windfree1960 is offline
Find More Posts by Windfree1960
Joined Sep 2011
anyone know where to get replacement parts for this? i lost the motor cover in flight today.
Darcy
Windfree1960 is offline Find More Posts by Windfree1960
Old Oct 04, 2011, 03:45 AM
TeeJayBee is offline
Find More Posts by TeeJayBee
United Kingdom, Swansea
Joined Mar 2011
Contact Alice at dzhobby.com, though you'll probably need a complet new fuselage
alice@dzhobby.com
TeeJayBee is offline Find More Posts by TeeJayBee
Reply With Quote  (Disabled)
Old Oct 04, 2011, 10:14 AM
h_bondok is offline
Find More Posts by h_bondok
h_bondok's Avatar
Canada, AB, Calgary
Joined Dec 2008
Originally Posted by shigetyann View Post
Hi h bondok
I donít pay attention to any type of servos including water proof type.
Thereís no way to use servos, or other electronics, on seaplaneís wing without waterproof.
This is an example.(ndf s288)
I use a clear polypropylene adhesive tape used in packing and a modified acrylic silicone glue that has the flexibility after it cures.
After covering grooves for servos and wires with the tapes, I coat all the end of the tapes with the glue dilute.
Good luck!
Shige
Thank you Shige. In fact i had water proofed all of my servoes. i dis-assembled all of them and used silicon grease to fill the servos internals with it. i tested it in the water and sound like ok.
Bond
h_bondok is offline Find More Posts by h_bondok
Old Oct 09, 2011, 06:17 PM
Windfree is offline
United States, WA, Shelton
Joined Aug 2007
replacement parts
for anyone looking for parts like me, I found KONDOR MODEL PRODUCTS KMP.CA will be stocking parts for the 1.8 meter icon a5.
Darcy
Windfree is offline Find More Posts by Windfree
Old Oct 15, 2011, 03:19 PM
staggeringwade is offline
Find More Posts by staggeringwade
United States, Mt, Helena
Joined Aug 2011
My Icon A5 (the large version from HK) came in with only 4 no name servos as expected from all of the complaints. The box was damaged badly but plane was fine. There were other misc parts missing-it looked like the parts bags were cut open with a box knife before shipping because nothing was in the bags and were scattered in side the box. Parts probably fell out of the large holes on the box due to shipping to the USA from china.
What servos are you guys using i this plane?
I was planning on using a metal gear servo for the rudder and nose wheel. But wasn't sure a small servo would work. I have 3 of the hobby king 996 mg servos i was thinking about using for rudder and retracts. Will this add too much weight?
I was going to replace the front landing gear with a robarts 602 unless somebody has a better idea.
I was going to use 2 3S LiPos on each side of the servo tray for better weight distribution and CG.
Wade
staggeringwade is offline Find More Posts by staggeringwade
Old Oct 16, 2011, 12:01 AM
Dakrat is offline
Find More Posts by Dakrat
Sky good, Earth bad!
Dakrat's Avatar
Anchorage
Joined Dec 2005
What size batteries are you guys using? I used a 2x Zippy 3000 5s and the plane seem very heavy. I had a very hard time getting her up to plane without sucking up a lot of water in the prop. She seemed to plow under the water. I was using a Turnigy 42-50 motor and a 10x5 3 bladed prop.
Dak
Dakrat is offline Find More Posts by Dakrat
Old Oct 16, 2011, 02:44 PM
Thomas B is offline
Find More Posts by Thomas B
Electric Coolhunter
Thomas B's Avatar
United States, TX, Fort Worth
Joined Jun 2000
Anyone have a good source for the smaller 1.09 meter Icon from DZ model, besides Hobbyking? I do not care for the ugly markings HK added, or their choice in electronic parts for the PnP version.
Thomas B is offline Find More Posts by Thomas B
Latest blog entry: 2014 events and travel
Old Oct 25, 2011, 11:10 AM
h_bondok is offline
h_bondok's Avatar
Canada, AB, Calgary
Joined Dec 2008
Dak
I'm using 2 of 2200 MAH 3S connected on sieres and it works pretty good. the plane not heavy, takes off water easly and glide at half the throttle. i'm using the stock motor and prop. with 60A ESC. this set up is good for me. by the way another advice, water does affected my electronics. the plane get out of control fiew times when the receiver get wet.
solution is to spray it with corrosionx. it water proofs electronics very well and then i don't have that proplem any more.
Old Nov 02, 2011, 08:26 AM
Skyguide is offline
Find More Posts by Skyguide
Joined Oct 2011
Maybe check out the Skyguide BUILD blog here about experience with the LARGE ICON A5. This model is from HoobyKing, but originally from http://www.dzhobby.com/
Skyguide is offline Find More Posts by Skyguide
Old Nov 02, 2011, 08:13 PM
earaoz is offline
Find More Posts by earaoz
Winnipeg, Canada
Joined Apr 2007
Cg
Guys, I got the small one from HobbyKing:
http://www.hobbyking.com/hobbyking/s...dProduct=17108
And apparently these come with no manual...
Does anybody know where the CG should be located?
Thanks!
E
earaoz is offline Find More Posts by earaoz
Old Nov 02, 2011, 10:50 PM
DaveBC is offline
Find More Posts by DaveBC
Obessive Compulsive
Visalia, California
Joined Mar 2010
I'm afraid this thread is on the larger one. Have you searched on line for a manual? The large on has the CG in the forward 25% of the wing. If that helps.
DaveBC is offline Find More Posts by DaveBC
Old Nov 03, 2011, 02:18 PM
shigetyann is offline
Find More Posts by shigetyann
shigetyann's Avatar
centrea Japan
Joined Nov 2006
My s288 pink version's CG is 35mm from leading edge.
I think CG-position is not so sensitive, you may treat this model as a trainer.
Thanks!
E
ICON A5 very best of touch and go (3 min 40 sec)
shigetyann is offline Find More Posts by shigetyann
Old Nov 03, 2011, 03:13 PM
earaoz is offline
Winnipeg, Canada
Joined Apr 2007
Excellent, thank you so much!
E
Old Nov 12, 2011, 06:10 PM
cabman1969 is offline
Find More Posts by cabman1969
cabman1969's Avatar
Melbourne, Australia
Joined May 2008
Just read through the whole thread. I've loved this bird since the first time i saw it. The HK 1800 seem like the best rendition of the model so far (other than the few inconveniences of gear strength and servo replacement.) This will be my next investment.
cabman1969 is offline Find More Posts by cabman1969
Old Nov 12, 2011, 07:06 PM
earaoz is offline
Winnipeg, Canada
Joined Apr 2007
Hey Shigetyann, one more question. Your video refers to a "fixed mixing", could you please explain what channels you mixed? rudder/ail? throttle/elev?
Thanks!
E
Discussion Icon-a5 amphibious parkflyer ( new picture and plan ) kylevn Foamies (Scratchbuilt) 108 Feb 01, 2015 04:03 AM
New Product Seaplane ICON A5 by Guanli kitaro Scale ARF/RTF 4 Sep 04, 2011 06:22 PM
Discussion GuanLi Icon A5 for FPV popoti FPV Talk 22 Nov 11, 2010 11:40 AM
Discussion Interesting new LSA amphibian in the works: The Icon A5 Thomas B Waterplanes 30 May 14, 2010 03:00 AM
Discussion micro icon a5 afitz87 Foamies (Scratchbuilt) 4 Apr 24, 2010 12:47 PM
